Anybody ever used either of these?
Discussion in 'General Automotive' started by johntoyota, May 3, 2018.
  1. May 3, 2018 at 6:06 PM
    johntoyota
    johntoyota [OP] "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    I am looking at buying a a cordless impact just to have on my truck. It would kind of be a dual purpose for taking off tires in a time of need but also for just general turning of bolts. As I get older, I find myself less anxious to crank on a wrench when I can just pull a trigger.
    This brings me to my question. Obviously a 1/2" is going to be better for swapping tires but I wouldnt expect that to be the activity I would most often use it for. So, will a 3/8" cordless impact be sufficient to pop a few lugs off? If so, I would prefer the 3/8" as for all reasons other than lugs, I feel like it would be the most practical.
    These are the models I am looking at.
    3/8"
    https://www.lowes.com/pd/DEWALT-20-Volt-Max-3-8-in-Drive-Cordless-Impact-Wrench/3977523
    1/2"
    https://www.lowes.com/pd/DEWALT-XR-20-Volt-Max-1-2-in-Drive-Cordless-Impact-Wrench/1000192195
    Also, please help not have this turn into a Dewalt vs. fill in the blank argument. Im just comparing 3/8" vs 1/2".
  2. May 3, 2018 at 6:22 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    You most likely wont be able to reliably remove the wheel lugs with the XR20 3/8" impact. At least from my past experiences. The downside to the 1/2" impact shown is it is the gear reduction model which means big torque numbers but increased tool length which can make it difficult to get into tight spaces. Both are good tools, but are in two much different torque ranges. Buy both and don't look back.
    90yota and johntoyota[OP] like this.
  3. May 3, 2018 at 6:35 PM
    johntoyota
    Down yonder in TN
    16 truck
    Hahaha. Those were my exact thoughts and I was kind of leaning that way anyway. I was just hoping somebody would convince me that the 3/8 would do it. For lugs, I like the long length to possibly eliminate the need for an extension. But for practically every other bolt on the truck that I would need to turn on the trail or at least not at home, the 3/8 would definitely be superior.
    SC4333[QUOTED] likes this.
  4. May 3, 2018 at 6:38 PM
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    I have a snap on 3/8 battery impact that will do lug nuts on a fresh battery. The newer ones are probably better, I bought mine new about ten years ago and got out of the automotive industry.
  5. May 3, 2018 at 6:39 PM
    slowtacotruck
    17 offroad
    stuff
    My 1/2 battery powered will do lug nuts no problem though.
    johntoyota[OP] likes this.
  6. May 3, 2018 at 6:40 PM
    johntoyota
    Down yonder in TN
    16 truck
    Well I splurged when I bought the truck so why not splurge on its toolbox.
    JS760 likes this.
  7. May 3, 2018 at 6:46 PM
    slowtacotruck
    17 offroad
    stuff
    A pneumatic 3/8 would do lug nuts. You would need an air compressor though.
  8. May 3, 2018 at 6:48 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I thought about it. Settled on a breaker bar because... Murphy.
    WSW3 likes this.
  9. May 3, 2018 at 6:54 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    We use a (Not dewalt) 1/2 inch drive cordless at work. It's main purpose is checking lugs on all the boats that go out as well as putting tires on when they come in on the truck with no tires mounted. The battery last quite a while for our purpose and it satisfies the torque spec for the lug nuts.
    Get the 1/2 inch. If you don't need it right away, Lowe's always has some sort of sale during holidays such as memorial day and especially Christmas.
    I keep in my toolbox a 1/4 inch porter cable impact and I use it for general purpose nut and bolt removal. Not high torque, but lightweight and small for tight spaces. Maybe something to consider, you could get a 1/2 and a 1/4 drive.
  10. May 3, 2018 at 6:58 PM
    johntoyota
    Down yonder in TN
    16 truck
    Nice idea about the holidays! Thanks. I have a 1/4 in the truck that actually does well on a surprising amount of bolts. Want the 3/8 for parts and the 1/2 for tires.
    Fire Arrow likes this.
  11. May 3, 2018 at 6:59 PM
    Thomas15
    Thomas15 Member
    2017 Tacoma trd Sport 4x4
    I’ve never used them in my 16 years as a tech always snap on cordless impact drivers. However a couple of the guys in shop have pots of these and these fu%%ers are strong. Mainly the 1/2 it’s removes axle nuts. Seat belt bolts and on occasions crankshaft pulley bolts. Oh and the warranty is better
  12. May 3, 2018 at 7:01 PM
    (none)
    (none) Well-Known Member
    Travis
    The anti-tacoma, aka 4runner
    As noted, get both... but if you can only get one (or just make it your first purchase), get the 3/8". I have one that accepts the 1/4 bits so you can use 1/4", 3/8", 1/2" or whatever sockets and adapters. I've had it for a few years and it's fantastic. I use it on every project. If you loosen the lugnuts first with a breaker bar, it'll get them off quick.
    I do have a Milwaukee 1/2" drive for wheels and big jobs. It's a heavy beast and too big for most jobs. Great for tire changes and some suspension work though.
    This is pretty much the one i have: https://www.lowes.com/pd/DEWALT-20-...d-Impact-Driver-1-Battery-Included/1000136219
  13. May 3, 2018 at 7:02 PM
    Fire Arrow
    Fire Arrow Hanging out at work
    Jim
    MD
    2016 Black DCSB SR sold, 21 Tundra Limited MGM
    Check the torque specs and see if they go high enough to turn the nuts to the proper range. No sense buying one that won't break the nuts loose or get them tight enough .
  14. May 3, 2018 at 7:08 PM
    GoodOlBoy
    GoodOlBoy Well-Known Member
    Brennan
    2016 MGM TRDOR
    I have the 1/2” one. It’s badass. Don’t have the 3/8” one yet but I want it because, we’ll yeah the 1/2” isn’t so compact. It’s easy to handle, just doesn’t fit in tight spaces at all. Works great for removing mugs though. It’s real strong.
  15. May 3, 2018 at 7:19 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    I have the 1\2 Rigid and it's a beast. Get the extended life batteries and they last a while. I rotate all my tires and it's still going strong on the same charge.
    shakerhood likes this.
  16. May 3, 2018 at 7:30 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I have 1 of those too, it does a really good job.
    JJ Customs[QUOTED] likes this.
  17. May 3, 2018 at 7:34 PM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    Make sure you get at least a 5 amp hour battery
  18. May 3, 2018 at 7:35 PM
    ls7alex
    ls7alex Well-Known Member
    Newark
    Taco gang
    I vote get both :spending:
  19. May 3, 2018 at 7:38 PM
    DieselTech1
    DieselTech1 Active Member
    Doss
    Nampa, Idaho
    2017 TRD OR DCSB
    Go with a 3/8” drive Milwaukee M-18 Fuel. You will not be disappointed I promise you. Mine will bust lug nuts all day, no problem. I’m a heavy equipment technician and use mine everyday. By far the most useful tool in my box.
    JJ Customs likes this.
  20. May 3, 2018 at 7:38 PM
    JJ Customs
    Jay
    NV
    We use the Milwaukee impacts at work and I have to say they have an awesome warranty. If you break it they fix or replace it within two years and pay the shipping both ways. For my cordless tools at home I have been really happy with the Rigid stuff and I am a massive brand whore/tool snob.
