Anybody seeing this?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HondaGM, Nov 18, 2009.
  1. Nov 18, 2009 at 6:28 AM
    HondaGM
    HondaGM [OP] Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    i push the recirculation button on the ac,go about a mile and it cuts off,push back on and cuts off about every mile............:confused:
  2. Nov 18, 2009 at 6:39 AM
    flatlander
    flatlander Well-Known Member
    09 DC-LB 2WD Prerunner V6 Auto
    Mine has never done that while running AC. But since it has gotten cold here and I was using the heater yesterday, I pushed the recirc button and it turned on. A bit later I looked down and it was off. Pushed it on again and it is on look down later and it is off.
    I was going to look through the owner's manual to see if it is even supposed to work with the heater, which I think it should, but maybe we have discovered a bug?
    Others, experiencing this?
  3. Nov 18, 2009 at 6:56 AM
    HondaGM
    James
    South-Pole
    i didnt have ac on or heat,i pushed recirculation button so cold air would not come in,this morning was also the first cold morning.
  4. Nov 18, 2009 at 7:24 AM
    RogueLeader
    RogueLeader Well-Known Member
    Rod
    Las Vegas, NV
    2011 Tacoma Double Cab SR5 TRD
    This is a problem with a lot of Toyotas. My FJC did that as well. Has something to do with temperature and outside air. There are several threads about this on the fjcruiser.com forums. For some reason, this doesn't happen with the wife's '09 Corolla.
  5. Nov 18, 2009 at 7:28 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Doesn't happen with my 1st gen.
  6. Nov 18, 2009 at 7:29 AM
    Warren Thompson
    Warren Thompson GeoTaco
    Warren
    Elko, Nevada
    '06 Tacoma DC TRD Sport RadRed
    I have had no problem with the Recirc button in my '06 TRD Sport. I use it often and until I turn the ignition off, it stays on, all the time:).
    Must be a problem with the later model year Tacos...:mad:
  7. Nov 18, 2009 at 7:32 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What else do you have on the controls?
    I've seen this before....but I think there's some combination of having it on defrost or some other selection that it does act weird. I just never figured out what that was. Almost like....you can't have it on Recirc and defrost at the same time?? Due to the humidity can build up?
    THat's a wild guess....
  8. Nov 18, 2009 at 7:37 AM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    No problem with the Recirc button in my '08 TRD Sport. It's always on weather the a/c is on or off. hmmm...anybody else???
  9. Nov 18, 2009 at 7:37 AM
    Slippy_McBrownfingers
    Slippy_McBrownfingers Active Member
    Slippy
    Texas
    2010 BSP DBL 4x4 TRD OR
    V1 Hardwire, Roll-N-Lock bed cover, Bed mat, Garmin Nuvi, Whelen Undercover Siren, Whelen LEDs
    Same problem here. Seems to do it when I'm on the heat side of the temp dial. Very frustrating.
  10. Nov 18, 2009 at 7:41 AM
    HondaGM
    James
    South-Pole
    thanks for the info,i read it and its got something to do with the windows fogging,it says to over ride it from doing this you must hold the rec button for 2 sec and release,i'm going to try it on the way home.
  11. Nov 18, 2009 at 8:52 AM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
    mine seems to always stay where I put it on my 09'. I sure hope I didn't just jinx myself now. If I did you SUCK!
  12. Nov 19, 2009 at 5:24 PM
    VORTMAX_99
    VORTMAX_99 Member
    Noticed this when I first got my "09. The trick to this is that you have to hold the recirculation button for 3 to 5 seconds. If you don't...it reverts back to outside air within a couple of minutes.
  13. Nov 19, 2009 at 5:54 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    From the Owner's Manual:
    If the ambient temperature drops while using the recirculated air mode the air intake mode automatically changes from recirculated air mode to outside air mode after a few minutes.
    To cancel this function:
    Press and hold for longer than 2 seconds.
    To reactivate this function:
    Turn the engine switch to the LOCK or ACC position.
  14. Nov 19, 2009 at 7:25 PM
    flatlander
    Thanks. I think that explains why it only happens on mine when on heat and it is cold outside. Works perfectly in the summer with AC.
  15. Nov 20, 2009 at 9:16 AM
    HondaGM
    James
    South-Pole
    yep,works if you hold for 2 to 3 sec...........thanks for the info.
