Any woodworkers?
Discussion in 'Garage / Workshop' started by Forster46, Mar 31, 2013.
  1. Jan 15, 2022 at 4:28 PM
    #8381
    Kilo Charlie
    Kilo Charlie One flat foot on the Devil's wing
    Iowa
    2017 Inferno Off Road
    My RAS is just in my way. I'll never use it but since I have the cabinet under mine, I've thought about repurposing the cabinet for another tool.
    woodtickgreg likes this.
  2. Jan 16, 2022 at 3:10 PM
    #8382
    brow
    brow Well-Known Member
    Andy
    Minnesota
    2020 Dodge Ram 1500
    It may not look like much progress, but there’s been about 25 hours worth of work done since my last update. All hard edges have been planed down, some with the spokeshave and hand plane, both the bow and stern mostly by hand with chisels, Since the curvature won’t let a plane sit flush. Found 4 broken staples that I missed when pulling all 1500 of them. Those really mess up your planes cutting edge. Ouch.
    Now I’m just playing games with the weather, no dust collection in the garage so I need to wheel it outside in the driveway when I want to sand. And between the snow and negative temps, Minnesota has not been cooperating.
  3. Jan 16, 2022 at 3:16 PM
    #8383
    brow
    Andy
    Minnesota
    2020 Dodge Ram 1500
    Also got an old craftsman 6-1/4 jointer that my dad wanted out if his garage. He’s a retired carpenter but still does things he considers fun for friends. Got it in trade but doesn’t need another one. Motor is good, blades all look decent. Need a new belt and then I’ll see how the bearings sound in it. It honestly looks like it’s been used 5 times in its life.
  4. Jan 21, 2022 at 5:48 PM
    #8384
    gasparic104
    gasparic104 Trusty Spotter
    Cayleigh
    Instagram: @NotSo_JDM
    2015 Tacoma TRD Sport DCLB; 21 & 03 Corolla
    Working on desks for @Slashaar and I; working with this beautiful beech
    Taking a break for a bit while doing shop drop stuff. I'm currently at 300 grit sandpaper, so I'll be clearing off the remaining dust in a bit. Just cleaning up toolmarks from the router etc
    I'm really dizy, I hope that makes sense, lol.
  5. Jan 21, 2022 at 5:51 PM
    #8385
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    will look awesome when done
    I have the same saw horses, they work great
    gasparic104[QUOTED] likes this.
  6. Jan 21, 2022 at 6:16 PM
    #8386
    gasparic104
    Cayleigh
    I broke one of them immediately :anonymous:
    @Slashaar said he wants to straight up return them, I figured we would just exchange them and I could maybe not scoot it across the slopped driveway with a butcher block countertop on it next time
    Slashaar and wilcam47[QUOTED] like this.
  7. Jan 21, 2022 at 6:18 PM
    #8387
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    I just want some nice metal ones....
    https://www.homedepot.com/p/TOUGHBU...le-1300-lb-Capacity-TB-C700/205870356#overlay
    and these would be nice for outfeed on the table saw :anonymous:
    https://www.homedepot.com/p/TOUGHBUILT-43-in-3-in-1-Roller-Stand-with-Triple-Function-TB-S210/
    Kilo Charlie and wilcam47 like this.
  8. Jan 21, 2022 at 6:20 PM
    #8388
    wilcam47
    Will
    Bourbon state
    Till you hit one of them with circular saw...:anonymous:
    Slashaar[QUOTED] likes this.
  9. Jan 21, 2022 at 6:23 PM
    #8389
    Slashaar
    Josh
    Kansas City, MO
    :bananadead:
    wilcam47[QUOTED] likes this.
  10. Jan 21, 2022 at 8:16 PM
    #8390
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    Ouch!
    wilcam47[QUOTED] and Slashaar like this.
  11. Jan 22, 2022 at 8:48 AM
    #8391
    Kilo Charlie
    Iowa
    You can get metal saw horses with 2x4 tops .. the wood can be replaced as needed.
    My next replacements will have a groove routered in then for my Micro Jig clamps.
    98tacoma27 and Slashaar like this.
  12. Jan 22, 2022 at 10:20 AM
    #8392
    tomwilson74
    tomwilson74 Well-Known Member
    Tom
    West Virginia
    2020 TRD double cab OR
    OME 3” lift Mickey Thompson Classic III Wheels
    Getting all the pieces together to put a router table in the wing of my table saw. Is there anything I can do to the laminate top to keep from getting any tear out or chipping when I’m routing the hole for the router plate??
  13. Jan 22, 2022 at 11:00 AM
    #8393
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I've never had a problem with tearout. Use a sharp router bit. When I am finished, I usually hit the cut edge with some sandpaper - the laminate edge can be sharp enough to cut.
    I am assuming you have the laminate glued down to something.
    I have cut laminate by itself (smaller, but still oversized pieces) using aviation shears. Unfortunately, I never get a clean edge.
  14. Jan 22, 2022 at 11:09 AM
    #8394
    Slashaar
    Josh
    Kansas City, MO
    You got a link for ones like that? That sounds perfect.
  15. Jan 22, 2022 at 11:20 AM
    #8395
    tomwilson74
    Tom
    West Virginia
    It’s 1 1/4” MDF with a laminated top from Rockler.
  16. Jan 22, 2022 at 11:32 AM
    #8396
    RugglesTarlek
    RugglesTarlek Well-Known Member
    California
    basic basic basic 14 AC
    I doubt you'll have a problem with laminate, but my universal advice is (1) test on scraps and (2) sneak up on the cut -- small depth or width increments.
    tomwilson74[QUOTED] likes this.
  17. Jan 22, 2022 at 1:12 PM
    #8397
    Pixeltim
    '15 Black DCLB SR5
    What are you making it out of?
    I did mine by gluing two layers of MDF together. It's very stable, and routing out the plate hole was simple. btw, I still have the template for that if you need, and if you ever get to Madison...
  18. Jan 22, 2022 at 1:52 PM
    #8398
    Kilo Charlie
    Iowa
    Mine are Craftsman but here's a photo of a set almost identical.
    Slashaar[QUOTED] and wilcam47 like this.
  19. Jan 22, 2022 at 2:08 PM
    #8399
    tomwilson74
    Tom
    West Virginia
    It’s from Rockler already has the laminate on it, total about 1 1/4” thick. I have the template from the plate I had in my old table. I’m putting a jessem lift in this one and it’s about 3/4” different in size. Bought another template, cost $30.
    wilcam47 likes this.
  20. Jan 22, 2022 at 2:16 PM
    #8400
    Pixeltim
    '15 Black DCLB SR5
    Yeah, I put in a jessem lift, I love it!
    Spunky and tomwilson74[QUOTED] like this.
