Anybody ever changed out the interior carpet flooring
Discussion in 'Technical Chat' started by jckinnick, Oct 3, 2021.
  1. Oct 3, 2021 at 3:16 PM
    jckinnick
    jckinnick [OP] Well-Known Member
    Tn
    2002 Toyota Tacoma TRD SR5
    None
    Looking for some videos tips and tricks advice?
  2. Oct 4, 2021 at 2:52 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Not nearly has hard as you might think. Pull seats. Pull trim panels as needed. Pull center console. Replace carpet. Reinstall parts. Of course this is the simple version. But really it’s not that bad.
    HisDad likes this.
  3. Oct 4, 2021 at 11:15 PM
    jckinnick
    Tn
    None
    Is there any kind of adhesive or anything that goes under it or do the bolts just hold the carpet in place?
  4. Oct 5, 2021 at 4:41 AM
    gotoman1969
    Correct. No adhesive. The seats and trim are what hold it in place.
  5. Oct 5, 2021 at 4:48 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  6. Oct 7, 2021 at 12:21 PM
    sf.larry
    sf.larry Well-Known Member
    larry
    2011 XR
    I did my 2011 X a few years back. I went with ACC and got the additional backing. If I had to do it over I would just pay a ton extra and get it direct from Toyota. I spent days trimming, cutting and steaming. The additional backing made it almost impossible to steam and fit into the contours. The most annoying thing is how far off the heel pad is. Just like every mod, I know all the imperfections so I’m the only one it bothers.
  7. Nov 7, 2021 at 4:33 PM
    jckinnick
    Tn
    None
    Do I even need the backing or could I just use the old one?
  8. Nov 7, 2021 at 4:40 PM
    Sean42
    Sean42 Well-Known Member
    I did it on my 2011. It took about 6 hours but nothing too crazy. Its not glued in, they come pre molded to shape and it settles right in. You need to trim for things like the center console and wires that come through the floor. There is plenty of excess carpet. I did a pretty professional looking install but if you’re not handy then you can screw it up.
  9. Nov 7, 2021 at 4:54 PM
    jckinnick
    Tn
    None
    Did you buy backing too or just the carpet?
  10. Nov 7, 2021 at 5:41 PM
    Sean42
    The one I bought it comes on the carpet. I chose the thicker backing. I used OC auto carpets and it’s been nice.
  11. Nov 10, 2021 at 4:14 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    What would you like to know? I've done it a few times before finally just tossing the carpet all together and putting in an all weather liner instead
  12. Nov 22, 2021 at 8:50 AM
    Mr Yoda
    Mr Yoda New Member
    Bruce
    Saint Anthony, Idaho
    2000 Tacoma extended cab sr5
    What all weather liner did you use? I was looking at a vinyl molded flooring and wondered what other have used instead.
  13. Nov 22, 2021 at 9:37 AM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
  14. Nov 22, 2021 at 10:18 AM
    Mr Yoda
    Mr Yoda New Member
    Bruce
    Strictlytoyz[QUOTED] likes this.
  15. Nov 22, 2021 at 5:39 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    No problem!
