Anybody have an ARB Front Air Locker?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Pablo8, Dec 14, 2019.
  1. Dec 14, 2019 at 1:09 PM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Need to compare notes on air locker behavior.
    1) Engage 4-lo
    2) Turn compressor switch on hear, feel nothing.
    3) Turn REAR locker switch on - HEAR compressor for a very short moment while hearing feeling a click.
    4) Turn FRONT locker on and hear, feel nothing.
    5) Turn all off, return to RWD
    1) Engage 4-lo
    3) Turn FRONT locker on and hear, feel nothing.
    4) Turn all off, return to RWD
    Is this NORMAL?
  2. Dec 14, 2019 at 1:36 PM
    xxtavixx
    xxtavixx Well-Known Member
    Jacksonville fl
    2018 6MT
    ARB rear locker OVtune Mobtown sliders Core-shifter short throw Trd bro-phony grill Caliraised bumper light bar Caliraised ditch lights Rigid ignite back up lights FN Five Star 16x8 Et0 255/85/16 cooper st maxx MesoJDM fuse box cover MesoJDM led interior lights Bilstein 6112 fronts Bilstein 5100 rears Headstrong 3 aal Toytec 3* shims Mesjodm dome and map lights Diode dynamix ss3 pro yellow Mobtown aluminum front skid 2lo mod SOS front recovery point
    I assume you are trying to determine if the front locker is getting air. My suggestion would be to engage both, then turn off the front, turn it back on. Do this several times. Eventually the compressor manifold will need to recharge as the line keeps drawing.
    I dont have a front, but for my rear it takes about 4 or 5 cycles to recharge the manifold
    Pablo8[OP] likes this.
  3. Dec 14, 2019 at 1:45 PM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    Yes just checking. It's raining cats and dogs out, if it weren't I would suspend all 4 wheels and test it. The front is silent, but I haven't cycled it as you suggest. It may just be it's so close to the manifold and doesn't move much when engaging. Thanks
  4. Dec 14, 2019 at 1:54 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Lift front of truck off the ground so tires are able to spin . Engage Air locker and you or a helper spin one of the tires . If both spin the same direction your locker is working . If only one tire spins one direction and the other doesn't or spins opposite direction then the locker is not engaging
  5. Dec 14, 2019 at 3:01 PM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    False test. Front locker does not engage unless rear locker switch is on.
    So switch on compressor, then rear, then front - the compressor will come on as required. Will lock test tomorrow. Thanks
  6. Dec 17, 2019 at 9:18 AM
    derelique
    derelique Well-Known Member
    Derek
    2004 Tacoma
    They made the wiring harness default that way. The front will only come on after the rear is engaged unless you modify it.
  7. Dec 17, 2019 at 9:20 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    Yep naturally I read the manual that evening which made it quite clear. :p:D
  8. Dec 17, 2019 at 9:22 AM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Slight spin of the front and it engages. I think I can turn my front locker on and off 3 times before the compressor kicks on. The rear is once.
  9. Dec 17, 2019 at 9:25 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    Pretty much spot on.
    Do you have an air hose/tank/qd etc for tires?
  10. Dec 17, 2019 at 9:51 AM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    I dont run a tank. When I air up with the hose it will just run continuously. Flick the front locker a few times on once the rear is engaged and you will hear it kick on. The tank has enough air to activate the front since that line is the shortest.
  11. Dec 17, 2019 at 9:54 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Does your front locker indicator light come on?
  12. Dec 17, 2019 at 9:57 AM
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    Did you get your questions answered? I'm not sure what exactly you're looking to test. Where exactly are you "feeling" for something when you engage the locker? Binding during turn? Tangible clicking or something during engagement?
    Like any locking gears you may need to induce by turning and moving the truck a bit. Front diff is smaller so doesn't take as much air from compressor once compressor has engaged and built pressure.
    Also, curious, what is your setup that you have to go into 4LO and lock the rear first? Interested because i have an OR and only have front air locker so I can engage whenever I feel like breaking my front end :)
  13. Dec 17, 2019 at 10:02 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    Cool cool makes sense. How is your air up line plumbed in? DIY or use the ARB kit?
  14. Dec 17, 2019 at 10:03 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    Yes it does.
    Brian422[QUOTED] likes this.
  15. Dec 17, 2019 at 10:10 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    Yes. I was just wanted to quickly make sure stuff was working when I first got my truck home last Friday. All seems well.
    I just used 4Lo in my example because I would be hard pressed to use my front locker in 4Hi! Yes with ARB they make it slightly idiot proof must have rear locked to use front locker.
  16. Dec 17, 2019 at 10:13 AM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    Yeah I was the same way when I did my front locker. If you can get it to bind it will be very obvious if it's locked. Unfortunately the light just means you've told it to push air doesn't mean it worked!
    Didn't know ARB made a full kit for both that has extra logic, very cool.
  17. Dec 17, 2019 at 10:22 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    Not a lot of logic just the front locker solenoid switch is powered from the rear locker solenoid switch
    While on the topic I am not exactly a huge fan of the ARB rocker switches. The don't really fit in the standard 2016+ cubby panel. While lighted and not engaged only a little bluish light and are not readable in the dark. Can read when on though.
  18. Dec 17, 2019 at 10:22 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Sounds like a solenoid failure then. Do you hear it pressurize at all?
  19. Dec 17, 2019 at 10:25 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    You could try taking the line from the front locker and connecting it to the rear solenoid. If diff locks then you know it is the solenoid!
  20. Dec 17, 2019 at 10:25 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    Please read through this thread. All is working. Thanks!
