Any woodworkers?
Discussion in 'Garage / Workshop' started by Forster46, Mar 31, 2013.
  1. Mar 10, 2020 at 4:31 AM
    #4921
    98tacoma27
    Ben
    Not Beech Creek
    Route across the grain first, then with the grain. If that doesn't work then you will need a backer.
  2. Mar 10, 2020 at 4:33 AM
    #4922
    98tacoma27
    Ben
    Not Beech Creek
    Like this...
  3. Mar 10, 2020 at 5:54 AM
    #4923
    elgringoloco
    elgringoloco Well-Known Member
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
    Bro, you're a freaking genius. Thank you!
  4. Mar 10, 2020 at 6:21 AM
    #4924
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Also with soft wood you might need to slow it down. I use a Bosch (1617EVS) and found 4-6 is about right.
    wilcam47, elgringoloco and 98tacoma27 like this.
  5. Mar 10, 2020 at 6:43 AM
    #4925
    elgringoloco
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
    I've been doing edges on white oak, and didn't even think to slow it down for the pine. I'm going to try dropping it down to 4 and go from there. That little Craftsman router has some speed to it.
    shane100700[QUOTED] likes this.
  6. Mar 10, 2020 at 6:55 AM
    #4926
    GunBunny12
    GunBunny12 Well-Known Member
    SE PA
    '18 TRD Sport 4x4 DCSB
    You actually want to do the opposite. Slower speeds on hard woods so the bit doesn't burn the wood. Higher speed on softwood.
    Also keep in mind that when you change bits, if the cutting diameter changes, that means the speed changes; even if you don't adjust it on the router itself. Let's say you set the router to "4." A bit with a 1/4" cutting diameter is going to spin slower (at the cutting face) than a bit with a cutting diameter of 3/4". The machine is also working harder in the latter case.
  7. Mar 10, 2020 at 7:14 AM
    #4927
    elgringoloco
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
    Oh yeah, I had to adjust how much pressure I was putting against the bit/bearing when rounding over that oak. I didn't notice any burns, but I'll definitely go back and double check. Appreciate the wisdom!
    wilcam47 likes this.
  8. Mar 10, 2020 at 7:49 AM
    #4928
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    I had read that before, but with anything pine, if I go up in speed it’s a disaster. I’m sure someone with more experience could come show me how to make it work that way, just me though... it’s the only way I’ve gotten smooth cuts.
  9. Mar 10, 2020 at 8:17 AM
    #4929
    GunBunny12
    SE PA
    Without knowing the specifics of the disaster it's hard to give any tips. I'll throw out a couple of ideas though:
    Make sure you check the grain direction vs. the cut direction. You get tear out when you are cutting against how the grain "runs out."
    My other thought, since pine is pine, is that you may be getting rough or fuzzy cuts. This could be as simple as having a dull or chipped cutter head. Everyone says to make sure you take multiple small passes with a router, and while that's true, you don't want your final pass to be too small. If it's too small then there's not enough material to absorb the heat and cool the cutter head, possibly leading to the edge losing temper, becoming brittle, and ultimately winding up with a bunch of micro chips.
    Again, I'm not sure what's happening with your projects, but those are just two common issues that come up.
  10. Mar 10, 2020 at 8:26 AM
    #4930
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    use quality bits, also clean the bits with mineral spirits when using pine, the sap can gum up your bit...thats all i got in addition to whats been said
  11. Mar 10, 2020 at 8:42 AM
    #4931
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    On those notes; I always hit them with a brass brush after use and run the flat edges with a diamond file real quick. Keeps them ready for the next use.
    GunBunny12 and wilcam47[QUOTED] like this.
  12. Mar 10, 2020 at 10:25 AM
    #4932
    elgringoloco
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
    Sounds expensive haha.
  13. Mar 10, 2020 at 10:57 AM
    #4933
    98tacoma27
    Ben
    Not Beech Creek
    It pays off in secondary work you won't need to perform though.
    For instance...straight blade versus spiral template bits with regards to end grain. The spiral bits are more expensive but they won't grab and split end grain like a straight blade bit will.
    I was using a straight blade template bit for routing a chair arm. The bit grabbed the end grain, split the arm, and bent the shaft of the router. Not only did I have to remake the piece, but I was out a router. Good thing it was a cheap Skill router.
  14. Mar 10, 2020 at 11:09 AM
    #4934
    elgringoloco
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
    Funny you mention spiral bits- I actually just ordered one a few weeks ago. Looking forward to a project that I'll need it.
    98tacoma27[QUOTED] likes this.
  15. Mar 10, 2020 at 11:10 AM
    #4935
    wilcam47
    Will
    Bourbon state
    i learned the hard way, it really does help when you have quality bits vs harbor freight bits...
  16. Mar 10, 2020 at 11:13 AM
    #4936
    GunBunny12
    SE PA
    It's a world of difference, isn't it?! "Damn, this wood is tough!" "Holy crap, it's like butter!"
  17. Mar 10, 2020 at 11:18 AM
    #4937
    elgringoloco
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
    So then, what's everyone's opinion of Freud bits? I've had good luck with them(so far), and they're not terribly expensive.
    98tacoma27 and CXYyuppie like this.
  18. Mar 10, 2020 at 11:29 AM
    #4938
    wilcam47
    Will
    Bourbon state
    Or why is this ripping out?? Its pine...put new quality bit on, dang i dont even need to sand this.....
  19. Mar 10, 2020 at 11:33 AM
    #4939
    GunBunny12
    SE PA
    I'm a big fan of Freud. Maybe because they almost employed me, but I think has more to do with the quality of their tools. It's about the only router bit I buy anymore. I'm sure there are better ones out there, but as you said, Freud isn't terribly expensive.
  20. Mar 10, 2020 at 12:21 PM
    #4940
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    90% of my router bits are Freud , good value IMO
    robssol, jwctaco, RedTacoATX and 3 others like this.
