Any woodworkers?
Discussion in 'Garage / Workshop' started by Forster46, Mar 31, 2013.
  1. Feb 7, 2018 at 8:56 AM
    #1841
    Toyko Joe
    Toyko Joe Here for the pictures
    dab of superglue?
    wilcam47[QUOTED] likes this.
  2. Feb 7, 2018 at 8:57 AM
    #1842
    98tacoma27
    Ben
    Not Beech Creek
    Nope, she hates you. Get her some catnip.
  3. Feb 7, 2018 at 9:00 AM
    #1843
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I thought of that but I may need to do an angle cut at some point. I just have to remember not to tip over when I take it off
    Toyko Joe[QUOTED] likes this.
  4. Feb 7, 2018 at 9:05 AM
    #1844
    Toyko Joe
  5. Feb 7, 2018 at 9:09 AM
    #1845
    wilcam47
    Will
    Bourbon state
    page 4. The positioning pin. Handle screws down and holds it in place but the position pin just sits in there. its fine if its flat but if you have to remove the miter to do a large cut you have the possibility of losing the positioning pin.
  6. Feb 7, 2018 at 9:13 AM
    #1846
    Toyko Joe
    Do you have a tap and die set? Add a heli-coil... :thumbsup:
    robssol and wilcam47[QUOTED] like this.
  7. Feb 7, 2018 at 9:14 AM
    #1847
    wilcam47
    Will
    Bourbon state
    that was the other option;) Right now I only use the 90 and 45 degree cut on table saw. But primarily the 90.
  8. Feb 7, 2018 at 9:18 AM
    #1848
    Toyko Joe
    I read your original post as as Kreg should done this to begin with... of which I agree.
    wilcam47[QUOTED] and scottalot like this.
  9. Feb 7, 2018 at 9:24 AM
    #1849
    island taco
    island taco Well-Known Member
    Vince
    victoria, canada
    White '23 LBDC TRDSport
    Kicker speakers, Key amp, Spiker hood struts, tonnueo cover, Cooper AT3 4s, Method Double Standard Bronze
  10. Feb 8, 2018 at 10:22 AM
    #1850
    wilcam47
    Will
    Bourbon state
    I think I solved the position pin falling out problem for now at least. I took a piece of plastic from a screw bag and stretched it over the pin and put it in the miter. Everyone knows when you are trying to rip a plastic bag it never does what you want but try to hold something in a bag and it rips instantly. So in this case I use the stretched bag to my advantage. It seemed to hold and not fall out but removes easily.
    scottalot likes this.
  11. Feb 8, 2018 at 10:38 AM
    #1851
    wilcam47
    Will
    Bourbon state
    also got the Harbor freight 6" disc sander for $59.99, a 25' air hose, and a couple small 10' tape measures and a free 25' tape tape measure. all for less than $79. originally listed for the the sander ;)
    Toyko Joe and Blackout14 like this.
  12. Feb 8, 2018 at 10:52 AM
    #1852
    wilcam47
    Will
    Bourbon state
    I saw this at home depot yesterday, also may be worth looking at. Around $8 just have to match to the color of your project. Id go with a lighter stain first then if it works go to a darker stain if thats what you like. It was in a can shaped like this said it covered water/heat stains etc. maybe try the back of the mirror see how it works.
    https://www.homedepot.com/p/Watco-1-pt-Dark-Walnut-350-VOC-Danish-Oil-265501/203164640
    scottalot[QUOTED] and Blackout14 like this.
  13. Feb 8, 2018 at 10:54 AM
    #1853
    wilcam47
    Will
    Bourbon state
    I put it together and its not real powerful but will work for what I need. I just need to light sand small pieces so this will work great and a great price ;)
    Blackout14 likes this.
  14. Feb 8, 2018 at 11:11 AM
    #1854
    98tacoma27
    Ben
    Not Beech Creek
    I've turned stuff down because of the space issue. :pout: :annoyed:
    scottalot, wilcam47 and Blackout14 like this.
  15. Feb 8, 2018 at 11:13 AM
    #1855
    wilcam47
    Will
    Bourbon state
    I'd prob start with a fine grit like 2000 go up from there 4000, 6000 etc.... You can find some in the automotive section in walmart. wipe down with a cloth when you start seeing "dust" come up from the piece. Dont use a lot of pressure. What you are looking for is more of a polish to blend rather than sanding if that makes sense.
    scottalot[QUOTED] likes this.
  16. Feb 8, 2018 at 11:14 AM
    #1856
    wilcam47
    Will
    Bourbon state
    just did that today...radial arm saw, cheap but I dont think Id use it that much and no room at the moment.
    98tacoma27[QUOTED] and scottalot like this.
  17. Feb 8, 2018 at 11:20 AM
    #1857
    wilcam47
    Will
    Bourbon state
    Piece like what you have is in decent condition, just needs some "lovin" in time rather than lots of money;) I think it will look really nice once you have a fresh/new stain you like on it. I know pics dont compare to seeing it in person.
  18. Feb 8, 2018 at 11:21 AM
    #1858
    wilcam47
    Will
    Bourbon state
    I had the opportunity to get a car lift years ago, but I didnt have the space for it :( I prob would have sold it later anyhow but still would be useful today ;)
    scottalot and Blackout14 like this.
  19. Feb 8, 2018 at 11:28 AM
    #1859
    wilcam47
    Will
    Bourbon state
    Looks decent...I got my Jet table saw about half price of new. Same situation...the guy only used it once and had it in storage. I used it more in the first month than the guy ever did. It had been in storage for 10 yrs...lol
  20. Feb 8, 2018 at 12:45 PM
    #1860
    PintSize
    PintSize Crossthreaded & torqued down
    Texas
    2011 2.7L 5 spd RC 4x4
    Basswood isn’t bad to dovetail with. It’s good to use as a backer board when your making multiple pieces of the same size to cut tails repeatedly...
