Anybody have issues with Duratracs?
Discussion in 'Wheels & Tires' started by lundy, Dec 29, 2011.
  1. Jan 6, 2012 at 3:18 AM
    #41
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    My only issue with the Duratracs is that I left them on the 05 when trading it for the 08. Got Silent Armors this time because I am prerunner and do mostly pavement driving. IMO, there is no better AT tire than the Duratrac. AT leaning more toward offroad tire that is. I consider my SA's AT leaning more toward pavement.
  2. Jan 6, 2012 at 5:07 AM
    #42
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    Shampoop, by dynamic balancing do u mean adding beads to the tires? What are your thoughts on adding dynabeads to already stick-on balanced tires? thanks
  3. Jan 6, 2012 at 9:20 AM
    #43
    lundy
    lundy [OP] Well-Known Member
    Justin
    Reno, NV
    2023 Double Cab 4x4
    Dynamic balancing would be weights on the inside and outside of the wheel when applicable or on an aluminum wheel it would mean having tape/stick weights on the portion of the wheel right behind the spoke and another weight on the inner most portion of the wheel or closest to the rear lip. Static balancing is when you only use weight in one section of the wheel. Dynabeads have worked well for a few customers of mine. Although most of them run large Toyo M/T's which are pretty round to begin with and usually require very little weight anyways so I don't of their experiences would be very accurate. Find somebody with swampers that runs them. If it helps them they'll help anybody!!
  4. Jan 6, 2012 at 10:31 AM
    #44
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    +1 to everything lundy said. Airun, just to make sure things are clear, dynamic balancing is not the same as adding beads. I would exhaust all formal balancing options(static and dynamic) before resorting to dynabeads.
  5. Jan 6, 2012 at 10:37 AM
    #45
    98tacoma27
    Ben
    Not Beech Creek
    I actually have roughly 6 oz worth of air soft beads in each of mine.
  6. Jan 6, 2012 at 11:09 AM
    #46
    YayAreaTaco0311
    YayAreaTaco0311 Motivator
    California
    '09 TRD 4x4 O/R Supercharged
    OEM TRD supercharger, OEM wheels painted black by me, yellow sidemarkers, arb bumper, LED interiors, roll-n-lock, 5% rear windows, mudflaps removed, protector alarm, mobile trace, blacked out front Toyota emblem, debadged, & tree air freshener.
    25K miles on mine and still going strong. It's my daily driver and I've been off-roading in them, lost count of how many times I hit the curb both when the vehicle is in motion and while parking, driven in the pouring rain, and ran over a few debris on the roadway and it's still holding up good. They are 265/75/16 with load range C on a stock supercharged Tacoma. I get them rotated every 5K miles when I get my oil changed. Would I buy it again? Fuck yes!
  7. Jan 8, 2012 at 12:19 PM
    #47
    alove0750
    alove0750 Well-Known Member
    Adam
    Concord, NC
    2015 DCSB 4x4
    Icon coilovers, shocks and springs SPC Upper Control Arms SCS Ray 10’s w/ 265/70R17 BFG KO2’s Leer 100XR shell
    I have 25K on mine with about 65 - 60 percent left. I will probably end up getting them again. They have done everything needed of them and then some in many cases. I have just made a point to rotate them religiously (every oil change/4000 mi) and no issues or un-even wear
  8. Jan 8, 2012 at 2:36 PM
    #48
    ryan c
    ryan c rookie
    ryan
    661 Lake Ez
    '06 4x4 swb dc
    2.5" lift in front, aFe air intake, anytime foglights, cut 9" off antenna, superwhite headlights, spintech exhaust, med. tint in the front, weathertech floorliners and caltech seat covers, dashtek dash cover, CHLM, debadged and destickered,
    got the same size. i got mine installed dec. 3rd. felt squirmy at 35psi americas tire co. set it at. heard about the chalk test o n here so ive now got mine down to 28 psi in front and 21 psi in the back and it still isnt rubbing the edges.
