anybody dial in a Chevy 63" leaf set up for speed?
Discussion in 'Long Travel Suspension' started by 87xjmike, Jan 26, 2011.
  1. Jan 26, 2011 at 11:45 PM
    87xjmike
    87xjmike [OP] Well-Known Member
    Folsom
    98 5lug 2rz
    downey mid travel 2wd set up
    posted this in the faq thread but didn't yield a response so here we are...
    Has anybody played around with the chevy 63" main leaf over the axle for a high speed set up? By playing around i mean attempt to dail in by adding/removing leaves, playing with shackle lengths and angles combo'd with a shock hoop and properly valved resi shock... I know over the axle is not ideal for speed but chevy leaves don't have enough arc to go under and i'm looking for a cheap long travel leaf set up that i can dial in w/ shocks and a shackle as i'm keeping this rig on the budget due to the mass amount of projects i have w/ limited funds on a college budget.
    I know ya'll wanna see 10-11 leaf spring under packs but i'm trying to stay away from that for a couple years untill i can afford to go to a swing arm set up.
    I have a 98 single cab 2wd, with a downey mid travel front end and add a leaf/shackle in the back. Rear end isn't cutting it and i need longer leafs. Not trying to compete, just looking to tune better for a fun beater.
    i'm allready running a decent set up in the xj (cherokee) but i have a feeling i'm going to wanna drive this 4 banger on road trips to the dez more at the moment as i don't have a tow rig and will enjoy the gas milage.
    currently runing a 10 leaf national pack in the back of me xj but i wanna keep this truck bed in the yota in tact for a while and need to focus my finances on the motor/revival of drivetrain so...
    me...
    looking forward to finally owning a taco, i'll post pics of my yoter this weekend after i snap them
  2. Jan 27, 2011 at 12:12 AM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    I was gonna do this but I found a 50t pack for 350
    How do you like the FOAs? Any leaks?
  3. Jan 27, 2011 at 12:33 AM
    87xjmike
    Folsom
    98 5lug 2rz
    yes of coarse i had leaks, had to take them off and send them back once already. I didn't mind much, great custi service and it was free for a virtual re-build and they added the 90degree bungs i wanted for for my hassle... been beating on them for a while now and they haven't leaked yet, i'm really just counting down the days untill they do though cuz you know they will.
    i think they like the differen't mounting location better, little less stress on the lines
  4. Jan 27, 2011 at 8:24 AM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Are those diagonal tubes even looks like they're landing in different spots?
    Did you get the high temp seals?
    As for the 63s maybe get a 3" lift pack and run it under axle with out the overload.
  5. Jan 27, 2011 at 8:48 AM
    87xjmike
    Folsom
    98 5lug 2rz
    even no...high temp seals no... It was a first cage build and my first experience w/ 2.5" resi shocks. Lesson learned on both fronts. The cage needs work, shocks...well i'm sure they'll need work soon at which time i may go to the high temps if these leak. I didn't think i needed them as i only use 14" of travel w/ an 18" shock that's no where near engine temps.
    Are you talking about an aftermarket 3" lift pack for the 1/2 ton chevy's? like rancho or something? That might be a good idea for geometry for a spring under but i think they might be too stiff. I already found a virtually brand new (from the dealer) chevy pack w/ a beefy 6" shackle for 50 bucks and i wanna try and make this stuff work.
    Has anybody had success with these leafs?
  6. Jan 27, 2011 at 9:07 AM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    I thought high temp seal were for high temp oil not for high temp engine compartments
    Well shit you should get that leaf pack if it doesn't work out just sell it. That's what i did
  7. Jan 27, 2011 at 9:26 AM
    87xjmike
    Folsom
    98 5lug 2rz
    well if a resi is in the engine compartment the oil in the shock will get hotter quicker, that's what i was referring to. These shocks really don't get that hot and i don't think high temp is necessary for this app/set up, FOA just has a shotty seal design. Hopefully they've done some r&d and fixed it as i think i might get them for the rear of the yota or slap on the 12" billy 7100's i have. I'm hoping to get 18's of travel out of the rear chevy pack so i'll most likely end up with an 18" shock. But that may change after mock up...I'll probably have to run a custom sway bar in the rear since it'll be spring over.
    What did you do exactly? Did you try the 63's and it handled like shit so you sold them?
  8. Jan 27, 2011 at 9:32 AM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Nah just just prep'd em sanding ect. Then I changed my mind and sold em for 70 bucks. You should look on Dezert-rangers might find more answers.
  9. Feb 2, 2015 at 5:19 PM
    mendogotblood
    mendogotblood Well-Known Member
    mendo, ca
    02 prerunner doublecab
    Revive an oldie but did the orig poster ever try the 63s?
    Howed they work? I loved them on my crawler. I'm interested in trying them on my doublecab build.
  10. Feb 26, 2015 at 7:01 AM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    I race 63" Chevy's on my 4Runner, custom cut the springs to length. They worked pretty good for prerunning but always needed more. My buddy run them in his Toyota Truck with Chaos front, he has just 3 springs in the pack and they do really well.
  11. Mar 14, 2015 at 4:13 PM
    mendogotblood
    mendo, ca
    Thanks for the reply. I ran them for years in my crawler and loved everything but my departure length. I was debating throwing a set with a couple extra progressively cut leaves added to make it a 4 or 5 pack. Paired with a long shackle, resis' and bumps I'm hoping it will hold me over. I ran a 3 pack with no overload and 7 1/2 shackles on my crawler for 3-4 years and they didn't flatten or "crap" out; I even made a few loads of wood while it had a bed.
  12. Apr 4, 2016 at 12:32 PM
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    anyone have pictures using the chevy leaf packs? i just bough some but want to see some setups and shackles.
  13. Apr 4, 2016 at 12:35 PM
    HAVVOKK
    HAVVOKK Blazin Doobies for Noobies
    lakeside
    2014 DGAF Long Bed
    Fucking look it up
  14. Apr 4, 2016 at 12:35 PM
    12TRDTacoma
    12TRDTacoma Pulley Man ;)
    Roberto
    Concord, CA
    12 TRD Sport DCLB 4x4 Tacoma
    Supercharged
    X2. I want to see what they look like on people's rigs...
  15. Apr 4, 2016 at 12:40 PM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Not I, but here's mine :D
    freddy2923 likes this.
  16. Apr 4, 2016 at 12:47 PM
    lilgerber
    Aaron
    Fresno, CA
    Have any pictures of the shackles you built? Or a buddy page?
  17. Apr 4, 2016 at 12:50 PM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
  18. Apr 4, 2016 at 2:24 PM
    HAVVOKK
    lakeside
    2014 DGAF Long Bed
    Fucking look it up
    Thought you did the Chevy swap?
  19. Apr 4, 2016 at 2:34 PM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    I did but I didn't build it for speed
