ANYBODY INSTALL OME LIFT ON 2015 DCLB
Discussion in 'Suspension' started by Stellasonasty, Jan 19, 2015.
  1. Jan 19, 2015 at 5:51 PM
    Stellasonasty
    Stellasonasty [OP] Member
    Blake
    Northwest
    Under construction
    ARB is all over the map when i have called and talked to them about this subject, first the lift wouldn't apply to my truck then it worked on some trucks and now carb says it will work on about 75% of vehicles. I would love if any of you guys with a 2015 DCLB trade sport have installed this lift and if it worked for you. Thanks
  2. Jan 19, 2015 at 5:58 PM
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    The suspensions are unchanged but they haven't updated the specs to reflect new model years. They are trying not to make a mistake. I'm sure more will comment but should be fine.
  3. Jan 19, 2015 at 6:24 PM
    Stellasonasty
    Blake
    Northwest
    Under construction
    While talking to ARB today there are some Tacomas that the rear struts will not physically fit, period. but they haven't nailed down why and witch tacomas won't work. Guy at ARB told me today to take a picture of the rear strut and where it connect at the bottom and he could tell me if the 2014 kit would work
  4. Jan 19, 2015 at 7:15 PM
    TacoDeLaPlaya
    Bobby
    Del Mar, CA
    Oh well at least you got somewhere shouldn't be too hard to check that.
  5. Jan 19, 2015 at 7:17 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    It will work! Nothing has changed suspension wise on the 05-15 tacoma!
  6. Jan 19, 2015 at 7:22 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This is the 3rd time I've read that ARB says the rear shocks may not fit on the 2015's
  7. Jan 19, 2015 at 8:03 PM
    Stellasonasty
    Blake
    Northwest
    Under construction
    its defiantly true with all due respect. just looking for members who have put a OME on a 2015
  8. Jan 19, 2015 at 8:08 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    If nothing has changed from 05-15' then I don't see the issue
  9. Jan 26, 2015 at 7:59 AM
    euroshowoff
    euroshowoff Well-Known Member
    Stafford, VA
    15 Superwhite DCSB 4x4 V6
    Toytec lift, Trailgear sliders, CBI ditch light brackets, Trailtoys LED ditch lights, Trailtoys LED reverse pods, Custom Roll-Bar, TRD skid plate, TRD sport grill, TRD custom bedsides, Custom BlueSea wiring block, OTTRAW Rockers, Pro Comp 7036, BFGoodrich KO2s, Bestop soft topper,VIAIR 88p
    bump, did any information come out of this? I noticed a disclaimer posted at wheelersoffroad for the rear OME shocks:
    *1/6/15 NOTE: OME/ARB IS AWARE OF A FITMENT ISSUE WITH THESE SHOCKS ON 2015 TACOMA AND IS WORKING TO RECTIFY THE SITUATION.
  10. Feb 4, 2015 at 7:44 PM
    99sh
    99sh Well-Known Member
    DCLB
    Did we get closure on fitment on a 2015? I emailed ARB and they responded with the following:
    [FONT=&quot]We had the chance to test fit the suspension to a brand new 2015 Tacoma [/FONT]​[FONT=&quot]and did not encounter any issues. The information we received about the 2015 suspension not fitting was a fluke thing but we had to verify the fitment for ourselves. [/FONT]
    [FONT=&quot] [/FONT]
    [FONT=&quot]ARB Tech [/FONT]
    scocar likes this.
  11. Feb 5, 2015 at 10:54 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    I just talked with ARB. They have OK'd the fitment on 2015 models. There should be NO issues.
  12. Feb 5, 2015 at 1:56 PM
    99sh
    DCLB
    Would you accept returns if it doesn't fit a 2015 for whatever reason?
  13. Feb 5, 2015 at 2:23 PM
    TacoDeLaPlaya
    Bobby
    Del Mar, CA
    I really wish people would wait until official releases have been made by manufacturers before speculation and word of mouth put all this misinformation out there.
    The mounts are tight. And can easily be separated with a screw driver or pry bar. It is an issue that has affected other manufacturers as well. This is a truck made of metal not a plastic model that you can break on accident during assembly. Don't be afraid to use a hammer or other tool, or inginuity if you cannot get something to fit.
    Just like using a spring compressor...why do it unless your new springs are so stiff you can't use the wait of the truck to load or unload them...strut assembly and disassembly is 10x safer if you leave it in the truck and lower or raise the control arm.
  14. Feb 5, 2015 at 2:28 PM
    OZ-T
    Peter North
    British Columbia
    ARB is the manufacturer yo
  15. Feb 5, 2015 at 3:50 PM
    OICU812
    OICU812 Well-Known Member
    Thanks for that good information.
  16. Feb 7, 2015 at 7:46 AM
    big22
    big22 Member
    Devin
    texas
    2015 DCLB 4x4
    have them on mine with no problems
  17. Jun 27, 2015 at 9:15 AM
    scocar
    scocar Patron of the Farts
    This is good news. Been searching for a while to confirm or deny this issue. Now I can include 2015 in my quest for a DCLB.
