any welders out there?
Discussion in 'Off-Topic Discussion' started by tacoma08MZ, Jan 21, 2009.
  1. Jan 21, 2009 at 12:37 PM
    tacoma08MZ
    tacoma08MZ [OP] Well-Known Member
    Levi
    Pittsburgh, PA
    2008 Access Cab 4x4
    tinted head/tail lights-blacked out badges-3 inch tuff country lift 33 inch nittos-black steelies custom spare bed mount-hilift-weathertechs-kenwood dnx5120 dvdnav headunit-remote start-painted grille surround-fog lights-grillcraft black mesh grille
    ok heres the deal. i want to start playing around with welding, i always have i think it would be a good thing to know how to do then i can maybe start building my own stuff. the problem is i know nothing about it.
    what kind of welder should i look into buying?
    i wana spend like 2-3 hundred? but i dont know what they run?
    should i go mig tig or something else?
    any brand welder better than another?
    or should i just buy a cheap starter kit from walmart or somthing that ive heard about?
    any help would be great :)
  2. Jan 21, 2009 at 12:46 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
  3. Jan 21, 2009 at 12:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    My first Welder was a Miller. It worked well. Im not a Welder by trade, but I like to weld stuff now and then. Im better at ARC welding, and you can pick up one of them pretty cheap. Get a good helmet, preferably with an Auto darkening shield, and get a good set of leathers. Then, find some scrap metal and start welding. There should be plenty of on line info to get you started.
  4. Jan 21, 2009 at 12:50 PM
    Motoknuckle
    Motoknuckle Braaaaap!
    Caleb
    Iowa
    02 Prerunner xtracab V6
    Tint, Clear Corners,
    I would stay away from the cheaper brands.
    Try looking into stick welders, they are quite affordable and can teach you the basics of welding. Hobart makes great welders, they are what I used when I took my welding class.
    I've been a certified welder for about 3 years, but have yet to get one of my own due to college. After I get out I'll be buying myself one!:)
  5. Jan 21, 2009 at 1:07 PM
    OU812
    OU812 ban the term murdered out
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    Nothing yet, brand new!
    I've got an old Linclon at the house. It works pretty good for basic stuff, welding implement parts back together, misc stuff like that. Check out estate sales in rural areas/auctions for cheap one.
  6. Jan 21, 2009 at 1:10 PM
    98tacoma27
    Ben
    Not Beech Creek
    The type of welder you buy depends on the type of welding you want to do. You are going to have to spend more than $300 for a decent welder, unless you can find a good used one. As stated before, the best way to develop the technique is with a stick welder. You can a new 220V Hobart at Lowes relatively cheap.
    The cheap wal mart kits are marketed for the home mechanic, but built for the hobbyist (mig style anyway). They really aren't good for much.
    Do not forget to purchase the safety equipment either. You will need: gloves (that go halfway up your forearm), a helmet (auto adjust recommended), wear a long sleeve welding jacket, and leather shoes. I also recommend a welding cap.
    You should also have an agle grinder and many types of discs.
    Other tips:
    • keep your rods dry and free of moisture
    • never weld in water
    • be aware of your surroundings when welding
    • learn how the metal will react to the heat ( the importance of tacking and clamps)
  7. Jan 21, 2009 at 1:24 PM
    Killer Red Taco
    Killer Red Taco NorCal Rock Whore
    Whatsurname
    BFE–Norcal
    007 Tacoma A/C TRD O/R Impulse Red 4x4
    Bilstein 5100 on front at 1.75 setting • 5100 on back• K&N Air Filter• TRD Seat Covers• Day Time Running Lights• Foglights Anytime• Hella 500 lights in grille• Rear TSB Springs• Alternative Locker Mod• CB and 4 ft firestick II• Billet Grille• Kid puke in the back!• 265/75R16 Goodyear MT/R• 16" Devino wheels• Hose Clamp Mod• Revenge Fab Sliders• No Sway Bar• A Hottie as Copilot
    safety first I was zapped by a 220 millermatic once, it didn't feel so good.
  8. Jan 21, 2009 at 1:28 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    My advice is to buy a decent welder, not one of the cheapies. A good welder will last longer and save you from headaches and save money in the long run.
    An ARC welder will be the cheapest buy for you, though MIG may be easier to use. It's just a bit more expensive to buy/operate than stick welders. Also, make sure you look at the maximum thickness it will weld in a single pass, as well as the duty cycle of the welder.
    You'll also want to notice that the real small welders use 115volt power(home outlet style), many of the moderate size ones jump to 230volt so for one of those you would need to have a 230 power source.
    A combo tig/stick rig like the basic Miller Diversion 165 will be the most versatile as you can weld just about any type of metal (with an AC/DC rig) but are quite expensive, around $1500.
