Any woodworkers?
Discussion in 'Garage / Workshop' started by Forster46, Mar 31, 2013.
  1. Nov 28, 2017 at 9:04 AM
    #1481
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    maybe you can file the mating surfaces, there should be a place where both touch. You might have to take it apart but it would be worth it. I dont know if yours has it but mine has the detents but also has a lockdown where you can tighten it down on whatever degree you want. I also check that with the speed square.
    jpneely[QUOTED] likes this.
  2. Nov 28, 2017 at 9:58 AM
    #1482
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    ill see if I cant file her down some. I actually had not thought of that. it would make life much better!
  3. Nov 28, 2017 at 10:03 AM
    #1483
    wilcam47
    Will
    Bourbon state
    I dont know which would be best to file on? The pivot or stationary part but I guess it wouldnt matter so long as you can get the 90degree.
  4. Nov 28, 2017 at 10:04 AM
    #1484
    jpneely
    Charleston, SC
    I'd probably try it on the sled side so that if I screw it up I can probably replace it easier. maybe. who knows.
    wilcam47[QUOTED] likes this.
  5. Nov 28, 2017 at 10:06 AM
    #1485
    wilcam47
    Will
    Bourbon state
    thats what shims are for;)
  6. Nov 28, 2017 at 10:06 AM
    #1486
    jpneely
    Charleston, SC
    haha I guess youre right!
  7. Nov 28, 2017 at 11:03 AM
    #1487
    scocar
    scocar Patron of the Farts
    Don't your saws have an adjustment for the index? I just did a minitune on my Dewalt 12. A decent saw will allow you to fine tune the detents in some manner, likely by loosening screws holding the index to the base, then square up the blade with the deck and backstop, then tighten the index screws again.
  8. Nov 28, 2017 at 11:06 AM
    #1488
    jpneely
    Charleston, SC
    hmm reading back over my messages, I got off subject a little. I got back onto filing down mating surfaces on my circular saw. it only has a adjustment lever as far as Ive ever seen. the chop saws weren't mine so I wont be taking them apart to see. if I get one, ill definitely be checking it all out.
    wilcam47 likes this.
  9. Nov 28, 2017 at 11:28 AM
    #1489
    scocar
    I bought mine used from a floor installer for about half price of new. I spent time assessing it, and found a missing set screw under the clamp, replaced the damaged kerf plate, cleaned of various globs of adhesive, and went step by step through the manual for adjustment and tuning. Given all the moving parts, temperature changes, and moving them around, they will tend to continually get out of adjustment, so becoming accustomed to checking before every use and tuning as needed should be SOP. Even small pieces of wood ships and saw dust on the deck can screw your cut.
    Places like this offer most replacement parts you may need, if you are buying a used saw. You can also go to a manufacturer-specific warranty shop.
    https://www.fix.com/models/miter-saw/dewalt/id773609/dw706-type 1/section6573378/page-b/
  10. Nov 28, 2017 at 11:31 AM
    #1490
    jpneely
    Charleston, SC
    whenever I find one that looks like a good deal ill definitely read some manuals on it and figure it all out. I love tinkering so fine tuning is right up my alley haha.
    scocar[QUOTED] likes this.
  11. Nov 28, 2017 at 11:55 AM
    #1491
    jpneely
    Charleston, SC
    so back to that old plane that I found. does anyone know of another forum that they know has some knowledgeable people on old woodworking tools? I cannot for the life of me find another iron like the one on this plane.
  12. Nov 28, 2017 at 12:20 PM
    #1492
    98tacoma27
    Ben
    Not Beech Creek
  13. Nov 28, 2017 at 12:22 PM
    #1493
    jpneely
    Charleston, SC
  14. Nov 28, 2017 at 1:20 PM
    #1494
    krap22
    krap22 Well-Known Member
    There is a hand tools section over at woodnet.net
    They have some very knowledgeable people over there.
  15. Nov 28, 2017 at 1:20 PM
    #1495
    jpneely
    Charleston, SC
    ill check that one out too. gracias
  16. Nov 28, 2017 at 5:33 PM
    #1496
    wilcam47
    Will
    Bourbon state
    I'll have to look but mine is a basic single compound miter saw. I dont think I have adjustments...I could be wrong though as I havent looked at mine that deeply I just align mine with the speed square.
    https://www.lowes.com/projects/woodworking-and-crafts/compound-miter-saw-buying-guide/project
  17. Nov 29, 2017 at 3:46 AM
    #1497
    Rider4
    Rider4 Well-Known Member
    2017 Tacoma TRD PRO
    Yeah it is a very hardwood. It does finish nicely with work.
  18. Dec 1, 2017 at 5:06 AM
    #1498
    98tacoma27
    Ben
    Not Beech Creek
    Kolunatic likes this.
  19. Dec 1, 2017 at 5:13 AM
    #1499
    jpneely
    Charleston, SC
    That's an awesome site! ill be checking this out.
    wilcam47 and 98tacoma27 like this.
  20. Dec 4, 2017 at 7:42 AM
    #1500
    98tacoma27
    Ben
    Not Beech Creek
    This one is good till the 24th.
    $10 off a $25 order (code 12217) and free shipping on anything over $35 (excluding freight).
    https://www.woodcraft.com/
    wileyC likes this.
