Any woodworkers?
Discussion in 'Garage / Workshop' started by Forster46, Mar 31, 2013.
  1. May 23, 2020 at 5:41 PM
    #5341
    TheCochese
    TheCochese The Bronze T4R OG
    Attempting to flee the south
    Cavalry Blue soccer machine
    Fine corinthian leather
    This does not spark joy.
    This does.
    Malvolio, wilcam47 and Fargo Taco like this.
  2. May 24, 2020 at 1:26 PM
    #5342
    Championsumo
    Championsumo Well-Known Member
    Tulsa, OK
    2015 DCSB 4X4 TRD Sport
    The flip cart kingdom is complete! Next up Paulk workbench.
    1887CBB9-E019-402D-9FF8-7D5612818C84.jpg 4F7C9ECB-9F0A-4CC5-976E-04FCF5121822.jpg DD97C25E-3CBE-4F4D-9564-E288EA5D76E1.jpg C59EBB78-9490-4B95-8F53-7C6147EA1F16.jpg
    Malvolio, Taco Buggy, OZ-T and 4 others like this.
  3. May 24, 2020 at 1:39 PM
    #5343
    TheCochese
    I'm trying this TSO square and parallel guide on this project and it is not going well. The square is off by around 1/8" or so over 53", and the parallel guides aren't giving me parallel pieces. I thought it might be the plywood I bought is that shit (even though I'm burning edges), but I did a five cut test and it's out on a ratio of .0011-something. I know .001 is square, but it just doesn't feel accurate enough. I'm constantly second guessing the cut that is off by my measuring tape and my Woodpeckers stuff.
    Ugh.
    23Skidoo and wilcam47 like this.
  4. May 24, 2020 at 2:07 PM
    #5344
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    What are yoi trying to square?
  5. May 24, 2020 at 2:44 PM
    #5345
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    I just spent a small fortune on trying to get my track saw to cut repeatable square and parallel cuts.
    The woodpecker parallel guide was hard to buy, but I had a $200 Amazon gift card.
    Almost went with the Seneca one that’s supposed to be pretty good for a lot less.
    TK-422, truchador and wilcam47 like this.
  6. May 24, 2020 at 5:03 PM
    #5346
    Championsumo
    Tulsa, OK
    Whipped up some 1/4” templates for a Paulk workbench, going to try my hand at template routing. I’m doing the compact version, if you haven’t seen it it’s pretty interesting. https://www.youtube.com/watch?v=ndRQBuVM3XY
  7. May 24, 2020 at 5:13 PM
    #5347
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    Just for you.
  8. May 24, 2020 at 5:47 PM
    #5348
    TheCochese
    Plywood pieces. I got a bit better as I went along, but I was having a tendency to push the back of the cut wide by 1/16-1/8" from the front. I'm too tired to fully explain at the moment, but yeah.
    Started to get the trick and was getting the occasional square piece. This tells me it's my technique.
    Drawer/shelf holes and dados tomorrow, we'll see how frustrated I get working outside on this POS Centipede or in my too-small shop if I get these installed tomorrow or it waits until next weekend.
    wilcam47[QUOTED] and 23Skidoo like this.
  9. May 25, 2020 at 7:56 AM
    #5349
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    interesting , I would contact TSO , I have the same square and no issues
    wilcam47 likes this.
  10. May 25, 2020 at 7:57 AM
    #5350
    OZ-T
    Peter North
    British Columbia
    you can clamp TSO square with Festool style clamps
  11. May 25, 2020 at 8:06 AM
    #5351
    OZ-T
    Peter North
    British Columbia
    FYI , when using the TSO rail square on a guide rail , the method I learned from Dave Stanton on youtube is to register the square against the plywood edge and then flick up the guide rail to release any tension on the grip tape so it lays back down correctly
    https://youtu.be/83H3V49Zk84
    Bigdaddy4760 and wilcam47 like this.
  12. May 25, 2020 at 8:37 AM
    #5352
    TheCochese
    That's the exact method I was doing, and my rail wasn't lining up with the marks I made - before I even made the cut. Consistent 1/16-1/8" off at the end. I did the five cut test yesterday and again this morning, and after careful positioning of the piece I ended up with 1mm over 250mm, which translates to an error of .001. That's supposedly a square square. When this project is done, I'm going to do some more experimenting to see why things aren't as they should be. The panels for this project were mostly fine, but I decided to butt joint instead of dado because I didn't want the slides to bind or come loose with that kind of variance front to back.
    Some panels were bang on, so I'm thinking I made errors at the beginning of each panel and they may have compounded. I burned an edge, squared up off that fresh cut...didn't seem to make a difference.
    OZ-T[QUOTED] and wilcam47 like this.
  13. May 25, 2020 at 8:51 AM
    #5353
    wilcam47
    Will
    Bourbon state
    Sounds like its slipping. Or maybe loose? Can you clamp the opposite end?
  14. May 25, 2020 at 9:14 AM
    #5354
    TheCochese
    The alignment error is happening before I even get to that point. I'm registering the square against the work piece with the rail tilted, and then I'm just tilting the rail down to contact the work piece.
    wilcam47[QUOTED] likes this.
  15. May 25, 2020 at 12:25 PM
    #5355
    OZ-T
    Peter North
    British Columbia
  16. May 25, 2020 at 1:23 PM
    #5356
    Championsumo
    Tulsa, OK
    No I used a router table for the straight cuts and free handed the roundy bits. Turned out pretty good. I Cut them out with my Milwaukee compact router with a template guide. I modified the plans a bit to add an extra stretcher since I’m only using half inch on the top and bottom, and left a spot for a bench vise. DB581FE7-DD45-4D78-9C38-39CB25762F1C.jpg
    OZ-T[QUOTED] likes this.
  17. May 25, 2020 at 7:46 PM
    #5357
    TheCochese
    So, the remodel is going well...
    Malvolio, jmess82, Fargo Taco and 4 others like this.
  18. May 26, 2020 at 1:01 PM
    #5358
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    We are extending our laundry room into the garage about 4' will have a folding table and cabinet against the 6' wall here and I framed that side with 2x8s son I could use the exposed back side to make some shelves for the garage side, and we got some lauan ripped down to 8" strips we are going to use for faux shiplap.
  19. May 26, 2020 at 1:08 PM
    #5359
    wilcam47
    Will
    Bourbon state
    Dual purpose! Great
    yota243[QUOTED] likes this.
  20. May 26, 2020 at 1:09 PM
    #5360
    98tacoma27
    Ben
    Not Beech Creek
    What's going on with the two sets of studs on the right that look hodge-podged together?
