Anybody running 285/60-18's?
Discussion in 'Wheels & Tires' started by S7ICKlVlAN, May 21, 2009.
  1. May 21, 2009 at 10:03 PM
    S7ICKlVlAN
    S7ICKlVlAN [OP] Cpt. Bubbleguts
    Dave
    Hawaii
    2012 TRD Sport DCSB
    TRD badged | Hunting Cage | Smoked Tails | LED Everything | Slim Cubby HID bi-xenon's | Spidertrax 1.25" | BHLM | FLM | S2000 Ant | 20% Shade | PL 8521 | OME 885 | Bilstein 5100's | Toytec 2" AAL | FN 18x9" Bronze BFD's | 275/65-18 Duratrac's | Wrinkle Red Valve Covers | 3M Di-Noc Wrapped Interior | Kode MB Push Button Ignition | Relentless Sliders | URD TCAI | Mr.Marv Enclosure | Arc Audio 10" | Hybrid Audio Clarus F/R | Alpine PDX-5 | Alpine INE-S920HD
    If so, can you post pics of how they look from the side as well as any other shots that give an idea of the profile? Eg. 3/4 front, rear, etc....
    Thanks in advance!
  2. May 21, 2009 at 10:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Thats the size Im running. Check the photos in my gallery. :)
  3. May 21, 2009 at 11:29 PM
    S7ICKlVlAN
    Dave
    Hawaii
    2012 TRD Sport DCSB
    Excellent pics Chris. May I ask what backspacing you have on those wheels and if the tires sit flush with the edge of the fenders (as it appears to in the pics)?
    Thanks bro, sent you some reps.
  4. May 21, 2009 at 11:32 PM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    Chris4x4 has 4.5" backspacing. Check my gallery as well, although I'm running 285/65/18 but same rims and backspacing as Chris4x4
  5. May 21, 2009 at 11:45 PM
    S7ICKlVlAN
    Dave
    Hawaii
    2012 TRD Sport DCSB
    Thx Bluez. I think I almost have the wheel & tire package set for my upcoming Tacoma. Would you say I need at least a 3" lift or can I keep it stock for now? OD on the 285/60-18's should be just about the same as stock.
  6. May 22, 2009 at 6:15 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    285/60/18's are considered a 32" tall tire. Mine were 31.5" talll when new. :)
  7. Aug 12, 2009 at 7:43 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    Im gonna bring this thread back to life...
    Can someone explain to me how you get a backspace, I know what an offset is but is this backspace pretty much the same thing? Is it the way the rims are manufactured?
  8. Aug 12, 2009 at 7:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Back space is the distance from the hub mounting surface on the wheel, to the lip of the rim.
  9. Aug 12, 2009 at 7:58 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    ok thanks, so can a backspace and an offset be directly related? like would a 4.5'backspace be equivalent to a certain offset..
    and how did I know you would answer my question? o thats right cause you have 24,000 posts ;)
  10. Aug 12, 2009 at 8:01 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Offset. The distance from the centerline of the wheel to the face of the mounting surface of the wheel that contacts the hub.
    Zero Offset. Indicates the mounting surface is at the wheel center.
    Negative Offset. Indicates the mounting surface is behind (or inboard) the centerline of the rim. This is often found on standard rear-wheel-drive vehicles and on so-called reversed rims. (Diagram below shows negative offset)
    Positive Offset. Indicates the mounting surface is in front of (or outboard) the centerline of the rim. This is often found on front-wheel-drive vehicles. Stock Tacoma wheels have Positive offset.​
    Backspacing. The distance from the mounting surface to the inside lip of the wheel. This measurement is closely related to offset (without actually measuring, backspacing is about equal to [Wheel Width / 2] + [Offset] + [about 1/4] ).​
  11. Aug 12, 2009 at 8:04 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    awesome it all makes sense with a lil math!
    thanks chris your the shizznit!
  12. Aug 12, 2009 at 8:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
