any "X" style 4 spoke wheels for 2nd gen?
Discussion in 'Wheels & Tires' started by builthatch, Dec 19, 2010.
  1. Dec 19, 2010 at 2:59 PM
    builthatch
    builthatch [OP] MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    i really like this Nissan wheel but bolt pattern won't work.
    anything else out there with 4 spokes that'll fit?
    6x5.5" bolt pattern.
    thanks.
  2. Dec 19, 2010 at 3:06 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    I thought nissans were also 6 on 5.5, no?
  3. Dec 19, 2010 at 3:08 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    as far as i've found late model are 6 x 4.5, but i can't be 100% sure. i'm like 95% sure ; )
    i just realized i might be able to run adapters but i'll have to really look around because the hub bore would have to be 108mm.
    EDIT: so the 00-04 are 6 x 5.5 - i need to see if they did that wheel back then.
  4. Dec 19, 2010 at 3:14 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    well, since you made me look, hehe, i found out too that the 00-04 had 108mm bores ALONG with the 6x5.5
    and they also had an X style wheel!
    16", not 17" like the later models, but whatever.
    and
  5. Dec 19, 2010 at 3:20 PM
    KPT
    09 Prerunner
    Sweet, just make sure the backspacing is between 4.5 and 5.5" and you are good to go.
  6. Dec 19, 2010 at 3:23 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    searches are showing 5.5, but you know how that goes : )
    gotta confirm.
    thanks!
    here's what they look like, the SE edition gun metal
