Anybody rebuilt a 2nd gen Starter? Parts source?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bluevan99, May 13, 2014.
  1. May 13, 2014 at 12:50 PM
    bluevan99
    bluevan99 [OP] Active Member
    07 DC LB SR5 TRD Sport
    My 07 4.0 4wd has the single click symptom which seems to fit the bad contacts scenario. All the writeups seem to be for first gen trucks. When i called all the parts stores, including the dealer,and several online sources, they all say a rebuild set is not available for the newer models and a reman/new starter is the only option.
    Anyone done the repair and can point me to where they found the parts?
    in the event that a replacement is the only option, the remanufactured options ($125) in my local stores are duralast, ultima, and rayloc. Any opinion? Thanks!
  2. May 13, 2014 at 1:13 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
  3. May 13, 2014 at 1:23 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    A starter and alternator repair shop will have the parts.
  4. May 13, 2014 at 1:34 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    There is no single kit but you can get all parts required
    Here is good place to start
    http://www.trademotion.com/parts/2007/Toyota/Tacoma/Base/?siteid=214001&vehicleid=190117§ion=STARTER
  5. May 14, 2014 at 8:21 PM
    bluevan99
    OP here, thanks to all of you for the tips. I was unable to find a local source here in San Diego but i did find an online source, pricey at $34 but thats like i guess.
    However I don't know if i'll even need it because i'm stuck on the top bolt of the starter which just won't budge. Everything else went like a breeze. There is just no clearance from any angle to get leverage on that thing because the exhaust is right in the way. I'm gonna try again in a day or two when i get some time but i don't think its worth it to me to take the exhaust manifold down just for this as that will be a bit more of a project than i was expecting. Any tips from someone with a same setup 07 4wd 4.0 who did this fix without taking the exhaust off?
  6. May 15, 2014 at 8:50 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    no direct advice on a taco....but my 4runner was also 'unpossible'
    get some looong extensions and two u-joints and come at it from far away
    on my 4runner I had to take the pass front wheel off, and squeeze up past the front axle assembly and over to the bolt with about 3 feet of various hardware and a deep socket. it came off though, even though logic dictated I had too much junk....I torqued all that crap up and cliK, bolt popped loose
  7. Jun 17, 2014 at 2:05 PM
    bluevan99
    Thanks to those who offered advice. I just wrote up a lengthy step by step for this but the stupid forum had timed me out while i writing it so when i hit post all my work was lost and i'm not spending another half hour redoing it. Suffice to say i got it done with a relatively easy method through the wheel well with a couple of tools. PM me if you want some help i'll be glad to. My 07 4.o 4wd could not be done with the methods described in other threads and the suggestions made in this thread.
