Anybody tried "Water Wetter"?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Deer Slayer, Jun 12, 2009.
  1. Jun 12, 2009 at 11:48 AM
    Deer Slayer
    Deer Slayer [OP] Active Member
    NW Mississippi
    08 4X4 I4 MT Acc Cab
    I recently learned about this chemical you can add to your coolant or use mixed with water alone if you are not concerned about freezing, called "Water Wetter" which is supposed to make your car engine run cooler. I know at least Redline makes it. Not sure if the name is a trade mark name they own or if others have similar chemicals with the same name.
    Was just wondering if any body has tried it and what they tought about it.
  2. Jun 12, 2009 at 11:50 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    I know that some of the sport bike folk use it in distilled water for track days (can't run anti freeze on many tracks). I have not heard anything bad about it.
  3. Jun 12, 2009 at 11:52 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
  4. Jun 12, 2009 at 11:56 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Water Wetter is great in my motorcycle- Dropped normal operating temps about 6 degrees on average...It works best mixed with distilled water. It'd be expensive to load your cooling system with JUST WW...It's like 16 bucks for a bottle that is measured in ounces.
    If you want a simple replacement- Check out Engine Ice- It's supposed to be a bit better than WW- but it's not legal at most race tracks so I don't run it in my bike.
    All that being said-I don't know anything about the composition of the cooling journals and stuff in the Tacoma- but I think WW is not compatible with magnesium parts and maybe not good for aluminum too...but I can't remember. So hopefully someone else has better info about how it works in a Taco for ya!!
  5. Jun 12, 2009 at 11:59 AM
    JDMcQ
  6. Jun 12, 2009 at 12:05 PM
    Joe B
    Joe B Well-Known Member
    When I had my '69 Corvette and did the car show and cruise night thing a couple of years ago,some used Water Wetter.I rried it in my vette and never saw any difference.
    Can't see why you would need it on a Tacoma.
  7. Jun 12, 2009 at 12:06 PM
    98tacoma27
    Ben
    Not Beech Creek
    X2. They engine is designed to run at a certain temperature.
  8. Jun 12, 2009 at 12:07 PM
    Deer Slayer
    NW Mississippi
    Has anybody tried it in a Tacoma? I wonder if it allows engine to run a little bit cooler, it would make any difference in performance or operation?
  9. Jun 12, 2009 at 1:06 PM
    Yuma Taco
    Yuma Taco Well-Known Member
    Lee
    Yuma, Az
    09 PreRunner DC TRD
    35% tint windows, OEM black running boards, OEM black roof rack, Foglight mod, De-badged & Sockmonkey Horns decals added, Two ammo box storage units (removed), 110 volt & 12 volt outlets for back seat area, EGR Slimline inchannel visors (all windows), Fold-A-Cover G4, Tonneau, Bedmat.
    I live in the HOT area and in my motorcycle days (Not long ago) I used Water Wetter in my bike. It did seem to cool better. Now bike cooling systems are still more air cooled the our trucks are so....
    Now, I'll add some WW to my Taco once I change the coolant :)
    But keep in mind I do not live where it get's below 30 degrees, my area is normally above 100 most days :D
    Yuma Taco,
  10. Jun 12, 2009 at 1:41 PM
    obxfishn
    obxfishn Well-Known Member
    Eastern Virginia
    2.5" ToyTec Lift, Smitty Built Nerf Bars, Scangauge unit,
    You're playing with fire when you start altering the cooling properties of the coolant. My words of wisdom would tell everyone to let the coolant do its job and do not alter the cooling properties. It could void your warranty if something happens to your block of you blow a head gasket. Just my $.02
  11. Jun 12, 2009 at 1:51 PM
    general61
    general61 Well-Known Member
    Ohio
    20 TRD OR
    My experience with was the same as most, almost no difference in the engine temp, maybe 3 or 4 degrees. The only time I ran it was in my track bike because I had to due to track regulations. And if ever gets down to freezing temps in your area, the damage that can be done is catastrophic if you leave the water wetter in the block.
  12. Jun 12, 2009 at 2:22 PM
    MassTaco
    MassTaco Well-Known Member
    Massachusetts
    V6 4x4 SR5 DC AT5
    The thermostat is virtually never fully open, so you basically always have extra cooling capacity. If you were to change the heat transfer properties of the coolant, the thermostat would close down a bit more so the engine would run at the same temperature. From what I understand, water wetter is effective if you are generating more heat than the cooling system was designed to transfer (ie very heavily modified, and running full-throttle for extended periods).
  13. Jun 12, 2009 at 2:37 PM
    dirthawker1313
    dirthawker1313 Well-Known Member
    Engine Ice is better.. its what all the guys at the track are using in there sportbikes.. i think it would be a waste in our tacomas.. i live in the desert and ive never had cooling issues even on the hottest days running the A/C full blast
  14. Jun 12, 2009 at 5:19 PM
    mcgiiver
    mcgiiver Well-Known Member
    Princeton, NJ
    2009 Access cab 4x4, 4 cyl, stick
    Aftermarket Driving Lights, Hidden Hitch, Removed rear headrests, Side protective moldings, vacuum gauge, Scan Gauge, Leer cap.
    Mass Taco got the right conclusion. The engine will run at the proper temperature because the thermostat will control that. The coolant will be a more efficient heat transfer agent. I ran a 40% mixture of antifreeze and a half bottle of WW in my 97 Taco. Immediately noticed better heat in the cab due to better heat transfer though the heater. 40% mixture was enough for freeze protection and the more water made for better heat transfer also. Water moves heat better than antifreeze.
  15. Jun 12, 2009 at 5:23 PM
    monte1985
    monte1985 Well-Known Member
    Stan
    Lancaster NY
    09 Tacoma Dbl Cab 4.0 S/C
    Supercharger, Magnaflow Exhaust. Audio System . Gauges TRD CAI
    Ive used it in my Monte Carlo SS and noticed a little bit of a temp drop . I also use it in my computer . Its water cooled and i noticed a few degrees difference in the CPU temp
  16. Jun 12, 2009 at 7:03 PM
    BeachBoy
    BeachBoy Well-Known Member
    VT & QC
    '09 DC LB Sport+Leather
    Icon Extended COs / Camburg UCA / ATX Predator Teflon / Mickey Thompson MTZ / Color-Matched emblems / All-Pro Bumper & skids / Stubbs HD-SKO / Alcans custom leafs / U-Bolt flip / Icon rear resi shocks / Rear Bumper
    I run that on my racebike.
    You can'T have coolant on a racetrack so we use water + water wetter.
    It keeps the engine cooler than coolant anyway
