Anybody ever change out the rear wheel studs?
Discussion in 'Wheels & Tires' started by Ragin, Feb 22, 2010.
  1. Feb 22, 2010 at 12:09 PM
    Ragin
    Ragin [OP] Well-Known Member
    Lafayette, Louisiana
    07 4x4 SR5 TRD
    3inch Skyjacker front struts, Skyjacker hydro7000 rear shocks w/ AAL, K&N CAI, Instrument Cluster Mod, GrillCraft Mesh Grill w/ Pro Comp 9556 5" fog lights, fog light mod, Wet Okole Seat Covers, Remote Start, BHLM, Diamond D3 10", Twister F2 190 Amp,
    3 of mine were sheared off, I was lookin at how to replace them and it looks like I have to take the whole axle shaft out to put in new lugs and that just seems stupid to me. Anyone know of a different way that i'm not seein here? thanks for the help if any.
  2. Feb 22, 2010 at 12:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Front or Rear?
  3. Feb 22, 2010 at 12:14 PM
    Ragin
    07 4x4 SR5 TRD
    rear
  4. Feb 22, 2010 at 12:14 PM
    yotabeast505
    yotabeast505 The Beast
    David
    NE Hights ABQ NM
    THE BEAST
    here we go. Ford 9" rear after breaking 5 sets of gears in the stock yota 8.8, 5.13 gears with a detroit hard locker, 63" chevy leafs and custom hangers, sky's front spring hanger with sky's extream hysteer and PSC hydro assist ram and PSC pump. welded front spyders in the f-550 front dana 60 with warn hubs, pico brake lines and hoses, elecrtic fan, TRD supercharger with URD 2.1 Pully, URD Map-ECU2 and cage built by me. wide band a/f by inovations, lots and lots more...........
    rear no you dont just fined a spot that it will clear and knock them out. and if your truck doesnt have a spot to do that just unbold the 4 bolts and pull the axle out not hard at all
  5. Feb 22, 2010 at 12:15 PM
    Ragin
    07 4x4 SR5 TRD
    what about pressing the new ones back in though?....well i could just tighten the wheels back on and pull them through that way...
  6. Feb 22, 2010 at 12:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I useually use a stack of washers, and use the lug nut to pull the new stud thru. Push the stud in, then put a stack of washers around it, and thread on the lug nut. I wouldnt use the wheels to pull it thru.
  7. Feb 22, 2010 at 12:38 PM
    Ragin
    07 4x4 SR5 TRD
    thanks chris and yota beast, thats a good idea with the washers...I have one more problem with it though, how do i separate the brake drum from it to put the new stud thru? its attached to the hub somehow...
  8. Feb 22, 2010 at 12:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You will see a couple of threadded holes in the brake drum. I cant remember the size off hand, but you can thread a bolt into the holes, and it will pull it off.
  9. Feb 22, 2010 at 12:41 PM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    Sounds crazy but put the new studs in the freezer for about an hour then heat the hub up just a little bit they slide right in. after everything cools and heats back to normal they are there for good. no beating them in or turning wrenches.
  10. Feb 22, 2010 at 12:43 PM
    jeremiekc
    jeremiekc Well-Known Member
    Jeremie
    Vilseck, Germany
    07 Regular Cab Base Model
    Secondary Air Filter removed, Painted Brake Calipers, AFN Drop in air cleaner, OEM Chrome Bumper, OEM Chrome grilll, OEM Cruise Control, OEM Interval Wipers, Hard Wired Garmin Nuvi 670, X-Runner Rims, Devil Horns, 6000w HID's, Bling Light Fogs with Blue Halo, OEM Bilstein Rear Shocks, 12V Plug in Truck Bed pocket. Debagged, 13" Antennax, Color Matched Satoshi Grill, URD Short Shifter, WeatherTech Floor Mats, PainLess Wiring Switched Fuse Box, Black Sand Pearl X-Runner Badges
    A good idea is to use a sacrificial lug nut to pull the studs threw. That or get yourself a grade 8 nut the same size. If you have nice lug nuts sometimes it will mess them up. I know that I paid $7 a piece for mine so I am kind of paticular.
  11. Feb 25, 2010 at 9:11 AM
    Ragin
    07 4x4 SR5 TRD
    thanks for the help guys, its all good to go now!
  12. Nov 5, 2012 at 2:23 PM
    ebayollis
    ebayollis MY DIXIE WRECKED
    josh
    spruce pine nc
    2017 tacoma trd sport ddbl cab 4wd auto
    tracking
