Anybody have a “sandbag” set up. 4x4-4x2, non studded/extreme weather tire winter driving thread,
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NorNev, Sep 15, 2021.
  1. Sep 15, 2021 at 9:11 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    Same here, works great and it removes itself as the weather warms.
  2. Sep 15, 2021 at 9:33 PM
    Truckntran
    Truckntran Well-Known Member
    1996 and 1998 Tacoma 2wd
    High mileage work trucks
    I used to carry around a couple bags of sand or a few chunks of heavy firewood. Either build a wood frame to keep it from sliding in the bed or just lay a tire or three flat in the bed to keep things put. Sure, it looked a bit hillbilly but so what?
    NorNev[OP] and Cereal_killer like this.
  3. Sep 15, 2021 at 9:37 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    You just reminded me of a good memory.
    When I was about 5, the guy across the street brought home a load from Big Bear. He unloaded it in his yard and let us neighbor kids have at. First time any of us had touched the stuff. This is what his truck looked like.
  4. Sep 15, 2021 at 9:38 PM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    When I lived in Wyoming, I used the 40# bags of water softener salt from Wally World (very cheap and available). Piled right back against the tailgate to maximize the weight transfer - biased to the passenger side. The wood frame to keep them where you want is the way to go.
    NorNev[OP] likes this.
  5. Sep 15, 2021 at 10:21 PM
    TacoTruckCO
    TacoTruckCO Well-Known Member
    Joel
    Portland, OR
    Voodoo Blue 20 OR DCLB
    I have one of those. 1/2” thick weighs about 100lbs
  6. Sep 15, 2021 at 10:35 PM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    After having three Tacomas I've settled on two 60# sand bags. One over each tire with a small choker around each with a ratchet strap holding them to the side. Keeps them from moving around and easy to take out when I need the whole bed. When I didn't strap them the bags would always move around, even with a bed mat.
  7. Sep 16, 2021 at 12:12 AM
    TheRedComet
    TheRedComet Well-Known Member
    Here
    2017 Barcelona Red TRD Sport 4X4 Manual
    Pro grille, Black SEMA wheels, air dam delete. Rear Blue Sumo springs. Front Timbren Active off road bump stops. Bilstein 5100s front and rear.
    As a Texan ive only seen snow a handful of times in my life and only recently drove in the stuff. Sandbags worked for me for the .2 inches lol
    NorNev[OP] and pltommyo like this.
  8. Sep 16, 2021 at 12:38 AM
    Kahpo
    Kahpo Well-Known Member
    Pacific Northwest
    96 extended cab 4x4 2021 TRD OR Access cab AG
    Normally I use 2 sand bags one over each wheel well. Last year traveling back to Seattle I got caught off guard in south eastern Washington and could not find any sand bags but they had garden manure on clearance for .25 a bag ended up putting about 30 bags in my truck worked great and the garden was happy.
    NorNev[OP] and shotgunbilly420 like this.
  9. Sep 16, 2021 at 1:00 AM
    Doc62
    Doc62 Well-Known Member
    Dave
    SE Pennsylvania
    2025 Tacoma TRD Off Road i-FORCE Max, 2019 Sahara
    When snow is called for in my area, I just buy extra cat litter for the back. Never goes to waste (2 cats) and as an added bonus, provides great traction material if you do get into a slippery surface.
  10. Sep 16, 2021 at 4:56 AM
    willie2
    willie2 Well-Known Member
    Nova Scotia Canada
    4 Banger 5 spd
    200 LB piece of industrial conveyer belt cut to fit.
  11. Sep 16, 2021 at 4:58 AM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Hard to weigh its very awkward and floppy
  12. Sep 16, 2021 at 6:30 AM
    TacoTruckCO
    Joel
    Portland, OR
    for sure . I’m just going by the weight listed on the farm store description. Haha
  13. Sep 16, 2021 at 6:39 AM
    pltommyo
    pltommyo Well-Known Member
    Tom
    2016 Gray Tacoma TRD Offroad
    SSO hybrid bumper, Warn winch, RCI skid trilogy, RRW sliders, everything in the cheap/free mods thread, and of course the frame recall work.
    I run severe snow rated tires, add no weight to bed, and just drive. Michigan winters are snowy and icy, and our damn roads are not fixed, but I have no issues. When it is especially sketchy I simply use 4WD, that is what it is for.
    NorNev[OP], CanadaToy and pinochle like this.
  14. Sep 16, 2021 at 6:43 AM
    CRCs Reality
    CRCs Reality Well-Known Member
    Pittsburgh-Ish
    2017 DCSB TRD Sport (OVTuned)
    If it's going to be really icy I throw 2 5 gallon buckets in the back corners. One full of rock salt and the other sand, adds weight and if needed I can scoop them out under the tires for traction.
  15. Sep 16, 2021 at 7:13 AM
    #35
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    With my current tires I found I didn’t need any ballast the last two winters, but I have used all sorts of whatever I could find in years past. Sand bags and similar things are nice, because they are easy to remove when I need to use the bed. A big pile of snow and ice; not so much.
  16. Sep 16, 2021 at 7:31 AM
    #36
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Only need to shove it in 4WD during a storm. Other than that, the streets are plowed. No weight required for me.....
    NorNev[OP] and knayrb like this.
  17. Sep 16, 2021 at 8:08 AM
    #37
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    Winter Tires.
  18. Sep 16, 2021 at 8:21 AM
    #38
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    Just get good quality winter tires as others suggested, and forget about sandbags. Love my Nokian LT3's... point and shoot....
    NorNev[OP], pltommyo and pinochle like this.
  19. Sep 16, 2021 at 8:25 AM
    #39
    Grindstone
    Grindstone Requires Adult Supervision
    The RTT is handy for this.
  20. Sep 16, 2021 at 8:25 AM
    #40
    Sasquatchian
    Sasquatchian Well-Known Member
    Back when I had a 2WD Toyota and used to go back country skiing and snowshoeing every weekend I'd put a couple hundred pounds of my photo sand bags at the back end of the bed and that helped a lot. Still had to chain up all the time anyhow because you'd have to go through the CHP chain control areas. Got really fast at putting a pair of chains on often being the last truck in and first truck out of chain control but it still got old and it's been 4WD ever since and only once have ever been forced by CHP to chain up with 4WD. Dude claimed it was ice but the road was dry and when I got to the second chain control, that officer looked and me and said, "what the fuck do you have chains on for?" After a while they'd get to know you and know whether or not you knew how to drive in snow and ice and mostly would just wave you on through. These days the 200 lb SnugTop is more than enough weight for me.