  9. Jan 8, 2012 at 3:03 PM
    #49
    Airun
    Aaron
    Show Me State
    Ok had mine rebalanced the other day after my last post and they are vibe-free and the sound is improved 50%. 3rd times a charm. Damn these things perform so well and look so neat it's hard to imagine anything better.
    I don't know of any shops around with a Roadforce machine or that do geometric matching. Very rural area. The shop I use is some older guys and the name on the bldg is the guy running the impact and the machine so I trust them. Knowing that I've hassled a bit with these tires they actually suggested I consider beads to constantly compensate for any changes. Of course they probably think I'm picky too.
    Oh well satisfied for now.
    What would be drawback of throwing a couple ounces of beads in each tire other than cost for little to no gain.
  10. Jan 9, 2012 at 9:56 AM
    #50
    Airun
    Aaron
    Show Me State
    thoughts guys, still following???????????????
  11. Jan 9, 2012 at 10:13 AM
    #51
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I'm on my 2nd set of them. I haven't had any of the issues stated above. I have about 20k miles on my current set of 285/70/17 D's and they haven't been balanced since they were first mounted and they still ride smooth. I haven't had to get them rebalanced. I rotate every 5k miles in a criss-cross pattern. They hum on the road but that's to be expected. If you're looking for a good AT tire, don't expect them to be quiet. They're great tires in the snow and ice (the rare times it does snow here) and they're great off road.
    My last set (265/75/16 C's) had about 27k miles when I sold them about a year ago and they still had plenty of life left in them. I actually saw the guy I sold them to recently and he was still riding on them. Here's a pic of them right before I sold them w/ 27k miles. We have a relatively warm climate here.
  12. Jan 9, 2012 at 10:25 AM
    #52
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    i loved mine when i had them and would have gotten them again if they made them in a 295 size.
    the only negative thing i could say about them was they tend to wander on the high way a bit this is most likely due to the huge amount of siping thats on them.
    i had called goodyear to ask about the siping and apparently it goes all the way down to the bottom of each lug. so each lug is in fact many lugs that are just spaced very close to one another if that makes sense.
    this is what goodyear had told me i took them at their word and it seemed to be correct as they did wander a bit at speed nothing bad but, it was noticeable.
    mine seemed to wear even although i didn't have them for a lot of miles. others i know that run them have really used them a lot and they also seem to really like them and have had way more time and miles than i did.
    mine also balanced out pretty well but, i road force everything
    so that may have something to do with it.
    i would also describe their grip as extreme they where awesome tires in that aspect! i don't think you will regret the purchase i sure didn't they also look great.
    i went with white out but if i had gotten them again it would have been black out.
  13. Jan 9, 2012 at 11:06 AM
    #53
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    The only potential drawback I can think of to Dynabeads is I've heard that in moist climates the beads tend to clump together (though the manufacturer says they don't clump, so who knows), which would negate their purpose (and even cause more vibes than without).
    Personally I view dynabeads along the same lines as putting nitrogen in tires: gimmicky, mostly because of cost. Yes, nitrogen stabilizes psi better than regular compressed air, but is it really worth the cost? Same way I feel about dynabeads (~$10/tire?!).
    PS, Dynabeads recommends 6 oz. per tire in a stock sized Tacoma tire.
  14. Jan 10, 2012 at 6:09 PM
    #54
    slodc4
    slodc4 Conceal Carry
    Steven
    Winterville, NC
    Locked 17 trd sport
    i have 10k on mine and they look new. I have very minimal vibrations, but that could be from my lift.
    these tires absolutely suck in thick sand. they just dig like crazy making it a fun time.
    ill probally buy another set
  15. Jan 12, 2012 at 12:56 AM
    #55
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    I have no experience with dynabeads or anything like them. I know how they're supposed to work, but know nothing about their effectiveness.
    The easiest way to think of the difference between static and dynamic balancing is that static only deals with the up and down imbalance, and only uses sticky weights in one spot in the exact center of the wheel.
