Anybody familiar with EVO's??
Discussion in 'General Automotive' started by 09_tacoma, Jul 10, 2010.
  1. Jul 10, 2010 at 8:31 AM
    09_tacoma
    09_tacoma [OP] Forever at a crossroads
    Mylene
    North Pole
    09 Taco V6 4x4 DLCB TRD Sport
    Headlights, Exhaust, grill, Kings all around resi suspension. Camburg UCA's, Clarion double din
    Hey, my buddy has an '08 EVO and for the past week has had a hard time clearing error codes.
    To sum it up his boost gauge stopped working so he messed with the wires and got them running again.
    But now he's getting the error code B212c, (his fuse is okay and he's getting power to it), he also lost all control over his ventilation system. He's got air blowing at the feet but he can't switch it to other areas or change the temp. it comes out at.
    He's also getting warnings for his airbag, traction control and I forget the 3rd..
    Would anyone have any suggestions on how he can get the codes cleared and things to run properly again??
    I can post a link to the thread he's created on the evox forum if that could help.
    Thanks for any input!
  2. Jul 10, 2010 at 8:52 AM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    He can get it flashed to clear the codes, but that won't help his ventilation system. Check for blown fuses.
  3. Jul 10, 2010 at 9:43 AM
    09_tacoma
    Mylene
    North Pole
    He has checked all the fuses he could find, all of them seem to be good and are getting a charge.
    He's tried clearing the codes too but nothing that he's tried doing has worked so far.
  4. Jul 10, 2010 at 12:47 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Could a wire have been fried? Loose connection?
    Should have got an STI. (EVO's are still seksi though)
  5. Jul 10, 2010 at 1:03 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    I've heard that the Lancers & EVO's have problems with the doors inside the heater core/evaporator box behind the dash. When I worked at a Mitsubishi dealer as a lube tech I seem to remember seeing the other techs removing the dash's on those alot and replacing a plastic gear or something like that on the hvac box, so that could be the problem with the ventilation system.
    As far as the codes go, it could be anything. No offense but the EVO's were pieces of crap. I always thought they looked cool, they were fun to drive too, but every single one I saw come through the shop was either brand new (no miles), or a huge piece of abused crap.
  6. Jul 10, 2010 at 2:34 PM
    09_tacoma
    Mylene
    North Pole
    It's a possibility I guess.. really can't say, I'm not knowledgeable enough in the wiring side of things. (Should have paid more attention in science class I guess, lol) If a wire is fried would it still give a positive reading on a test light??
    That's the best suggestion I've seen so far (as far as the ventilation problem goes). Thanks! I'll pass the info along
  7. Jul 10, 2010 at 3:02 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Honestly, couldn't tell you.
    All I know is that if you can't fix it with a hammer...it's an electrical problem.
  8. Jul 10, 2010 at 3:26 PM
    Altonymous
    Altonymous Taco Lantern
    Cary, NC
    '10 TM, DC, 4x4, TRD OF w/ SR5
    I own an '08 Evo myself. I'm looking to sell it to pick up a Taco, but not because I don't love it. I love mine, had 0 problems since the day I bought it. Evos and STis end up in shops a lot because people tinker and don't know what they are doing.
    As for your friends problem, it sounds to me like one of his wires is frayed because he didn't run the wires correctly and thus it's not grounded properly.
    I've done a lot of electrical installs and even fixed up cars for other people and most of the time the culprit was someone not using the right wire or connectors. I've seen some pretty scary stuff. Bare wire's being plugged straight into the fuse box, electrical tape connecting wires together... These are all scary because if the tape get's snagged putting things back together or gets pulled apart it can short things.
    Also does he hear a clicking sound near the fuse box? If he does it's most likely a fuse even if he thinks he checked them all, I suggest pulling each one and verifying. A lot of times the tiny little boogers look fine until you shine a light directly on them.
  9. Jul 10, 2010 at 3:58 PM
    09_tacoma
    Mylene
    North Pole
    I like his car too, it's a sweet car and the exhaust he has on it sounds amazing. I can hear it rumbling from up the street when he comes over hehe.
    Back to his problems, he's not the one that did the mods on it, he bought it used last fall and it was already modded out. From a few things I've seen myself though, the previous owner didn't really know what he was doing.. some things were pretty sketchy... :confused:
    I'm not worried about my buddies' capabilities.
    There isn't any electrical tape or bare wires going anywhere (thankfully), bad connectors is a possibility though.
    Thanks for your input
  10. Jul 10, 2010 at 6:26 PM
    Altonymous
    Cary, NC
    No Problem. If you guys lived closer I would offer to take a look with him.... Is he aware of evolutionm.net or evoxforums.com The guys there can probably give him a hand and/or help him find someone local that knows what they are doing.
    P.S. - Mine is for sale... ;-P
  11. Jul 10, 2010 at 7:05 PM
    09_tacoma
    Mylene
    North Pole
    Pm sent,
    Hehe, I dunno.. that's a tough one.. I like my poor abused truck, lol
    What's a girl to do? sadly can't have it all...
