Anybody mod the trialer plug?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Country101, Apr 23, 2012.
  1. Apr 23, 2012 at 6:00 AM
    Country101
    Country101 [OP] Well-Known Member
    NW Arkansas
    08 tacoma access cab V6 4x4 manual
    dirty truck mod, custom trailer scratch on tailgate, husky floorliners, OME Lift
    My truck has the flat 4 prong trailer plug and I ended up doing some work on it. The factory location is crap for me. You cant see it unless you bend down really far and it has no give to be able to line it up. So, inevitably, you break off the ground plug, which I did. Since then, I have went to auto zone and gotten a new plug with a couple extra feet of wire and some of the wire protection that is similar to what they use in the engine. Cost a total of 10-12 bucks. I removed the bracket that it originally hung from and spliced all the wires to the new plug. It was convenient to zip tie the wires to one of the bolt holes of the bracket, so I did. I then ran the plug up over the license plate to a rectangular hole and shoved it through. I left just enough sticking out that it hung to the bottom of the bumper. Enough to let me move it around, but it not get into anything. But now I can see it and get it lined up without having to get down so low and not have to worry about breaking it off again. Makes hooking it up a lot easier. I had though about moving the mount to somewhere on top, but I like having it where I can move it around. I really dont like the flat plugs anyway, but until I put a brake controller on the truck, this will do. Then I will just switch out the plug and get an adapter to keep in the truck.
  2. Apr 23, 2012 at 6:16 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Sounds good! Just so you know, I don't believe any of the Tacomas came with a flat 4 from the factory so you likely spliced a harness added by a previous owner.
    Otherwise, sounds like you did it the right way and protected the wires with wire loom. :thumbsup:
  3. Apr 23, 2012 at 7:32 AM
    Country101
    NW Arkansas
    No, it came factory like this. I bought it new. It's a base model with no towing package.
  4. Apr 23, 2012 at 7:36 AM
    Geo Taco
    Geo Taco Well-Known Member
    Justin
    Lafayette, CO
    2012 Subie Impreza
    Black Softopper
    One quick question, was the rectangular hole above the license plate the pass-through for the spare tire?
  5. Apr 23, 2012 at 7:41 AM
    Country101
    NW Arkansas
    Yeah. There should be plenty of room for your tool to go through there to let the tire down though. It's only about 1/2 inch loom around the wires so there is still lots of room.
  6. Apr 23, 2012 at 7:46 AM
    Pugga
    Massachusetts
    Did it have a receiver on it?? :confused:
    I have a base model, no tow package and it didn't come with any wiring. I had to add the flat 4 connector myself. Was it a dealer installed wiring harness?
  7. Apr 23, 2012 at 7:50 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Thats why. You plug trailer package harness to that 4 point plug :)
  8. Apr 23, 2012 at 8:04 AM
    Country101
    NW Arkansas
    Yeah, I bought it with a hitch and the plug was already on there.
  9. Apr 23, 2012 at 6:18 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    My 06 base had a dealer installed 4 wire harness as well. I just rewired it two weeks ago for 7 wire, used the same "convertor" in the dash, just added the extra brake and charge wiring.
  10. Apr 23, 2012 at 6:25 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Maybe dealer-installed or something, but I can assure you that no 2nd Gen Tacomas came with a 4-pin connector. The base model has nothing.
    The models with the towing package have a 2" receiver, trans cooler, and a 7-pin connector next to the receiver.
    Even though they provide a hole for it, Toyota does not recommend towing with a ball mounted to the bumper.
    BTW: Without the towing package, your limit is 4500 pounds, tongue weight on the bumper is likely under 500.
  11. Apr 23, 2012 at 9:23 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    5000/500 lb. on mine, 06 base doublecab, 4x, 1GR 6spd. The owners manual doesn't say that, but the original window sticker with matching VIN does. Bumper is limited to 3500/350, but I wouldn't go anywhere near that without a hitch.
  12. Apr 23, 2012 at 9:26 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Yikes!
    I figured the bumper would be good to the non-package truck rating.
    But I did install a Reese shortly after I got the truck.
  13. Apr 24, 2012 at 5:08 AM
    bikinit
    bikinit EXTREME...poser
    Mass.
    '12 TX Pro DC SB V6
    Forgive my ignorance, but can I buy an adapter for the OEM trailer set up that let's me connect to the uhaul trailers's rectangular connection???
  14. Apr 24, 2012 at 5:34 AM
    Country101
    NW Arkansas
    My truck came with a hitch and the flat plug when I picked it up new. whether the dealer put it on or not, I dont know. Anybody have a picture of the transimission cooler so I can look to see if I have one?
    Bikinit, I would imagine you can. I have seen quite a few differant types of adapters at auto stores and stuff like that, but I am not sure about that specific kind. A general google search may find you something pretty quick, or just a call to your local parts store.
  15. Apr 24, 2012 at 6:51 AM
    bikinit
    Mass.
    '12 TX Pro DC SB V6
    thanks I'll check it out.
  16. Apr 24, 2012 at 7:06 AM
    Pugga
    Massachusetts
    Yes, you can. It's a plug and play unit and costs about $30. It plugs into your tail lights and has a control module that sticks with double sided tape behind where the tail lights go. Then you just run the wires where you need them. Total install can be done in about 10 minutes, 30 if you take your time.
    Uhaul's connection is called a 4-pin. It's a common connection for trailers that don't have brakes or, in the case of Uhauls larger trailers, have surge brakes.
    These kits can be found online at places like JC Whitney or Autoanything or I'm sure you could pick one up at Uhaul.
    Edit: Here's the kit (you'll want the flat 4-pin option). I guess pricing has gone up a bit. Shop around, I think I got this same kit for around $30.
    http://www.autoanything.com/towing/75A3875A0A0.aspx
  17. Apr 24, 2012 at 7:17 AM
    jeckel7234
    jeckel7234 Well-Known Member
    Drew
    VA
    05 Tacoma
    Add-a-Leaf, Leveling Kit, 31.5 Nitto Grapplers, Mag-Lite Mod, Anit-Key in the ignition beep mod, Tail gate theft mod, Trifecta tonneau cover, washable cabin air filter,
    I think ive seen somewhere on this forum where sombody cut out a spot on there bumper and attatched the oem plug in it, Ive thought about going town to a ford dealer and getting the double connector the newer ford trucks have with 4 and 7 pin and putting that in the bumper, maybe one day
  18. Apr 24, 2012 at 7:25 AM
    berg2065
    berg2065 Well-Known Member
    Phoenix
    11 reg cab 4x4
    5100's set at .85,eibachs, LR uca's, toytec 1.5" aal, ride rite bags, receiver hitch, ARE cap with bedrug, Thule rack, wet-okole cover, ultragauge, kenwood dnx5180 navi/receiver, ss rubi404 running factory doors and JL8
    you don't have to worry about the tranny cooler since you have a manual. the coolers are for autos only.
  19. Apr 24, 2012 at 7:53 AM
    bikinit
    Mass.
    '12 TX Pro DC SB V6
    Very helpful and useful posts all, thanks. This forum is much more active than my MC forum. It's hard to keep up.
  20. Apr 24, 2012 at 8:56 AM
    Country101
    NW Arkansas
    Thanks for that info berg. I'm not much on vehicle knowledge. Never was around it much.