    As for brands, Miller, Hobart, and Lincoln are the ones i'd recommend.
  9. Jan 21, 2009 at 1:34 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    Welding is a skill that takes lots of practice, you can pick up the basics either on your own just by doing it or you can take a few classes which is what I'd suggest, with an instructor you have less chance of forming bad habits which are hard to break until to are forced for whatever reason into doing it correctly.
    I learned by getting tossed into the foremans position at a fab shop many years ago and had to pick it up pretty fast so I could hire and fire without being challenged on my abilities.
    I didn't get any type of certification until several years ago and went for my pipe certification because more of the projects I get involved in are requiring it now a days.
    If you want to buy a box and just start burning rod on your own, I suggest you stick with the name brands and avoid those cheapo deals you see at the local auto part stores, swing by a weld supply shop and talk to them, they get trade in equipment and they love new potential customers so most will point you in the right direction.
  10. Jan 21, 2009 at 1:34 PM
    tacoma08MZ
    Levi
    Pittsburgh, PA
    2008 Access Cab 4x4
  11. Jan 21, 2009 at 1:39 PM
    tacoma08MZ
    Levi
    Pittsburgh, PA
    2008 Access Cab 4x4
    xtreme i did hear somthin about the duty cycle from the guy i work with like for example you weld for a minute and it has to cool down for 10 or smohting like that? can you elaborate?
  12. Jan 21, 2009 at 1:39 PM
    Snipe
    Pacific NW
    08 TRD Off Road
    I work many days welding pipe laying in mud with a creek flowing in my right boot and coming out my left sleeve and if you cuss loud enough it drowns out the sound of the sparks jumping off the end of your eyebrows :D
  13. Jan 21, 2009 at 1:41 PM
    Killer Red Taco
    Whatsurname
    BFE–Norcal
    If you plan to mig weld with that you need different wire and a tank with a steel mix gas, AIrgas sells that
  14. Jan 21, 2009 at 1:42 PM
    Killer Red Taco
    Whatsurname
    BFE–Norcal
    I think we will call you sparky! :D
  15. Jan 21, 2009 at 1:45 PM
    tacoma08MZ
    Levi
    Pittsburgh, PA
    2008 Access Cab 4x4
    damn. even more money
  16. Jan 21, 2009 at 1:49 PM
    Killer Red Taco
    Whatsurname
    BFE–Norcal
    But flux core is good to start with and you don't have to drag a tank around:)
  17. Jan 21, 2009 at 1:49 PM
    Motoknuckle
    Caleb
    Iowa
    Welding isn't something that will be cheap.
    Like stated above, look for some auctions. They usually have quality used welders for a great price.
  18. Jan 21, 2009 at 1:51 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    my advice is dont get the walmart one thosr are set a 70 maps constantly which means that you can only weld thin metal (1/16 or 1/8inch thick metal)
    go for the adjustable 220 amp welder at lowes but keep in mind that for those you have to run a bigger power supply out to your shop/ work area
    never weld near water
    keep your rods dry
    dont weld in a wooden building (ive learned from experence)
    weld in a well ventlated area
    and always wear a mask gloves and a good pair of leather or steel toe shoes(cuz hot slag hitting your foot isnt the best feeling in the world)
    a good rod to start with is E6013 or E6011
  19. Jan 21, 2009 at 2:02 PM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    I'd say go with a ire welder for a few reasons. 1 is that they're small and often run 110V. Secondly, you don't have to make sure that the welding material is bone-dry. With a stick welder, the sticks have to be kept totally dry. Some guys use a toaster oven to dry them out. Additionally, you have to stop and change the sticks a lot, which is a pain in the ass.Wire welders can run on big spools that last a long time. It constantly feeds wire, which is nice. But stick welders are simple and usually inexpensive.
    What's nice about wire welders is that they weld really hot, as in the surrounding metal gets almost molten. Some people say that wire welders aren't good for heavy duty jobs. But I build custom racing mower frames which take a severe beating on the track, and I have yet to break a weld.
    Lastly- get a good welder. The ones at wally world and harbor freight are junk and will burn out quicker. I got a Lincoln Weldpac HD100. It was around $350. Get yourself a self-darkening helmet too. They're worth it. Lastly, get some good magnets to stick things together with.
    It takes a lot of practice to get good at it. Just get some scrap and paly around for a few days until you get the hang of it.
  20. Jan 21, 2009 at 2:04 PM
    RelentlessFab
    Eric
    Sparks, NV
    yeah basically. for example, 20% duty cycle would let you weld for 12 minutes out of the hour(60min). Maybe weld 3 min, cool for 12, and then repeat, etc. This is the reason why having a higher duty cycle is a good thing. Who wants to weld for a few minutes only to have to let the welder cool down for a much longer period of time than they can use it?
