anybody running without swaybar
Discussion in 'Suspension' started by bajamoon, Apr 1, 2009.
  1. Apr 1, 2009 at 10:15 PM
    bajamoon
    bajamoon [OP] Well-Known Member
    STEVE
    Whittier
    i am thinking about taking off the sway bar, how does it handle off road, street, i just think it is holding the handling back, but i don't want to go under the truck and disconnect anything if people don't like the way it handles, mainly will be doing desert and some trails, no rock crawling. thanks in advance.
  2. Apr 1, 2009 at 11:45 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    I read on I think total chaos website under the spindles that when you put tc spindles on they actually take the sway bar off since its not necessary. I guess the suspension performs better. Lemme see if i can find it....
    3.5” 05+ Tacoma Prerunner/06+ FJ Cruiser 4x2/03-07 4Runner 4x2 - Lift Spindles
    Finally a race inspired bolt on lift spindle for your 2005+ Tacoma Prerunner, 06+ FJ 4x2 and 03-07 4Runner 4x2. TOTAL CHAOS spindles are designed to add an additional 3.5” of lift and can be installed with existing aftermarket mid travel upper control arm and coil over shock packages. These systems combined provide 6”+ of lift and maximum cross member ground clearance, allowing you to Install up to a 35” tire. Our tubular tower and plate design features internal gussets along with overlay plates to add strength and reinforcement to proven weak areas. The tower includes a tapered bung that offers a pocket to access the aftermarket uniball conversion nut or thefactory ball joint. The CNC machined billet hub includes a one piece bearing carrier, and caliper mounts that are integrated into the boxed main body. To maximize strength, TC’s spindle was designed to not retain the factory sway bar. With the heavier spring rates of aftermarket coil over shocks and the increased track width provided by the spindles (3/4” per side), the sway bar removal is not noticeable. Removing the sway bar also allows for maximum wheel travel and articulation which will greatly improve the vehicles off road handling and performance. TOTAL CHAOS lift spindles come powder coated black and include a pair of D.O.T. approved stainless extended brake lines. Lift spindles that are intended to be installed with TC long travel systems must be specified at time of purchase. ABS wire tabs and brake line tabs are included to aid in routing the lines away from contact areas to prevent damage to these components.
    These will fit 6-lug 2WD vehicles only!
    I dont know of anyone who has taken it off though so I cant vouch for that. Wouldnt hurt to try
  3. Apr 2, 2009 at 3:29 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I wouldn't take it off.
    Surely, you could drive around with it off and you might not notice anything.
    But, if you ever had an emergency situation and had to quickly swerve around something...... that could be the difference between the vehicle staying on all 4 wheels or .....on two and on its roof.
    For offroading, disconnect them as needed. Keep it connected for on-road use.
  4. Apr 2, 2009 at 6:33 AM
    bajamoon
    STEVE
    Whittier
    that was the main thing keeping it on, i will disconnect before i go off road. thanks guys.
  5. Apr 2, 2009 at 7:05 AM
    OGSpacePimp
    OGSpacePimp Member
    Gainesville, Florida
    99 x-cab, bagged on 18s and being shaved
    bags, 18s, front inner fenders tubbed, shaved: hood squirters, corner lamps, antenna, door handles, tailgate handle, 4x4 fenders, 95 - 97 4x4 bumper/valance, 98 - 00 4x4 grill, 96 sr5 buckets, tubular control arms, 4 link, step notch w/ cover, and lots of other misc. stuff
    i ditched mine when i bagged the truck, but i ride 2-3" off the ground, so no worries, on anything stock or higher i wouldn't want to take it off on the road
  6. Apr 2, 2009 at 9:44 AM
    sonjay
    sonjay Well-Known Member
    I've taken mine off, and will not be putting it back on. It handles so much better on gravel roads, and off road. I can hardly notice any difference on road, slight body roll on hard corners, I don't drive fast anyway.
    Hoff likes this.
  7. Apr 2, 2009 at 12:47 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    x2 for janster
  8. Apr 2, 2009 at 10:00 PM
    bajamoon
    STEVE
    Whittier
    i will try it, we will see, thanks for the input fellas.:)
  9. Apr 2, 2009 at 10:13 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    2021 TRD Off-Road 2wd Cement Grey
    Bilstein 6112/5160 set at notch 2/3, OEM TRD Pro Wheels, 275/70/17 Falken Wildpeaks, OEM TRD Pro Grill, Debadged, Ceramic Tinted Windows
    I took mine off and then put it back on. I have a DC with Icons. I am getting the TSB leafs tomorrow and I am going to wait and see how it handles before I consider taking off agian. I drive on the freeway alot and I drive fast, so I think I am better with it.
  10. Apr 14, 2009 at 1:30 PM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    I just took mine off. Wow suspension is soooooo much sweeter, but I can really feel the body roll on corners. I'm gonna leave it off for a few days and see how I like it, most likely ill be putting it back on since I have a 6" lift :eek: that could be dangerous.
  11. Apr 14, 2009 at 1:52 PM
    bajamoon
    STEVE
    Whittier
    let me know how you like it in a couple of days. thanks for the info
  12. Apr 14, 2009 at 1:58 PM
    TEX357
    TEX357 TX
    05 TACOMA
    285\70-17 BFGoodrich KM2's 17x8 Pro Comp 7089
    Personally i wouldnt take it off, just because i would know i could flip a lot easier!
  13. Apr 14, 2009 at 4:18 PM
    06Bluez
    Phoenix, Arizona
    06 4x4
    With a like a 2.5" lift I would prolly do it but nothing higher. Im just gonna test it out tho since I already have it off and am to lazy to throw it back on today.
  14. May 3, 2009 at 8:18 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Those that have removed it, we'd like to know what you think.
  15. May 3, 2009 at 8:20 PM
    stikkimikki87
    stikkimikki87 Well-Known Member
    Pensacola FL
    d44, 37s, all 4 wheels turn!
    uhh...everything? lol
    ive had mine off for a LONG time (pre SAS)...... always seemed fine to me
  16. May 3, 2009 at 8:24 PM
    cjag
    cjag Active Member
    Georgia
    07 TRD OFF Road 4x4
    www.cardomain.com/ride/2537226
    May be a dumb question, but has anyone heard/seen of sway bar dis-connects for 2nd gen Taco's? I know we used to run them on our Jeeps "back in the day":D
  17. May 3, 2009 at 8:39 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    I've been looking for the same thing. Nothing yet. I may need to raid the hardware bin at Lowes for some Grade 8 stuff and fab my own.
  18. May 3, 2009 at 8:40 PM
    stikkimikki87
    Pensacola FL
    make sure it doesnt get caught in a cv boot...it wont be fun if it does
  19. May 4, 2009 at 9:56 AM
    sonjay
    I love it without my sway bar, I hardly notice any difference in the corners. The suspension reacts much better.
  20. May 4, 2009 at 11:05 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i removed mine, eventhough the CO's i have will allow it to bolt back up the exact same way it was stock w/o any brackets. the only thing i've seen change is the body roll in fast, tight corners....besides that, i love it w/o the swaybar
