Any welders?
Discussion in 'Jobs & Careers' started by 4banger4x4, May 21, 2013.
  1. May 21, 2013 at 4:52 PM
    4banger4x4
    4banger4x4 [OP] Probably should'nt have done that.
    Eric
    Whorelando, Fl
    Im gonna be graduating at the end of June, Ive got certs for vertical and overhead fluxcore open root under my belt and ill hopefully be getting 2 more at the end of school for 5 and 6G boiler tube. Just seein if theres anyone out there and if anyones got work.
  2. Nov 14, 2013 at 9:18 AM
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    You'll wanna head to dakota with your 4G and 6G certs. You'll get bank but will work hella horrible hours in the frozen tundra. Probably last about a year to two out there. Which will get you time to get contacts at power plants and see whats up with the unions. Good luck
