Anybody else have headlight lens melt?
Discussion in 'Lighting' started by jrobson, Oct 20, 2010.
  1. Oct 20, 2010 at 6:18 PM
    jrobson
    jrobson [OP] Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    My lens over the DTRL is starting to melt and actually cracked. Taking it to the dealer to have both headlight housings replaced next week under warranty. Anybody else have this problem?
  2. Oct 20, 2010 at 6:27 PM
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    there have been a few threads on it...some dealers are blaming the aftermarket HID lighting and not wanting to replace them under warranty (suggest converting back if you have it prior to taking it to dealer)
  3. Oct 20, 2010 at 6:52 PM
    Taco4x4NC
    Taco4x4NC Well-Known Member
    David
    Western North Carolina
    2010 4x4 DC/LB "Pytrite Mica/Katzkin leather
    3m clear bra or Venture, stant locking gas cap, Shield, front windows tinted, weathertechs, ARE "Z" topper. Sockmonkey decal, Billy 5100's x 4 corners, Eibach coils, Toytec 1.5 AAL. Michelin 265/75/16 MS2's, Grillcraft MX series/TOYOTA badging. FJ/SE TRD Anthracite gray wheels. Katzkin leather/heated seats.
    Converting it back to stock to get free work/replacement done? Why not just be honest and tell the truth...they will quickly recognize dishonesty. Bad advice........
    You won't get far................. For what its worth.
    Taco4x4nc
  4. Oct 20, 2010 at 8:06 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Any HIDs (even PnP kits) when installed properly should not melt the HLs. Correct me if I'm wrong but I believe the OP is talking about the amber turn signal lens inside the HL that is melting. The DRLs on the 2nd gen uses the turn signals & not the driving lights like on the 1st gens. I've also notice the amber lens melted on some 2nd gens.
    I think it would probably happen again with the replacements unless they changed the design to correct this. Either too close to the bulb or not sufficient ventilation for it. I would just disconnect the DRLs if it were me but we don't have DRL laws in my area like Canada.
  5. Oct 20, 2010 at 8:09 PM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    Mine have melted but I only have aftermarket bulbs in there and I did the DTRL mod. I have heard of this happening to others as well.
  6. Oct 21, 2010 at 12:31 AM
    supremetaco2
    supremetaco2 Well-Known Member
    concrete jungle, oahu
    04inacoma
    +hp, lifted, lights, dif breather mod, debadged, shorty antenna...
    my friends one did that. stock everything. pretty messed up
  7. Oct 21, 2010 at 8:49 AM
    jrobson
    Mobile, Alabama
    09 DC 4x4
    That is correct. it is the lens over the DTRL's. My dealer doesn't have a problem with the HID's being there but I am going to swap them anyway so they don't end up fingering an expensive HID bulb and then have it blow.
  8. Oct 23, 2010 at 8:55 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    My DRL's melted my ebay headlight lenses. I disabled to DRL's once it started happening.
  9. Oct 23, 2010 at 12:50 PM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    So has anyone contacted Toyota corporate about this? Having DRLs melt the light housing is a pretty serious issue. I would like to add them to my truck, but don't want to fry the housings. DRLs are a safety issue, so they should be more concerned about it.
  10. Oct 23, 2010 at 1:05 PM
    doubletaco
    doubletaco Well-Known Member
    Magnolia
    16 Quicksand TRD O/R 4x4
    TRD FJ Wheels, LED Fog lights
    It's not the headlight lens thats melting it's the blinker lens where the DRL's are. Installing HID's has nothing to do with the DRL's.
  11. Oct 24, 2010 at 5:51 AM
    jrobson
    Mobile, Alabama
    09 DC 4x4
    My new housings will be in on Tuesday. Dealer said "No Problem" and I even confessed about the HID's. Service guy told me mine was the second one he's seen.
  12. Oct 24, 2010 at 8:11 AM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    I have both of these problems. Thanks for reminding me. I'm going to email my dealer now.
  13. Oct 24, 2010 at 8:20 AM
    Kahunadave
    Kahunadave Well-Known Member
    Dave
    Orlando, FL
    05 DC PrernrTRD Sport
    K&N CAI-series 63, custom Billet Grille, Magnaflow exhaust, AR Tactic 17x8, Toyo A/T opencountry 265/70/17, Iridium plugs.
    Both of my stock DTRLs have that bubbled up/melted look which started about 2 1/2 yrs ago..unfortunately my truck was out of Wrty so never took to stealerhship.. Working on just replacing both Headlights with newer ones since the outside plastic is starting to fog as well.
  14. Oct 24, 2010 at 8:20 AM
    Jason'sLawnCare
    Mine are also starting to fog. Dang these headlights are a bad design.
  15. Oct 26, 2010 at 9:57 AM
    jrobson
    Mobile, Alabama
    09 DC 4x4
    Dealer called and mine came in today.
