Anybody have a posi?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Brice, Jul 7, 2015.
  1. Jul 7, 2015 at 8:06 PM
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    were could i find a posi unit for a 99 prerunner taco? i read the door panel code and it says i dont have a posi but i would like to have one.
  2. Jul 7, 2015 at 9:48 PM
    TACO626
    TACO626 Well-Known Member
    Montclair, CA
    02 Tacoma 2.7
  3. Jul 8, 2015 at 7:15 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
  4. Jul 8, 2015 at 10:38 AM
    Brice
    Brice
    Texas
  5. Jul 8, 2015 at 10:38 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    whats a posi?
  6. Jul 8, 2015 at 10:40 AM
    Brice
    Brice
    Texas
    kinda like a locker but automatic with no button to engage it
  7. Jul 8, 2015 at 10:44 AM
    Brice
    Brice
    Texas
  8. Jul 8, 2015 at 10:52 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Chevy talk
  9. Jul 8, 2015 at 10:57 AM
    ramonortiz55
    Ramon
    Texas
    stock
    gotcha.
    is posi a short word for something longer? or just posi is a old school word itself?
  10. Jul 8, 2015 at 10:58 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
  11. Jul 8, 2015 at 10:59 AM
    devinzz1
    devin
    2023 aclb trd or mt
    positive traction or "posi-trac"
  12. Jul 8, 2015 at 11:13 AM
    Brice
    Brice
    Texas
    hmm ill look into that no slip
  13. Jul 8, 2015 at 11:24 AM
    Brice
    Brice
    Texas
    I think i've decided to go with the no-slip
  14. Jul 8, 2015 at 11:26 AM
    tan4x4
    Rick
    Folsom, CA
    A posi (aka Limited Slip Diff), does not completely lock both sides. Only spools do that. Automatic lockers (Lock-rite, Detroit, etc) lock and unlock automatically as needed. The tru-trac is available for all Tacoma OEM rear diffs EXCEPT the e-locked diffs.
  15. Jul 8, 2015 at 11:53 AM
    ramonortiz55
    Ramon
    Texas
    stock
    gracias
  16. Jul 8, 2015 at 1:39 PM
    Brice
    Brice
    Texas
    Alright so i believe i have settled on the powertrax no-slip
  17. Jul 8, 2015 at 3:12 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    This is what I ran in my 03 Tacoma and I ran them front and rear in my 89 pickup. I highly recommend these units, as they seamlessly transfer torque from one wheel to another vs any kind of locker that operates as like an on/off switch. They also do not wear out like clutch based units and require no gear oil additives. They make a unloaded pickup with MT tires much better to drive on in the rain on steep streets (as the tires won't spin) in addition to all the off-road benefits, and are more ideal in the snow (on the street) when you do not want your rear end to fully lock. The only time a locker will be significantly better is if one wheel has zero traction (ie airborne) then the torque transfer to the other grounded wheel will be zero.
  18. Jul 8, 2015 at 3:26 PM
    Brice
    Brice
    Texas
    would you happen to have the part # for that one? This locker/posi will be going into a 2wd prerunner. I dont want to do anything crazy but i need it to not get stuck easy as it is my only vehicle and converting to 4x4 basically voids my sell-a-bility
    EDIT: i have a 7.5inch oem open diff
  19. Jul 8, 2015 at 4:14 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Using Randys Ring and Pinion Diff Wizard, (where I get all my gearing work done) they do not show a TrueTrac for the 7.5 diff. I don't know if they are available for that diff.
    http://www.ringpinion.com/DiffWizard.aspx
  20. Jul 8, 2015 at 4:38 PM
    Brice
    Brice
    Texas
    well if they dont have one it looks as if im gonna use the powertrax
