Anybody hauled a motorcycle in their tacoma?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by metaltaco16, Jul 9, 2016.
  1. Jul 9, 2016 at 2:39 PM
    metaltaco16
    metaltaco16 [OP] Well-Known Member
    2016 Tacoma TRD Off Road
    I hauled my GSXR on a 10hr road trip in my 2010 tacoma a few years back. It worked just fine. Now I have a 2016 tacoma and my bike is a Harley sportster, a tad heavier. Anybody don't this or know if the tailgate will be able to handle the tire for a trip?
  2. Jul 9, 2016 at 4:55 PM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    If you're in doubt about your tailgate supporting the weight buy/make a longer platform/rail the whole bike sits on so the tailgate is not bearing much weight.
    MadDaddy likes this.
  3. Jul 10, 2016 at 5:30 AM
    evilfij
    evilfij Well-Known Member
    2016 ACLB SR 4x4 MT Utility Package Black
    TRDOR wheels, sheepskin seat, cruise and intermittent wipers, curt hitch
    I need to haul a 1975 R75/6 in my ACLB so anyone who has any tips I would appreciate them. I have a ramp but it is a heavy bike so I am mostly focused on how to secure it. Back in first or front? Straight in or diagonal?
  4. Jul 10, 2016 at 7:04 AM
    SqFt
    SqFt Well-Known Member
    2016 Tacoma TRD Sport
    I have a long bed and have hauled my GSXR and a Honda Shadow 750. No problem what so ever. I drive them straight in and centered. Then I use the four hard tie-downs in each corner to secure it. No wheel chock required.
    evilfij and Cavedog like this.
  5. Jul 10, 2016 at 7:07 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    You'll be fine. I had a Sportster in the back of my truck on Several occasions, among other bikes. And I've got a first gen 5 lug with the 2.4I. You'll be fine. Will have to turn the wheel sideways and ratchet strap it.
    evilfij likes this.
  6. Jul 10, 2016 at 7:10 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I remember someone on here was in a similar predicament a while ago. They ended up using a thick piece of wood that covered the whole bed and tailgate as one piece with some supports underneath. It worked great and took the weight off the tailgate. Let me see if I can dig it up
    EDIT: I looked, but couldn't find it again. IIRC, all he did was cut a piece of wood that fit the whole bed/tailgate and had somee 2x4's underneath running width wise, to help distribute the weight.
    MadDaddy and evilfij like this.
  7. Jul 10, 2016 at 7:14 AM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    The tailgate won't support the weight of a heavier bike long term (especially true with SB). With older vehicles, you could add a stiffener to help avoid damaging the gate-no idea about 3rd gen ones.
    That /6 is probably nothing to worry about in the long bed. When you load the bike, just load it to the center of the bed. What ever you do, do not use the bed rails and plastic hooks to secure any motorcycle. @JLee used to make some corner brackets to help secure the load. Tie down at the front and back. Try and keep the rear wheel from bouncing too. You can go corner to opposite corner too but down the center makes it easier to see whether the bike is shifting around or not.
    evilfij likes this.
  8. Jul 11, 2016 at 12:49 AM
    MF13TRD
    MF13TRD MF13TRD
    Mark
    CNY
    TRD Offroad BSP
    Duratracs, spidertrax, SOS Concepts sliders, Hella500 Blackmagics behind Customcargrills, foglights anytime, console lock
    FWIW I have transported my sportster in the bed 5 times now across multiple states with no issues. I center it in the bed with the wheel straight and the rear tire sits about dead center on the tailgate on my short bed. It does sag some but has always sprung right back when the bike comes out. Two ratchet straps are all you really need to secure it to the tie downs at the front of the bed. Hook one end there, loop it around one side of the front fork and hook the other end on the same side. Repeat on the other side and crank those suckers down until your fork is compressed about half way so the straps don't come loose if you hit a big bump. In the past I have run a third strap thru the back of the frame forward of the rear tire just to be safe but it doesn't really do anything except make you feel better. I couldn't get it to budge at all shaking it, just rocked the whole truck.
    evilfij likes this.
