Anybody ever have corrosion on their battery tiedown?
Discussion in 'Technical Chat' started by TaylorTRD, Feb 15, 2023.
  1. Feb 15, 2023 at 8:51 AM
    TaylorTRD
    TaylorTRD [OP] Big ole log thumper
    Taylor
    Eastern Berks/Lehigh Valley PA
    14 Tacoma DCLB TRD Sport 4x4
    TRD catback exhaust, Volant CAI with Powercore filter, Meso Customs Red/White LED map lights, Sequential smoked 3rd brake light, Morimoto XB LED foglights
    I was installing an intake on my 4.0 last weekend and noticed that my battery had corrosion around the side of the battery tiedown bracket. I could understand it having some on or near the battery posts, but thought it was a little odd that it was on the bracket itself. There was a bit towards the back of the battery, on the underside of the tiedown bracket and some on the rod going down the back. Anyone have any idea where it could of came from? Never seen that happen before but my only guess is maybe my battery has a crack in it I'm not seeing? I don't know when or if it's ever been replaced, truck has 110k on it currently. I'm going to assume it has been at least once.
    Robnik likes this.
  2. Feb 15, 2023 at 8:53 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Leaking battery caused it, it could have leaked enough it's not wet anymore.
    Robnik, super_white, Bivouac and 3 others like this.
  3. Feb 15, 2023 at 8:56 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Not much to worry about unless it's an excessive amount of corrosion. I think mine has a bit of corrosion, but nothing crazy.
    I'd assume it's from the acidic gasses emitted from the battery over time.
    You could remove, clean it to bare metal and repaint if you'd like.
    six5crèéd and TaylorTRD[OP] like this.
  4. Feb 15, 2023 at 8:56 AM
    TaylorTRD
    Taylor
    Ok, next question is what would have caused it to leak? Overcharging?
    Robnik, Bivouac and six5crèéd like this.
  5. Feb 15, 2023 at 8:58 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Anything is possible really, could be over charged, could just be a bad seal on the battery.
  6. Feb 15, 2023 at 8:59 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    If it's a flooded battery like OEM, then there are vent holes on the battery for acid to overflow out of. Get an AGM battery to mitigate this problem.
  7. Feb 15, 2023 at 9:13 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    A normal wet battery needs to be vented if not the pressure would cause it to explode .
    That is why caution is needed to disconnect the negative cable first.
    Hydrogen Gas Likes to explode Blowing up a battery is not something you want to do up close.
    The acid completely destroyed the clothing I was wearing I lucked out I turned away just as it exploded I am not sure my eyes would have survived .
  8. Feb 15, 2023 at 9:14 AM
    TaylorTRD
    Taylor
    I appreciate the info fellas, I didn't really pay it too much attention when I had the hood open but I'll have to see if I can find a manufacture date on it. Might be time for replacement soon.
    Robnik and six5crèéd like this.
  9. Feb 15, 2023 at 9:19 AM
    Bivouac
    Your better off with a load test.
    A in service date is only good if your under warranty or the battery is being prorated.
    Robnik and TaylorTRD[QUOTED][OP] like this.
  10. Feb 15, 2023 at 9:23 AM
    TaylorTRD
    Taylor
    True, I'll take it to my trusty Autozone and have em hook it up haha. See what she's puttin out.
    Robnik likes this.
  11. Feb 16, 2023 at 11:49 AM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    Clean, prime, repaint using a spray can to match, Fluid Film.
    I installed a new battery 2 weeks ago no corrosion, but the truck has been Fluid Film since new.
    I have a posting about it on the Hey Connecticut forum.
    TOMB
    Robnik and TaylorTRD[OP] like this.
  12. Feb 17, 2023 at 6:12 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    I had the same problem since the truck was new. I didn't feel like sitting at the dealer half a day over a battery.
    It was leaking acid slowly. When I bought a new battery, I wire brushed it aggressively.
    Washed it & let it dry.
    Johnson Controls batteries, pfft!
    I sprayed the hold down with Rust-Oleum.
    No problem since. :)
    TOMB and TaylorTRD[QUOTED][OP] like this.
