Any woodworkers?
Discussion in 'Garage / Workshop' started by Forster46, Mar 31, 2013.
  1. Feb 19, 2022 at 1:35 PM
    #8621
    RTweet
    RTweet Well-Known Member
    Oregon
    2021 White TRD Pro, MT
    wilcam47 likes this.
  2. Feb 19, 2022 at 1:37 PM
    #8622
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    does that affect depth of cut?
  3. Feb 19, 2022 at 1:40 PM
    #8623
    RTweet
    Oregon
    I imagine that depends on the table saw. You’re supposed to get one ½ to 2/3 the blade diameter. I don’t use one and my work relies in precision (though, I’m not as anal because I’m comfortable tuning up with hand planes). I get by on a combo Freud and a ripping Freud, both thin kerf.
    wilcam47[QUOTED] likes this.
  4. Feb 19, 2022 at 1:41 PM
    #8624
    wilcam47
    Will
    Bourbon state
    Im mostly doing rip cuts..
  5. Feb 19, 2022 at 1:44 PM
    #8625
    RTweet
    Oregon
    How thick?
  6. Feb 19, 2022 at 1:50 PM
    #8626
    wilcam47
    Will
    Bourbon state
    Maybe 2in max
  7. Feb 19, 2022 at 1:53 PM
    #8627
    RTweet
    Oregon
    Well, you’re kind of between both worlds with that. A thicker blade will be more precise and less prone to deflection/overheating. If your table saw is under 3HP, however, the thin will fly through it vs the thick.
  8. Feb 19, 2022 at 6:45 PM
    #8628
    98tacoma27
    Ben
    Not Beech Creek
    If it's burning then the blade is dull or dirty or it could just be the wood. I'm looking at you cherry and maple.
    If the motor is getting tired then it is underrated for the application or its a shitty motor.
    Thin kerfs are no more than .030“ less than a full kerf. I'd hardly call that a waste material.
  9. Feb 19, 2022 at 7:01 PM
    #8629
    916carl
    916carl Well-Known Member
    Carl
    2008 DCSB TRD Sport SR5
    Anybody work with pine? While I'm waiting for the danish oil to dry and cure in my walnut box I decided to do something with the test/prototype one I built first, out of pine. I don't particularly like pine, and since it's a test box with a fair amount of flaws and ooops, I'm going to try a walnut gel stain.
    I took some zinsser clear, un-waxed shellac and cut it 50/50 with denatured alcohol, then put on 2 coats. Tomorrow I'll very lightly sand it then wipe gel stain. My hope is the shellac will prevent blotching. Maybe I should do another shellac coat before... the pine really soaked it up.
  10. Feb 19, 2022 at 7:05 PM
    #8630
    wilcam47
    Will
    Bourbon state
    Its a bit finiky, and prone to warping. I used wood conditioner but it kinda gave it a color i didnt like so i used a darker stain
    916carl[QUOTED] likes this.
  11. Feb 19, 2022 at 8:53 PM
    #8631
    RTweet
    Oregon
    Point I made later in the convo. Burn will happen if feed rate is too slow, too (something that could also happen with an underpowered TS). Otherwise, you can burn with any blade. If you’re ripping thin stock, that adds up quickly.
  12. Feb 20, 2022 at 2:38 AM
    #8632
    98tacoma27
    Ben
    Not Beech Creek
    Use a conditioner first before stain. That keeps the pine from blotching. I'm not sure it's going to take stain now that you put shellac on it. I'm interested to see the results.
  13. Feb 20, 2022 at 9:46 AM
    #8633
    916carl
    Carl
    The idea I had (not really mine but from tons of internet searching) is the gel stain is a surface application of color. So seal the wood first, apply the gel stain, then cover it with some protection. I have wood conditioner but have read mixed results using it on pine. I've read of success with shellac.
    Toyoda213 and wilcam47 like this.
  14. Feb 20, 2022 at 9:48 AM
    #8634
    98tacoma27
    Ben
    Not Beech Creek
    Interesting. I've never used the gel before.
  15. Feb 20, 2022 at 10:49 AM
    #8635
    916carl
    Carl
    I've got some poplar on a step stool to finish and I would like to make it darker, as the other parts are walnut. I don't like the contrast of nearly white poplar to the warm tones of walnut. Hence my research into blotch control. One of the recent finds is a product from Charles Neal that seems to have a lot of success (reading about it on different forums and sites).
    https://thewoodwhisperer.com/articles/blotch-control-to-rule-them-all/
    Not sure how far I want to go down this rabbit hole, so I haven't purchased it yet. So easy to get carried away with different products and methods.
  16. Feb 20, 2022 at 10:59 AM
    #8636
    wilcam47
    Will
    Bourbon state
    Anyone gonna try this? Im thinking about it, you have to get a membership then dowload his template.
  17. Feb 20, 2022 at 3:20 PM
    #8637
    wilcam47
    Will
    Bourbon state
    Finally dug out a wood sliver out of my hand, i couldnt see it but it wasnt healing up, so i knew it was there. Scraped some of the callus off and pinched and it popped out. Part of woodworking i guess.:annoyed:
  18. Feb 20, 2022 at 6:12 PM
    #8638
    Farcedude
    Farcedude Well-Known Member
    Greg
    Westminster, CO
    ‘23 MGM DCSB OR
    Oof yeah those suck. I finally got tired of walking in the house to dig out splinters, and mounted one of these (screw through the end cap hole) to my rack of wood screws, so it’s in the garage and I always know where it is:
    https://www.rockler.com/uncle-bills...75LGzIssME6u97rDGA3d9c9wwgpcNMnRoC5hIQAvD_BwE
    916carl and wilcam47[QUOTED] like this.
  19. Feb 20, 2022 at 6:16 PM
    #8639
    wilcam47
    Will
    Bourbon state
    Cool ill have to get one, yeah i couldnt even see a piece to pull the sliver out. Been in my hand at least 2 weeks
  20. Feb 20, 2022 at 6:28 PM
    #8640
    Farcedude
    Greg
    Westminster, CO
    ‘23 MGM DCSB OR
    They’re worth the price, I’d say get a 3 pack so you can have on in a first aid kit too