  9. Jul 11, 2016 at 1:03 AM
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    I prefer using an open cargo trailer.It was well worth the price of it and easier for an old man!
  10. Jul 15, 2016 at 8:17 PM
    dpgreen
    dpgreen Well-Known Member
    Doug
    Raleigh, NC
    2016 4x4 Access Cab
    Hauled a Yamaha Roadliner (see profile pic) in my 2007 and my 2015 (both access cab long beds). With fuel and my hard bags weighed around 780 pounds plus another 170 with me sitting on it when loading. There are several threads about the weak tailgates on the gen 2s bending, especially if you concentrate weight on the middle of the tailgate when loading it. I have a ramp that spreads the weight so I might have been able to get by BUT...not willing to risk it. So... for the 2007 I had cut a 3/4 inch 4x8 piece of plywood to fit the bed (including wheel well cutouts) and the ramp sat on the plywood over the tailgait. On the 2015 I got fancy and bought a steel tailgate cap from Voodoo Fabrications. My understanding is that the Gen 3s have better tailgaits but I still would want to reinforce them before putting my big bike on it unless shown evidence that it has the capacity.
    MadDaddy, Kilokato and KB Voodoo like this.
  11. Jul 15, 2016 at 10:20 PM
    stan23
    stan23 Well-Known Member
    stan
    Santa Clara, CA
    2025 DCSB TRD Sport 4x4
    Hey man!!! nice seeing you here.
    The 3rd gen gate is a bit more robust than the 2nd gen. But still I added a tail gate reinforcement plate.
    mobtown sells one. Works great!
  12. Jul 15, 2016 at 11:39 PM
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    I think the tailgate on the 3rd gen is pretty stout and you wouldn't have any problems. That said, if you want piece of mind then you could cut a piece of 3/4 plywood to fit between the wheel wells and long enough to extend out over the tailgate.
  13. Jul 16, 2016 at 8:32 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Thanks! And you as well.
    The plywood idea would probably work too.
  14. Mar 21, 2017 at 7:29 AM
    Rider Eh!
    Rider Eh! Well-Known Member
    Calgary, AB
    17 Tacoma DCSB TRD Sport V6 Manual 4X4
    I'd like to resurrect this thread as motorcycle season is coming soon. Anyone had any issues? I have a short box and will have two 450 MX bikes on the tailgate. Wondering if I should reinforce either the cap or the tailgate or both.
  15. Mar 21, 2017 at 7:36 AM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    No the motor will be in the bed. The tailgate won't have much weight on it
  16. Mar 21, 2017 at 7:58 AM
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    I've hauled two full size MX'ers in the bed from Denver to Vegas and back with no issues.
  17. Mar 21, 2017 at 11:19 AM
    Rider Eh!
    Calgary, AB
    My concern is there's a bit of a difference between hwy miles and bouncing up and down a gravel road. Bikes are well balanced, so figure 130 lbs each rear tire on a point location is quite a bit of force.
  18. Mar 21, 2017 at 11:25 AM
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    Hauled a bike in my short bed for 5 hours, no issues. Angle it slightly so that the back tire is actually on a beam in the tailgate and not in the center, where there is no support underneath (you can feel where the supports are). I used the tiedowns in the front of the bed (the metal ones) and loaded the front suspension of the bike to take as much weight off the back wheel as possible.
  19. Mar 21, 2017 at 11:40 AM
    2Airheads
    2Airheads Well-Known Member
    George
    2017 SR AC 4x4 Manual
    Straight in,compress the forms while sitting on the bike and tie down the front down the front end to the d rings.Ive done this with my R80/7 with no problems.I don't even use ratchet tie downs,I use the cam buckle ones.
  20. Mar 21, 2017 at 11:42 AM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    a time or two but its a second gen FTMFW
