Anybody got a hand throttle setup??
Discussion in '1st Gen. Tacomas (1995-2004)' started by 01kingtaco, Mar 9, 2013.
  1. Mar 11, 2013 at 10:29 AM
    01kingtaco
    01kingtaco [OP] Well-Known Member
    Kodiak
    Maui hawaii
    01 taco slightly modded
    Bigger tires, sound system, deck plate mod, fog light mod, straight pipe exhaust, blue led floor lights, ultragauge, 3 inch lift
  2. Mar 11, 2013 at 10:31 AM
    FoundOffRoadDead
    FoundOffRoadDead whiptastic handling
    Shamus
    Walnut
    Ford
  3. Mar 11, 2013 at 12:54 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    I've had interest to do this for quite some time.
    but a google search failed to confirm my inquiry.
    my primary confusion is the length of the cable housing and wire
    that leads from the control to the throttle body.
    In looking at muh '00 Tacoma...
    I'd guess 5 ft on the cable housing...
    and prolly 6 ft of wire.
    But other write ups vary in what length was used
    and I didn't find the magic article that details specifics
    regarding the Tacoma 5VZ.
    sooo...
    what cable length did others use on their 5VZ Tacoma ?
  4. Mar 11, 2013 at 3:35 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I'd think you could make 5 or 6 foot work just fine. Really would depend on your routing t
    Of the cable I think.
  5. Mar 11, 2013 at 5:19 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    thanks... I realize cable length can be adjusted.
    was just looking for a completed example
    so I wouldn't need buy longer lengths then necessary.
    my local bicycle shop is asking $ 2.50/per ft (cable or sleeve) :rolleyes:
    guess I'll have to shop around online
  6. Mar 11, 2013 at 6:25 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea the only good write up I found once on yotatech was for a 3vz
  7. Mar 11, 2013 at 6:44 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    I'll take pictures during my install.
    this thread seems lacking of detail
    I'm going to use the Sunrace SLM10 top load friction shifter.
    but can't find a single left thumb lever. Only the right or pairs :mad:
    still looking :rolleyes:
    A thoughtful user here has offered to help me out with my
    cable/sleeve needs.
    I'll thank him officially when I post completion pics (if he's ok with it)
    edit: just found those single left side friction levers
    two @ Amazon one for $ 10.20 shipped, another for $ 7.00 shipped
    the key was wording the search (Sunrace MBT left friction shift lever) bingo
    I couldn't decide... so I got one of each :p
    th_SunraceSML10frictionlever_717ead8d19cb20ca0b2c73700fb47ac2b678924f.jpgth_Sunracefrictionlever_b2dc2f01dd8566097b51b7a81ec38ae55d5f8e94.jpg
  8. Mar 11, 2013 at 11:10 PM
    01kingtaco
    Kodiak
    Maui hawaii
    I'm not even gana route it to the throttle body I'm going to put the twist out one mounted right of to the side of the parking brake lever and have it go straight to the top of the gas pedal where the wire connects to the lever it's a straight line from those 2 points
