Any write ups on replacing carrier bearing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SoCal Hillbilly, Aug 17, 2015.
  1. Feb 10, 2016 at 7:59 PM
    tan-ishman
    tan-ishman Well-Known Member
    San Diego,CA
    2005 DCSB
    a bunch of new/used parts....and some skids.
    when you say "new U-joint", do you mean carrier bearing?
  2. Feb 11, 2016 at 1:13 PM
    SoCal Hillbilly
    SoCal Hillbilly [OP] Well-Known Member
    Eric
    San Diego
    2013 DCSB
    No, they are totally different. I think Toyota may call them spider gears in the manual.
    https://www.youtube.com/watch?v=rOEdul7nscY
  3. Feb 11, 2016 at 1:17 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I just did the what they call "center bearing" I figured I may as well do the U-joints since I have to take off the driveline anyhow. But any ways its not an awful job.
  4. Feb 11, 2016 at 1:19 PM
    SoCal Hillbilly
    Eric
    San Diego
    2013 DCSB
    I did the same thing but only because I was tired of servicing them. Went with the sealed type.
  5. Feb 11, 2016 at 4:58 PM
    wilcam47
    Will
    Bourbon state
    Mine isnt a daily driver so I opted for the grease-able Ujoints..
  6. Feb 11, 2016 at 5:21 PM
    whiskeyMIKE
    whiskeyMIKE Member
    Vancouver, BC
    09 DCSB SR5
    Icon stage 3 suspension, abs kill switch mod.
    I just did my center bearing last weekend. Super easy job with minimal tools. I would recommend a 2 arm puller with a decent reach on it to get the bearing off. When you install your new bearing make sure you have it on the right way and then I believe the torque to set the bearing is 153 ft lbs then you back it off and re torque to 51 ft lbs.
    www.customtacos.com/tech.old/files/05FSM/repair.html
    This site has most if not all your specs and some good pics. I used it to do my release bearing, clutch, flywheel, and center bearing.
  7. Feb 11, 2016 at 6:06 PM
    wilcam47
    Will
    Bourbon state
    Mine was so roached out It just fell off....went on easy, I had more trouble taking out the U-joints than anything else...
  8. Feb 11, 2016 at 10:38 PM
    Navar
    Navar Well-Known Member
    Corona CA
    07 Tacoma TRD Sport 4x4
    Washed it, Icon suspension, Icon UCA
    Should there be any play in the carrier bearing? None or a little?
  9. Feb 12, 2016 at 6:57 AM
    tan-ishman
    San Diego,CA
    2005 DCSB
    So you suggest that if I'm going to do the carrier bearing I should also do the U joints?
    I didn't see any play in the U joints so I was thinking of just doing the bearing and seeing how it goes after that. Thoughts?
  10. Feb 12, 2016 at 7:17 AM
    tan-ishman
    San Diego,CA
    2005 DCSB
    I'll make a write up when I do my work in 2 weeks. Waiting for the parts to arrive and headed to my buddies heated garage.
  11. Feb 12, 2016 at 8:13 AM
    SoCal Hillbilly
    Eric
    San Diego
    2013 DCSB
    You have to remove one in order to get to the nut that holds the yoke on; then you can remove the carrier. You can reuse the old u-joint but if you mess it up removing it be prepared to replace it.
  12. Feb 12, 2016 at 12:08 PM
    tan-ishman
    San Diego,CA
    2005 DCSB
    now that is good advice! I'll just go ahead and buy 3 u Joints then, pretty cheap at $15 each.
    sorry to jack your thread man. I'll try my best to pay back with a write up.
  13. Feb 12, 2016 at 2:40 PM
    SoCal Hillbilly
    Eric
    San Diego
    2013 DCSB
    Just double check those part numbers. Theres nothing like getting half way into the project only to see you have the wrong parts.
    Good luck
    tan-ishman[QUOTED] likes this.
  14. Feb 12, 2016 at 6:11 PM
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    It's a Tacoma, it has driveline shudder straight outta the factory.
    Stryker420 likes this.
  15. Mar 9, 2016 at 7:36 AM
    #35
    tan-ishman
    San Diego,CA
    2005 DCSB
    So I got under my truck and looked at the carrier bearing. Looks brand new... I couldn t find any play in the drive shaft either. I'm going to do some other work tomorrow but I'll grease up my zerks while I'm under there. If this fixes the problem I'll let y'all know. Ended up buying like 800$ in other parts.
  16. Aug 2, 2016 at 7:36 AM
    #36
    TheSupremeReader
    TheSupremeReader Well-Known Member
    Andrew
    TRD OR DCSB
    So I went to my Toyota dealer to get the yoke nut and I am told that its not a serviceable yoke and that I would need to be an entire drive shaft for that nut...anyone who has done it have a part number for the yoke nut?
  17. Aug 2, 2016 at 8:59 AM
    #37
    SoCal Hillbilly
    Eric
    San Diego
    2013 DCSB
    If you can get the part number off your drive shaft, Spicer will have the part number. You may also be able to just give the year, make and model of your truck. Then use their distributors to get it. It will be much less than dealer prices.
  18. Feb 21, 2017 at 1:01 PM
    #38
    hillbillytoyo
    hillbillytoyo Well-Known Member
    Daniel
    WV
    17 Tundra Crewmax SR5 TRD Off Road.
    G2 bed cover
    Sub'd for reference
  19. Sep 28, 2018 at 8:16 PM
    #39
    Kevinkiger16
    Kevinkiger16 Active Member
    Kevin
    2007 tacoma 2.7 manual
    I know this is a old post but I’m doing my carrier bearing on my 07 tacoma and can’t get the yolk off I’ve tried a press anti seize I’ve beat it as much as I can without mushrooming the bolt any tips??
  20. Sep 29, 2018 at 8:48 AM
    #40
    trdNick
    trdNick Odie
    Texas
    2020 Ram 1500 4x4 5.7 Hemi BigHorn
    You need a jaw puller to remove the yolk. Put the center of the puller on the center of the threaded portion of the shaft