    Dynamic balancing also deals with the "left and right" imbalance by placing weights either on the inner and outer lip, at different positions on the clock face or by using sticky weights as close to each edge as possible.
    Most vehicles today have wheels that have a "positive" offset, so because the spokes are so far from the middle of the wheel, you can place sticky weights behind them and still be putting them on the right side of the wheel. But some wheels have offsets closer to "zero", especially trucks with wider than stock aftermarket wheels. It ends up making it so that the farthest you can place the sticky weights to the right is still the center of the wheel, meaning you can't dynamic balance it. It's like trying to sit in the middle axis of a see saw and trying to balance the weight of your friend sitting way out on the seat. Lots of times, less experienced techs try to dynamic balance these wheels when they should just static balance them. Static imbalance is what causes by far most of the vibrations you can actually feel. I seriously think it may not even be possible to feel a dynamic imbalance in a truck.
  16. Jan 12, 2012 at 2:50 AM
    #56
    shooter3225
    shooter3225 Well-Known Member
    Tyler
    Riverside, CA
    09 TRD PreRunner
    So I live in So Cal where we don't get snow and ice but I was really leaning towards these tires. I am on pavement and off road a lot too..still a good choice? Seems as if most are highlighting their performance in snow and cold weather and I'm just curious if it's worth it for me to buy these.
  17. Jan 12, 2012 at 9:28 AM
    #57
    lundy
    Justin
    Reno, NV
    2023 Double Cab 4x4
    I think a lot of modern truck wheels get a lot of there offset from the thickness of the mounting pad. It's much cheaper for a manufacture to have only one mold and control the the offset by simply leaving a thicker mounting pad for a zero to negative offset or taking away more of the mounting pad for a positive offset. Thus leaving plenty of room to still get adhesive weights on the left and right side of the wheel.
    Though I do agree about the wheels that have little to no room to do a dynamic balance. People should not attempt it when the inner most weight isn't well beyond the the center line of the wheel (in the area that would be considered positive offset).
  18. Jan 12, 2012 at 7:23 PM
    #58
    RickN
    RickN Member
    Just bought mine so cant comment on how they preform but after driving with them for a few days I have no regret.
    What pressure do you guys run these? The tire shop set mine to 35psi.
  19. Jan 13, 2012 at 9:42 AM
    #59
    Airun
    Aaron
    Show Me State
    interesting, thanks for posting sham!
  20. Jan 15, 2012 at 10:01 PM
    #60
    santas212
    santas212 I'm on a boat!
    Georgetown, CT
    '09 DCLB, TRD Sport, Barcelona Red
    Mostly miscellaneous electronic mods.... -2 spare Electrical fuse blocks hard wired to the battery with a key on relay. -Hard Wired Radar detector over rearview mirror. -2 Dual Whelen Avenger blue LED emergency lights, one on each side of the rearview mirror. -EP911 Blue LED Light Bar & Traffic Advisor, Rear Windows. -4 corner amber strobes in stock lights. -Hardwired RF Scanner with external speaker under center console. -Huskyliner front splash guards -Fireband 2 way radio in center console. -Herculiner painted on hitch and skid plate. -Switch to power one 12v socket when truck is off. -AntiDark LED strip under hood with switch. -Timbren Rubber Springs - Rear -MBRP Offroad Cat-Back with Resonator -Duratrac's -Provisor -Color matched hood bug shield
    Doing some research on these i am seeing two different load ratings in the tire size i want. looking at 265/70/17's they have load C and load E. The load ratings come with varied top speed ratings as well something like 108 and 121, not that i need to be running anywhere near these.
    Just wondering what you guys think, i was wondering if the load E tire would be a more stable road & highway tire? They are a bit more expensive per tire, but i spend more time on road than off and don't want to encounter the "road squirm" or "softness" some people have talked about.
    This may be a product of the siping and not the load rating though. (i had to look up siping btw > basically it is a process of slicing cuts in the tire treads that add traction.)
    suggestions?
