Anybody put a steering stabilizer on a 3rd gen?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jkensrud, Sep 26, 2019.
  1. Sep 26, 2019 at 9:25 PM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Also balanced and new tires. 3 different wheel alignments (because I'm extremely OCD about alignments)
  2. Sep 26, 2019 at 9:28 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Did you throw UCA / LCA on at trying to fix the problem, or did you throw rack / tie rods on trying to fix the problem after changing UCA & LCA created the problem?
  3. Sep 26, 2019 at 9:30 PM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    I did the UCAs because I went with JBAs for the lift. The lowers I changed because the original ones were pretty bad from the previous owner. The rack I changed because it was leaking and had to get replaced eventually. And with that came new tie rods. Honestly dont recall the bump steer before the lift. But also I should mention that the previous owner had a spacer lift on the truck when I bought it.
  4. Sep 26, 2019 at 9:33 PM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Also no play in any of the components. Also got new cam bolts from toyota because the previous ones were pretty ugly
  5. Sep 26, 2019 at 9:35 PM
    mutely
    With all that, you probably have the geometry going out of wack as the suspension rises or lowers. Either the UCA or LCA is not designed/ setup to work with the other. Take it to a shop than knows how to measure/ set this and they will figure it out. Or you can pull the shock, and cycle/cycle/ re cycle the suspension and figure it out.
  6. Sep 26, 2019 at 9:43 PM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Well its toyota LCAs and the JBAs are tacoma specific. So I dont know how that wouldn't be set up for the truck. And the shocks are Bilstein 6112s, set at notch 4. It tracks completely straight and will do that even at 70. But slow speed bumps, will definitely throw me around. Not to the effect of the steering wheel shifting, but enough to annoy me.
  7. Sep 26, 2019 at 9:44 PM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    I'm even considering removing my sway bar
  8. Sep 26, 2019 at 9:49 PM
    tcjacado
    tcjacado Well-Known Member
    How much lift is that providing?
  9. Sep 26, 2019 at 9:53 PM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    One big problem is I never measured the before height because it was already lifted with the spacers. But if I had to make an educated guess, I'd say at a solid 3 inches. Rear is 1.5 inches higher than the front. All current measurements are even left to right
    tcjacado[QUOTED] likes this.
  10. Sep 26, 2019 at 9:58 PM
    tcjacado
    I am gonna have to say that's more than likely your issue right there. What springs are you running, just because they have a notch that high doesn't mean its recommended to run it there. Lower that clip and get mew springs that are specific to your needs.
  11. Sep 26, 2019 at 10:00 PM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Running the 600s. But I originally put it at that notch because the plan was to get a bumper and winch. But that has to wait now. And pulling these things out to change the notch multiple times is a PITA
  12. Sep 26, 2019 at 10:01 PM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Also, I kept asking around if lowering to notch 1 or 2 with 700 springs with get me the same height and NO ONE could get me a straight answer on that. Not even the vendors
  13. Sep 26, 2019 at 10:03 PM
    tcjacado
    Because you need to look at toytec or ome springs. 888 or 887s
  14. Sep 26, 2019 at 10:04 PM
    mutely
    I’ve never been a fan of Bilstein for off-road applications and I’ve never see enough rebound dampening for the unsprung weight people add these days, but I doubt that’s your problem. A good shop will be able to sort it in no time, but finding one and their cost you may not like. Do you have the cam set correctly in the UCA, that’s probably the first thing any shop would check:
    EDIT
    Other thing to remember is your alignment was done at static sag. You may need the alignment done at deferent travel heights to get to the root cause.
  15. Sep 26, 2019 at 10:07 PM
    #35
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Those springs are for 5100s. I have 6112s
  16. Sep 26, 2019 at 10:08 PM
    #36
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    The JBAs aren't adjustable. They just allow for more adjustment on the cam bolts when doing an alignment. But 2 separate shops gave me caster readings of almost 4 and nearly zero on everything else.
  17. Sep 26, 2019 at 10:08 PM
    #37
    tcjacado
    Pretty sure they are the same, just larger diameter, but the springs should still be the same application (meaning should fit)
  18. Sep 26, 2019 at 10:11 PM
    #38
    tcjacado
    I have only seen people run into issues with setting it any higher than the second clip or at least being happy with the ride quality.
  19. Sep 26, 2019 at 10:12 PM
    #39
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Oh yeah ride quality is definitely shit. But I expected that so it didnt bother me. Plus when the added weight finally does get installed. I'm expecting it to soften out a bit. I just hope that weight also helps with the geometry issues as well
  20. Sep 26, 2019 at 10:14 PM
    #40
    tcjacado
    It will to a point, but I am afraid your coil will be almost completely compressed at that point.
