Anybody have experiece with Camburgs New ball joint UCAs?..........
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sincitytaco, Mar 17, 2009.
  1. Mar 17, 2009 at 6:08 PM
    sincitytaco
    sincitytaco [OP] Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
    I need to get a set and this look a nice set, It has a factory style ball joint which will be smooth and quiet, it has a tab to mount the ABS lines and it claims that it will correct the alignment issues.
    My questions are:
    1. I got my truck aligned today and they could not get the toe to be any less than 1 degree (I guess my tie rods ran out of length). And they also could not get the caster any where near correct. So will these arms make it so as that I can get an alignment to where it will correct both these issues? I need it to correct more than just Caster is what I am saying.
    2. Will these relocate my wheel in my wheel well hence possibly causing my tire to rub in a location it does not now (i.e the big ass mount that the cab is mounted to) I have about 1/2 inch of clearance now, but if it is moved back more than a smidge I will rub them when I am reversing FOR SURE!!!
    3. Will they make the truck ride better?
    4. Once this is done I want my truck to track straight as an arrow and have steering that firm and returns to zero with no help? Right now I need to assist it a little to return to zero. Will these accomplish this?
    Here is a link to them:
    http://camburg.com/images/05tacoma/tacoma%20bj%20uca%20info.pdf
  2. Mar 18, 2009 at 12:11 AM
    sincitytaco
    Las Vegas
    Well I guess then I should change my mind?????????
  3. Mar 18, 2009 at 6:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I havent run the new Camburg arms, but, They say they are supposed to correct the alignment. Yes, if it corrects the alignment, there is a good chance it may rub someplace else. The Camburgs have been known to be noisey. Its due to the Uniball used in the UCA. Have you considered Total Chaos? The TC's correct for alignment, and are nice and quiet.
  4. Mar 18, 2009 at 8:59 AM
    sincitytaco
    Las Vegas
    I think all UNI BALLS can be noisy, but these aren't uni balls, they are OEM style ball joints. Check the link. I had TC UCAs on a previous Tacoma, they were very noisy at times.
  5. Mar 18, 2009 at 9:05 AM
    luni
    luni Resident Gun-toting Hippie
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Icon c/os, TSB 4 leaf pack, Unbreakable Fab tube winch bumper, Mile Marker SEC12000, Roadless Gear winch control panel, Bud Built skids, URD Pipe Bomb Y pipe, snorkeled rear diff breather, no carpet
    I run TC UCAs and they're loud as hell when they get dirty. That just comes with the territory with uniball UCAs. Additional suspension travel and squeaking. An aftermarket UCA will help with the alignment. They're designed to correct the geometry after a lift.
  6. Mar 18, 2009 at 10:32 AM
    sincitytaco
    Las Vegas
    I am just weary of the Camburgs because I have heard of people not being able to get their truck aligned properly after install. I called camburg to ask what specs I could expect after install and they would not commit to anything so I am very weary.
    I decided to just get the TC UCAs knowing they work. I just hope I don't get a loud squeaky set.
  7. Mar 18, 2009 at 10:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Just be sure to rub grease all over the bushings before you install them, and they should be nice a quiet. I have had mine under water, had concrete dry on them, and all sorts of dirt and mud, and they are quiet as a mouse. How they are installed is the biggest factor in if they make noise.
  8. Mar 18, 2009 at 2:35 PM
    sincitytaco
    Las Vegas
    I will make sure they grease the hell out of them then. Thanks.
  9. Mar 18, 2009 at 3:17 PM
    sonjay
    sonjay Well-Known Member
    Light racing also makes a similar arm, with a factory style ball-joint. About the same price I think.
  10. Mar 18, 2009 at 3:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Even though they say they have worked the bugs out of the LR UCA's, Im still hearing of people that are haveing issues with them..
  11. Mar 19, 2009 at 10:30 AM
    sonjay
    Well that sucks. I was hoping to get a set, not for a little while though. Maybe they'll get the bugs worked out.
  12. Mar 19, 2009 at 10:36 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The new issue people are haveing is that the LR UCA's are not very consistant in their build quality. People that have installed them have been haveing alignments of 2.1* on the driver side, and 4.5* on the passenger side, for example. No one has been able to get a correct alignment with them.
  13. Mar 19, 2009 at 10:43 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    X2, with the advice from people here when I installed my TC UCA's last year I greased them up real good. Had them covered with mud, road salt and dust and never had an issue to date.
    Plus in my opinion the ride is great.
  14. Mar 19, 2009 at 10:46 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep. It seems that alot of people that have them installed have issues. Im thinking that the person doing the install, is installing the bushings "Dry", so as to keep his/her hands clean, or whatever, figureing the grease will eventually find its way.
