Any way to relieve the stress the AC puts on the engine?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Andiamo, Aug 18, 2021.
  1. Aug 18, 2021 at 7:23 PM
    Andiamo
    Andiamo [OP] Well-Known Member
    Second battery maybe?
  2. Aug 18, 2021 at 7:26 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If it’s putting that much stress on the engine, something is wrong.
    Is your compressor working properly?
    It shouldn’t have any real noticeable effect on engine load.
    Modern compressors don’t tax the engine like they did years ago.
  3. Aug 18, 2021 at 7:26 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Not sure what your asking here?
    There's no way to take the load that the A/C compressor puts on the engine away other than not use it.
    0xDEADBEEF and TnShooter like this.
  4. Aug 18, 2021 at 7:27 PM
    Bishop84
    Bishop84 Well-Known Member
    Higher idle
  5. Aug 18, 2021 at 7:35 PM
    Clearwater Bill
    Billy
    Largo Florida
    Remove the AC.
    No more stress. On the engine. Just the occupants.
    Not really sure what stress you think there is?
  6. Aug 18, 2021 at 7:42 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    No.
    Unless you go this route:
    If you want to really check the stress it is putting on the engine, get yourself a bluetooth OBDII reader and watch the real time numbers. I think you'll see it is not as bad as you think. You can get everything you need for around $30.00. If your cooling system is working okay, you should be fine. Your alternator is very similar impact.
    snackz, 04taccoo, Junkhead and 8 others like this.
  7. Aug 18, 2021 at 8:01 PM
    Andiamo
    When I say stress I mean gas mileage
    otis24 likes this.
  8. Aug 18, 2021 at 8:03 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    No, not really other than not using it.
    It shouldn't really affect fuel mileage more than maybe 1 mpg.
    ciaman96, tinker_troy and TACOTU3 like this.
  9. Aug 18, 2021 at 8:03 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Nope. Ac requires energy to run, and that is provided by the engine. Only thing you can do is just not use it.
    modern ac is pretty efficient though.
    Dm93 likes this.
  10. Aug 18, 2021 at 8:06 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    The best vehicles didn't have AC.
  11. Aug 18, 2021 at 8:14 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Sure they did :D.
    04taccoo, otis24, essjay and 11 others like this.
  12. Aug 18, 2021 at 10:31 PM
    Dirty Dude
    Dirty Dude Well-Known Member
    2004 Tacoma SR5 Xtra cab 5-lug
    Dirt, miles, and wear.
    The AC compressor isn't powered by electricity. Its clutch is, but that's not a big power draw. Each amp of power at 12 volts only represents 12 watts. One horsepower is 746.
    That compressor is driven mechanically by the engine. The only way to eliminate that load is to not use the AC. That said, the effect on fuel economy should be a fraction of an mpg. Maybe not even measurable to most drivers. It's not measurable to me and I've tracked fuel economy with my truck for ~50,000mi now.
    Andiamo[OP] likes this.
  13. Aug 18, 2021 at 10:42 PM
    det107
    det107 Well-Known Member
    Vent windows were the best!
    Sandman614 and JudoJohn like this.
  14. Aug 18, 2021 at 11:02 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
  15. Aug 19, 2021 at 1:09 AM
    Hayrider
    Hayrider Over the hill & going down fast...
    Hey You…
    Convection Oven AZ
    15 DCSB & X-cab SOLD for more than new‼️ Now 05 & 07
    Reg Cabs, 5 lug, 5 spd, Magnuson & LS Swap, StopTech’s, Yada Yada Yada…
    PERFECT JUST PERFECT‼️ :rofl:
    Pull that 2TR and swap in an LS3… :D
    God I got to ask where do you guys find this $h!t? Best Forum on Earth!
    davidstacoma likes this.
  16. Aug 19, 2021 at 1:24 AM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    stupid question but ima ask it, why do i need to push ac button if the ac is already on, if i depress it the ac is still on….whats the freakin point. And yes you put more load cus its runnin off the belt to the engine, also at idle red lights itll kick on making you lose 1-2mpg’s. is it worth it? for me it is.
  17. Aug 19, 2021 at 8:28 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    gas mileage is not affected as much as the power hit, but all these Toyota trucks suffer the same odd hit. That's the main reason I never use it unless it's 80/80+ outside
    Living in an area with many many hills you tend to notice the struggles of the truck :D
  18. Aug 19, 2021 at 9:45 AM
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    The AC button engages the magnetic clutch and then the belt actually spins the compressor. That pulley is freespinning with little to no resistance otherwise.
  19. Aug 19, 2021 at 6:44 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    I've got 415,000 trouble miles on my '96 Tacoma and original AC and 2.7 engine both still work GREAT. Why on earth would would there be a need to relief stress the AC puts on the engine?
    Junkhead, Ridgerunner and JudoJohn like this.
  20. Aug 19, 2021 at 10:30 PM
    Caslon
    Caslon Well-Known Member
    2003 Base Cab. 2 whl drive. 5 speed
    Everything your fan belt moves succumbs to friction, over time.
