anybody add led lights to the bottom edge of door?
Discussion in 'Lighting' started by tango down, Feb 8, 2012.
  1. Feb 8, 2012 at 8:07 AM
    tango down
    tango down [OP] Policy Ninja
    jeff
    peoples republik of IL
    12 Taco DCSB TRD Off Road
    LED interior, rail mounted ammo cans
    Wondering if anyone has added LED lights to the underside of the doors so that when the door is opened the lights shine towards the ground?
    If so, how did you mount them? How much room is there for mounting a LED application? What product did you use?
    Thanks!
  2. Feb 8, 2012 at 8:12 AM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    I haven't, but there are several products out there. You could mount some under the rocker panel, or to the bottom of the side mirror. Oznium.com has a bunch of LED stuff, or you can get sealed LED strips off eBay that people have used here for rock lights.
    Under the side mirror would be fairly easy to get wires to. The bottom of the door might have some clearance issues.
  3. Feb 8, 2012 at 8:13 AM
    Stubbs95tacoma
    Stubbs95tacoma Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    My lexus has them buttt those came stock... I think it would be cool on a newer taco thogh!! :D
  4. Feb 8, 2012 at 8:21 AM
    acdronin
    acdronin Well-Known Member
    My feeling is that one could install something in the bottom edge of the plastic catch-all thingy at the bottom of the door rather than cutting metal
  5. Feb 8, 2012 at 8:38 AM
    tango down
    jeff
    Great idea! As space between the door and interior (when closed) is no longer a problem.
    @iroc, I was thinking of that too and will probably do that mod anyhow, but I was thinking lights coming from the door would light the door a little bit too so passing traffic would see the open door as well.
  6. Feb 8, 2012 at 6:42 PM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    I added two led strips under each front door today...it should keep my wife from hitting her shins on my nfab bar....I hope.
  7. Feb 8, 2012 at 6:45 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    The best way would be to tap it into the door pressure sensor that triggers the dome to come on. Make sure you wire the ground to it, as that is how the pressure sensor is wired. When that switch is de-pressurized it connects the ground for that circuit.
  8. Feb 8, 2012 at 7:05 PM
    SoCalTacos
    socal
    Yeah I wired it to the dome light...now when I unlock doors with alarm they come on...door open...on. also installed a switch to keep them on whenever I want..
