any write ups on how to...
Discussion in '1st Gen. Tacomas (1995-2004)' started by fireturk41, Jul 3, 2009.
  1. Jul 3, 2009 at 1:32 PM
    fireturk41
    fireturk41 [OP] I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    are there any write ups on how to change the timing belt, change differential fluid, change transfer case fluid, power steering fluid . i took it to the dealer to fix my drain plug prollem and got a whole list of things that need to be changed or replaced, it caught my eye that my tranny fluid was one of the things, i changed it not 1k miles ago so i wantr to service it myself, are there any write ups on how to use these
  2. Jul 3, 2009 at 1:35 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Changing Diff Fluid By Brian
    I wanna say The Transmission and Transfer case are the same as the diffs. Drain them then use the fill plug until it over flows.
  3. Jul 3, 2009 at 1:38 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
  4. Jul 4, 2009 at 11:24 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    is it ok to use synthetic gear oil if the transfer case and differential fluid has never been changed in 213k miles?
    also how do you change the transfer case fluid
  5. Jul 4, 2009 at 6:20 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    i drained and filled mine with semi synthetic fluid at 126K, no problems:D
    Transfer case..drain and fill.
  6. Jul 5, 2009 at 1:34 PM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    IF you have an automatic tranny you don't want to fill it like you do your diffs and t-case. Fill it like you do your engine oil with the right amount not just until it starts coming out.
    I read Luk's post and he may have been talking about the diffs or a Manuel tranny but I just wanted to make sure.
  7. Jul 6, 2009 at 4:18 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
