Any woodworkers?
Discussion in 'Garage / Workshop' started by Forster46, Mar 31, 2013.
  1. Jan 24, 2024 at 4:50 PM
    woodtickgreg
    woodtickgreg Well-Known Member
    Greg
    Michigan
    But on a better note, 3 legs are done.
    Only 2 more mortices to clean out on 1 leg.
    Once the mortices are done I'll move on to tennons and fitting them.
  2. Jan 24, 2024 at 5:18 PM
    ndoldman59
    ndoldman59 Well-Known Member
    Murray
    West Fargo, ND
    2021 magnetic silver SR5 DCSB V6
    Made these for my wife. She collects butterfly stuff.
  3. Jan 24, 2024 at 5:42 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Farcedude and Malvolio like this.
  4. Jan 24, 2024 at 5:47 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Metal dust for me :anonymous:
  5. Jan 24, 2024 at 5:49 PM
    RichochetRabbit
    You were supposed to say ... "Do not ask me how I know".
    wilcam47[QUOTED] likes this.
  6. Jan 24, 2024 at 5:56 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    :rofl::rofl::fistbump:
  7. Jan 24, 2024 at 6:11 PM
    RichochetRabbit
    This is something I accomplished several years ago. I had allowed the shower-head to drip on the water-control handle but finally needed to remove it. The ionized-calcified crud filled the tiny screw hole.
    While my accomplishment is small-time compared to some ... I broke a titanium-coated 7/32 drill bit getting that <bleep> off.
  8. Jan 26, 2024 at 7:13 PM
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    Here’s his final build. And today I tossed together a whale of an Outlaw Class car to run with all the other freaks.
  9. Jan 27, 2024 at 3:03 PM
    woodtickgreg
    Greg
    Michigan
    Mortices are done on the legs.
    Once I started chopping I kinda fell into a rythem and it went pretty smoothly. Narex morticing chisels work great. I just used the bench chisels for smoothing and fine tuning.
    Next it was time to trim one end smooth of the cross members. Layed out some lines.20240127_163239.jpg
    Cut....flip...cut.
    Matched up pretty good for a 6" timber.
  10. Jan 27, 2024 at 3:10 PM
    woodtickgreg
    Greg
    Michigan
    Next I cut the cross members to length.
    Easy peasy......
    Now all the cross members are cut to length, next I'll be forming the tennons. I'll. Make them a bit oversize so I can trim them to fit.
    Man I'm having fun on this build, isn't that what it's really all about? I don't do wood working for money, it's not a job, it's for fun. And this one is for me.
    ricphoto, Fargo Taco, kent50 and 6 others like this.
  11. Jan 27, 2024 at 3:29 PM
    DoubleB
    DoubleB Well-Known Member
    Bakersfield CA
    22 TRD Pro / 06 PreRunner
    Designing and making an oval side table to go with the chairs.
    Drew out my stencil
    1/4” MDF template
    Pieces rough cut to length and planed to thickness.
    Top panel glued up.
    Leg pieces layed out.
    Time for a break and a cold beverage.
    Kwikvette, Fargo Taco, kent50 and 5 others like this.
  12. Jan 27, 2024 at 3:30 PM
    woodtickgreg
    Greg
    Michigan
    That's going to be cool.
    wilcam47 and Malvolio like this.
  13. Jan 28, 2024 at 5:38 PM
    woodtickgreg
    Greg
    Michigan
    I need a tennoning jig for the next steps of my workbench build so I made one today. I kept this one very simple compared to others I have made or seen. Sometimes the K.I.S.S. works the best. I also just used scrap wood so there is no cost, and screws I already had in the shop.
    Started with a piece of 3/4" plywood and a scrap of 1" walnut. Cut a rabbet in the walnut to straddle part of my saws high low fence.20240128_184723.jpg
    It fits snug but still moves easy on the fence.
    Next I screwed the back part of the jig fence on.
    And I attached a top brace to hold everything square when in use.
    I made sure everything was square as I put it together.
    then I made an outrigger to straddle the saw fence and help stabilize the jig.
    Now the jig can just lift off or drop on when needed and not interfere with the saw fence. Adjustments for the cuts can be made with the saw fence. You just use a quick grip clamp to hold the stock and push it through the saw blade and just cut through the plywood on the first cut.
    jbciv, wilcam47, Fargo Taco and 4 others like this.
  14. Jan 28, 2024 at 6:21 PM
    DoubleB
    Bakersfield CA
    Very Cool!
    I made it this far today. Still need to final sand, attach the top (simple pocket holes), and finish.
    airmax233, jbciv, wilcam47 and 6 others like this.
  15. Jan 29, 2024 at 1:56 AM
    woodtickgreg
    Greg
    Michigan
    That's going to compliment the chairs nicely.
  16. Jan 30, 2024 at 7:40 AM
    jbciv
    jbciv Well-Known Member
    2023 Tacoma TRD Off-Road
    man, i had some catching up to do! nice seeing the workbench updates and those chairs are cool too.
  17. Jan 30, 2024 at 8:52 AM
    Malvolio
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    Woodworking folks, any tips on making a bar stool?
    We have two of the stools pictured, and my wife wants a third. They aren’t made anymore, though it’s a common design with lots of slight variations.
    I’ve got a table saw, sliding chop saw, a router, and the normal clamps and chisels. The faint seat buttprint recess and the curves of the legs seem like the most challenging part. . (Obviously they’ll all need a fresh coat of paint too!)
    Is it time to get into drawknives? I figured I can take one apart and get pretty close with the tools I have. Thanks for any tips.
    ndoldman59 and wilcam47 like this.
  18. Jan 30, 2024 at 8:55 AM
    wilcam47
    Will
    Bourbon state
    Id use a grinder with a sanding disc to get the buttprint indention, then sand as normal. Looks like tenons on other parts.
    ndoldman59 and Malvolio[QUOTED] like this.
  19. Jan 30, 2024 at 9:25 AM
    jbciv
    do ya happen to have a jigsaw or bandsaw?
    wilcam47 likes this.
  20. Jan 30, 2024 at 9:44 AM
    wilcam47
    Will
    Bourbon state
    Belt sander would work too
    jbciv[QUOTED] likes this.
