Anybody running 5W-30 in 2n gen. 4 banger?
Discussion in '4 Cylinder' started by Deer Slayer, Nov 13, 2009.
  1. Nov 13, 2009 at 1:52 PM
    Deer Slayer
    Deer Slayer [OP] Active Member
    NW Mississippi
    08 4X4 I4 MT Acc Cab
    I know that 2nd generation 4 cyclinder engines call out 20 grade oil, but was wondering if anybody running 5W-30 oil in their engines and if they had any problems or benefits associated with it versus 5/0W20 oils?
  2. Nov 13, 2009 at 2:00 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I run 5w-30 in my 05. It's also the recommended viscosity in my manual. Maybe they changed it somewhere between 05 and 08?
    I can't say that I've had any problems or benefits from it.
  3. Nov 13, 2009 at 2:46 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    I have run both in my '08 4-popper. So far the mix has been 50-50. It's still runnin'.
  4. Nov 13, 2009 at 2:50 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I would not run a thicker oil than it calls for. The engine and the oil controlled VVTi system are designed to run on 0w20 or 5w20. JMO.
  5. Nov 13, 2009 at 2:55 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    run the 5w-20 or 0w-20 read the manual man
  6. Nov 13, 2009 at 7:19 PM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    X2 its 5w20 for me
  7. Nov 13, 2009 at 7:19 PM
    Kelson
    Kelson
    Honolulu, Hawaii
    its on the oil fill cap as well
  8. Nov 13, 2009 at 8:39 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    2019 SR/SX Tacoma Access Cab 4x4 3.5L
    I run 5W-30 with no ill affects. If you "read the manual", it also has wording that allows you to make a judgement call to go to a higher weight if needed.
    Nothing wrong with the 0W-20 or 5W-20 call outs but that is mainly to meet CAFE requirements here in the USA. Like or same engines outside the USA in ASIA and elsewhere, still call out heavier weight oils.
    Truth be told, most 30 weight dino oils actually shear down to a 20 weight within 500-1500 miles. What makes 5W-20 and 0W-20 oils excellent in most regards, is that they will not shear as much and maintain within the spec of a 20 weight oil.
    Baby Jesus does not cry if you are using either a 5w-30 or 10W-30 in your Tacoma.
  9. Nov 13, 2009 at 8:49 PM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    I'll be using M-1 0w20 when I hit 5k.
    As far as CAFE requirements, yes the 5w and 0w are going to give you slightly better mileage. I consider this a bonus ;) And like Hootbro said, you DO have some leeway in what you add to the crankcase... but why stray from manufacturer's recommendations?
    Remember to check out Advance's sale this month- 5 qts. Mobil 1 plus Mobil filter for 29 bucks :)
  10. Nov 13, 2009 at 8:58 PM
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    EXACTLY! I took advantage of this deal last weekend (had to buy the 6th quart at regular price though). Mine's full of Mobil-1 0w-20 now.
  11. Nov 14, 2009 at 11:32 AM
    tiger955
    tiger955 Well-Known Member
    Carson City
    06 Access 4WD
    trd suspension
    I was talking with the service manager at my local Toyota dealership yesterday and he was telling me that they are seeing noticeable improvements in fuel mileage using Mobil 1 0W20 in the 4 cyl Tacos. They see a slight improvement in other vehicles/ motors, but the 4 cyl Taco is very noticeable. I am going to try it next oil change.
  12. Nov 14, 2009 at 2:33 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    I'm pretty sure the dealership puts 5w-30 in when they change to oil, since it's been written on the little sticker they put on the windshield a couple of times.
  13. Nov 14, 2009 at 3:12 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    remember though that a 20 grade oil offer less protection than a 30 grade oil. It's been proven in various tests. The protective oil film breaks up easier.
  14. Nov 14, 2009 at 4:44 PM
    def4pos8
    def4pos8 Well-Known Member
    Ohio
    White Tacoma AC 2.7L/5spd SR5
    undercoat, running boards
    I use AMSOIL 0W-30 in mine. No problems.
  15. Nov 14, 2009 at 5:04 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    im doing 5w-30 and i love it
  16. Nov 14, 2009 at 8:04 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    What tests? Links? Please do not reference some "4 ball wear test" that is not relevant to automotive engine environments.
  17. Nov 14, 2009 at 8:12 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    It really does not matter too much. You can talk about various tests, etc, but there is really not much of a difference. You may lose some ponies/mpg with 30 compared to 20.
    However using a weight that is not listed in the manual could lead to troubles getting things repaired under warranty.
  18. Nov 14, 2009 at 8:40 PM
    afd23a
    The Dynamo of Dixie
    I don't know what they recommend for years other than 05. I'd think it would be the same for all of the 2TR-FE engines, but maybe not. Here's a couple of pics from my owner's manual AND oil cap. They both say 5w-30. I've considered running 0w-30, but figured I'd stay with what is recommended for now because I already had a crap load of it.
    Bottom line: I don't really care what you run, but a great recommendation is what is in your owner's manual and marked on the oil cap. Here's what's on mine. Seemingly from above posts, yours may be different.
  19. Nov 14, 2009 at 9:47 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    My 06 is the same as the above post -- 5w30 recommended both in the manual and on the oil filler cap. I have not run anything else and of course it seems to work just fine, so I cannot comment on any difference from the 0w20 oils. Running 0w20 will allow slightly better oil flow on cold/dry starts and probably give slightly better fuel economy but not much. It might help some vehicles to use the lighter weights in colder climates because of the added flow on cold start, but then it does not matter so much once the engine and oil are up to temp. Just use whatever oil is recommended in your manual and change it regularly, that's what I always say.
  20. Nov 15, 2009 at 7:11 AM
    def4pos8
    Ohio
    Well, you're right --sort of.
    The idea that viscosity equals protection is/was mostly true with dead dinosaur lubricants.
    High-end synthetics are engineered to produce certain results.
    I use AMSOIL 0W-30 in my two-dimensional travel vehicles.:burnrubber: I use AMSOIL Racing Oil 15W-50 in my three-dimensional vehicle.:plane: The 0W-30 actually performs BETTER than the 15W-50 in the ASTM three-ball wear test.
    Does that difference mean that I should run the 0W-30 in the airplane? NO! The aircraft runs constantly at 75% power and is air/oil cooled. Does ANY automotive engine run constantly at three-quarters' power for three to four hours per cycle? Some commercial diesels might but, generally, no. Even though that 0W-30 can protect, say, the piston pin bearings, better than the 15W-50 in the test, it won't endure the heat and high power requirements of the aircraft engine.
    That's why all vehicle makers have separate oil drain interval suggestions for severe service. If you actually run your engine at, say, 50% power while towing a trailer at maximum combined vehicle weight rating, the increased stress on the engine lubricant demands a shorter drain interval.
    :stirthepot::smash:
