Anybody have a “sandbag” set up. 4x4-4x2, non studded/extreme weather tire winter driving thread,
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NorNev, Sep 15, 2021.
  1. Sep 16, 2021 at 8:26 AM
    #41
    adk_tacoma
    adk_tacoma Well-Known Member
    Joe
    Waterford, NY
    2016 quicksand tacoma sr5
    Westin outdoors man winch brush guard, custom switch board, Custom machined tow hooks, 255/85/r16 tires, trd shocks and struts, oba in bed cubby, ladder rack, JDUB skid plate
    I made a bed mat out of 3/4 inch stall mat from tractor supply (100lb) then add the 160 lb ladder rack, and 160lb rock sliders and I don't think I need anymore .
    NorNev[OP] and TacoTruckCO like this.
  2. Sep 16, 2021 at 6:40 PM
    #42
    holysmartone
    holysmartone Member
    Nick
    2017 Inferno Tacoma Offroad
    Michigan winters here. I run snow tires (Cooper Discoverer M+S), and usually throw 4 60LB bags in the bed. Didnt feel like getting new bags last year, so I just filled the bed with some cinder blocks I had laying around. You really dont need a ton of weight, I just find a couple hundred pounds help hold the ass end down, especially around tight curves.
    Either way, its nothing like the 800lbs+ that I used to throw in the bed of my old Cummins in the winter to keep the tires from spinning when taking off from every single stop light.
    NorNev[OP] likes this.
  3. Sep 16, 2021 at 11:05 PM
    #43
    DNguyen1033
    DNguyen1033 Well-Known Member
    Nguyen
    Southern California
    07 OR | 21 OR 4X4
    And this is why Toyota have the famous taco lean, lol.
  4. Sep 17, 2021 at 5:44 AM
    #44
    WoodfordReserve
    WoodfordReserve Member
    2016 Tacoma AC 4x2 Base Gray
    Trailer Hitch
    2016 4x2 Access Cab 2.7 SR - I live in the NE Ohio Snowbelt and have a steep uphill driveway to tackle. My Tacoma remains in my attached garage all winter which isn't heated but usually above freezing. I use the ShurTrax bladder and fill it as close to its 40 gallon capacity as I can to achieve about 320 lbs of low-slung traction weight over my drive wheels. I swap my standard radials with Nokian Hakka LT3 studded. The combo works very well and ShurTrax is easy to drain, roll up, and store away in the Springtime. Pretty inexpensive too. The bladder rarely freezes solid so it remains a slushy waterbed for most of the Winter. Its tough enough to load non-sharp-edged cargo (or step on) atop, but if I loaded up regularly, I'd consider building a plywood floor deck just above it (4" height) in my bed. The baffled bladder has grommets built in to strap down securely to the bed floor. Its nearly impossible to move around when filled, anyways. Interestingly, the motion of the water slush acts like a recoil damper when driving over rough surfaces and smooths out my ride a bit. The 2.7 auto moderates the drive wheel torque to manageable levels and I rarely experience wheelspin. My ski equipment nestles snuggly between the wheel housing and side of the bladder when I transport myself to the ski slopes, which is an added bonus. I don't have to store sandbags or weights throughout the rest of the year.
    NorNev[OP] and Knute like this.
  5. Sep 17, 2021 at 8:41 AM
    #45
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Used to put 4 sandbags across the bed between the wheels wells of our 2nd gen and again on the 3rd gen. Now with the canopy, JackAll, recovery gear, and toolbox I don't need so many - in fact last year I didn't bother and had zero issues. Blizzaks help of course.
  6. Sep 17, 2021 at 8:42 AM
    #46
    BlueRidge19
    BlueRidge19 Well-Known Member
    '21 OR DCLB
    4 concrete blocks (8"x8"x16"), about 150 lbs.
