Anybody have any other solutions for the low rear view mirror?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmasterj, Feb 26, 2009.
  1. Feb 26, 2009 at 1:29 PM
    jmasterj
    jmasterj [OP] Samsonite...I was way off!
    07 TRD Off Road
    I know there have been some threads about moving it up and turning it upside down and I have tried that and it is still bad. I am wondering if there is an aftermarket mirror that is thinner that would help out. I thought about remounting, but then I would have that black spot on the windshield and I am rather anal retentive. Between the A pillar and the mirror and having to duck down it is pretty dangerous.
  2. Feb 26, 2009 at 1:38 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Put it on the windshield, push the piece in the middle towards the roof as much as it'll go then set the mirror where you can see out of it. Haven't noticed it being any different than in any other vehicle. Even with the GPS mounted where it is under the mirror isn't causing any sight issues.
  3. Feb 26, 2009 at 1:43 PM
    jmasterj
    07 TRD Off Road
    Hmmmm, tried that. I am 6-1 and straight across the mirror to the A-pillar is a solid blind spot. I have to duck down at 4 ways stops and such to check the right side. Maybe it is just me?
  4. Feb 26, 2009 at 1:45 PM
    Hardcorehehaw
    Hardcorehehaw 1 man wolf pack
    Evan
    09 Magnetic Gray PreRunner
    Debadged, 20" Liquid Metal Magmas, Yokohama Parada Spec x 285/50/20, Llumar clear bra, Fold-A-Cover G4, Weathertech liners, Wet Okole seat covers, JBS technologies keyless entry keypad.
    recline your seat back a little maybe?
  5. Feb 26, 2009 at 3:15 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
  6. Feb 26, 2009 at 3:55 PM
    CtryBoyInMT
    CtryBoyInMT Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    It is mostly a rear window design problem. I've done the flip mod, and now it's so high, all I can get at that angle is the headliner, 2" above the tailgate and the tailgate.
    The roof line rolls too far down the back and the window is too low. Thats why they needed to mount the mirror so low. I've pretty much eliminated the rear view mirror from my scan, now.
  7. Feb 26, 2009 at 7:42 PM
    mdiehl
    mdiehl Member
    NE California
    2008 Tacoma 4x4
    helper springs
    jmastrj: Take it off and leave it off for a while...you'll notice the difference. It will be better. I have a similar thread about removing the black plastic/metal stud glued on the windshield, but I guess it is illegal in Florida. Sure hope your not from there. Tssk, Tssk. I wish I knew as much as I did at 24 than I do now at 59. Remember to watch the road!!!
  8. Feb 26, 2009 at 8:12 PM
    Okkine
    Okkine Well-Known Member
    Vancouver, BC
    2009 Magnetic Grey Access Cab - 2.7L I4 - 4x2
    I'm a little confused. I'm 6' even, and have never noticed any problems with the rear view. Perhaps your seat back is too far up?
  9. Feb 27, 2009 at 8:16 AM
    fritzthecat
    fritzthecat Well-Known Member
    Virginia Beach
    07 PreRunner Auto AccCab Indigo
    Same problem here. I'm 5'10 and the mirror was right in front of my eyes blocking the view. Even upside down it still interferred. I eventually bought another metal (not plastic!) mirror mount and glued it on a few inches higher. Now the mirror sits rightside up, all the way at the top. I can see perfectly out the back window. The old mounting block is just barely visible on the bottom of the mirror and not worth removing.
    [​IMG][​IMG]
    Fritz
  10. Feb 27, 2009 at 8:52 AM
    jmasterj
    07 TRD Off Road
    That looks much better Fritz. I am going to have to try that.
  11. Feb 27, 2009 at 8:59 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    ya I'm 6'4 and have had the same issues. I kinda learned to work around it and it isnt too bad of a problem
  12. Feb 27, 2009 at 9:20 PM
    raskal
    raskal Well-Known Member
    B.C.
    2013 DCLB TRD MGM
    hmmm,... I've never had a problem with it. I'm 5'7" though
    ha ha ... tall guys sux
    (first time in my vertically challenged life I've EVER got to say that)
