Anybody use an indoor bicycle trainer stand?
Discussion in 'Sports, Hobbies & Interests' started by Simon's Mom, Oct 26, 2010.
  1. Oct 26, 2010 at 5:44 AM
    Simon's Mom
    Simon's Mom [OP] Wag More Bark Less
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    I know nothing about them but want one.
    My goal is to use it 5x a week for fitness & improve endurance.
    My bike is a Trek 6500 w/ quick releases & disc brakes if it matters.
    Also would consider picking up a road bike if it works better on the system.
    After my surgery, I really have gotten to like biking a lot & want to get back into it, but winters are not outside biker friendly unless you have lost your license or stud your tires (you do see this here).
    Budget is around $250
    pros & cons of what you have used or are using would be great.
  2. Oct 26, 2010 at 5:53 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    A lot of guys I work with are heavy into biking, like Pan-Mass challenge type of guys, so I asked the same thing last winter. Unanimously they recommended rollers instead of those trainers that just hold up the rear tire. I can press them a little more to see if they can recommend a specific brand or a place to buy. I know Dick's has one or two, but I know nothing about the quality of their stuff.
    http://www.dickssportinggoods.com/product/index.jsp?productId=2728562&cp=2367438.2367824.2712461
    This is the type of trainer I was recommended, not necessarily that brand though, just an example.
    EDIT: I should clarify, I'm not a real serious cycler, I was asking them for an idea to stay in shape through the winter. I didn't buy one yet because balancing on that thing seems scary at best and it would be embarassing to explain an indoor bicycle accident to coworkers or the ER staff...
  3. Oct 26, 2010 at 5:57 AM
    i love tacos
    i love tacos Well-Known Member
    St. Louis, MO
    01 PreRunner TRD
    Bull Bar, Hella Lights, AiRaid cold air intake
    Check REI they carry multiple models. They have fluid trainers and magnetic. With your budget you should be able to get nice trainer. I don't own one but I've wanted one for two years. You may want to trade out your knobby rear tire for a smoother street tire also.
  4. Nov 15, 2010 at 10:39 AM
    buck
    buck Don't sweat the petty - pet the sweaty
    Ontario, Canada
    15 DC V6 4x4 TRD Magnetic Gray
    High-flow coconut smiley-face air freshener.
    Your trek is fine to use on a trainer, just get a cheapo slick rear tire for it. Anything with knobs will be LOUD.
    You can adjust resistance by changing your bikes gears, don't worry about a trainer with a remote adjustment. Magnetic or fluid will suffice.
    Also, don't try to wheelie on it....
  5. Nov 15, 2010 at 11:02 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    Stock for now
    thank you yes no wheelies..........:laugh:
    and thanks to all who have helped as well. :)
  6. Nov 15, 2010 at 11:17 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
  7. Nov 15, 2010 at 11:20 AM
    SmilingMark
    SmilingMark Well-Known Member
    Mark
    Ogden, UT
    2010 Access Cab
    Color matched grill w/ grillcraft. BHLM and Morimoto Mini HID's Debadged.
    I've got a CycleOps that I love. You will need to get a cheapo slick tire for the rear. I also got a block for the front wheel as well. I has 3 different settings that allow you to adjust the angle of the bike to mix it up.
    I have it set up in front of the big screen, great way to watch sports. I also have a setup next to it for my laptop so I can play online poker while working out as well.
  8. Nov 15, 2010 at 11:23 AM
    jmdaniel
    jmdaniel Has A Well Known Member
    Jeff
    Leander, TX
    2018 Tundra SR5 CrewMax, 1977 FJ40 Landcruiser
    Get rollers, and don't be discouraged the first time you try them. Rollers keep you engaged while you are using them, which is a heck a lot more interesting than stationary types, IMO. You end up really developing your form on a bike, which helps when you are riding the bike off the rollers.
  9. Nov 15, 2010 at 11:48 AM
    toy81
    toy81 Active Member
    Nathan
    Bay Area
    2008 Tacoma TRD
    If you are planning on watching TV while you ride, buy a quiet rear wheel trainer and run a smooth rear tire to avoid the noise of knobby tires. The cheeper fan or magnet resistance trainers can be extremely noisy, listening to music or the TV on one of these is nearly imposable. Look for reviews or try a few out at a shop. I have a fluid Cyclops from REI, good price and pretty quiet.
    Rollers are a great tool as well. They are very quiet, but require a lot of concentration at first. If you are unsure how they work, basically you are riding on a treadmill and your pedaling stroke powers the movement with the rear wheel. The front and rear bicycle wheels act as gyroscopes to hold you upright...any small movement on the bike is felt with greater emphases than on the road. To ride rollers well your body movement must become very balanced and smooth. Riding rollers and watching TV is tricky business as you could imagine. If you venture to the edge of the roller and come off, you will be kissing the ground before you can unclip and catch yourself.
    I have spent many hours on both rollers and trainers. Generally I use the rear wheel trainer for interval training, or if I want to relax and watch a movie while I ride. I use the rollers to improve on balance and pedal stroke efficiency. The few times I have fallen on rollers is when I was watching TV while riding. :)
    If you are looking for a first purchase and want to avoid possible injury I would get a rear wheel trainer with a "leveling kit". (block for front wheel to sit in)
  10. Nov 17, 2010 at 12:52 PM
    CPA_Taco
    CPA_Taco Well-Known Member
    Kansas
    Mall Crawler
    I filled it with awesomeness
    With your situation I would recommend getting a rear tire mounted trainer and not the rollers. The rollers are for those serious bikers, but if you are just wanting to stay in shape over the winter like me I use this exact one. It'll run about $250. I got mine at the local bike shop in town.
    CycleOps Magneto
    The nice thing about this unit is that it uses magnetic force for a progressive resistance ride. Basically the faster you go the more resistance it gives without getting off the bike to adjust the setting. That's the main reason why I bought this model and I love it. I heard a lot of bad things about the fluid ones, but I also read that CycleOps took care of their customers and replaced any that did leak.
    I also use a Trek like you (mines only a 4300) and it hooks up perfectly.
    And don't waste your money ($55) on a front wheel block like this one
    I just stuck a big phone book under my front tire and it works perfectly.
    I would also recommend, like others have said, to get a smoother rear tire. If you go to a local bike shop and ask them for an indoor trainer tire they'll know what you are talking about. I have one just like this and watch TV while I ride and can hear my TV just fine.
  11. Nov 17, 2010 at 1:13 PM
    KCin HBCA
    KCin HBCA 2020 TRD Sport 4x4
    Keith
    Huntington Beach
    2020 Dbl Cab TRD Sport 4x4
  12. Nov 18, 2010 at 11:56 AM
    KCin HBCA
    Keith
    Huntington Beach
    Here is the trainer I have... It is a RDA Magturbo Inter Rim. You don't need to change tires to use this and it is quieter than the ones that contact the tire tread. I found the manual on line too so you can read through it.
    I have no idea what I paid for it so how does $100 + shipping sound if you are interested. My zip code is 92647 and I think it weighs around 10 lbs.
    Let me know what you think.
  13. Jan 9, 2011 at 12:15 PM
    Pugga
    Massachusetts
    Just wondering if you ended up getting a trainer? If so, what did you get and how to do you like it? I'm looking at getting a trainer and wondering what you ended up with and how it's working out.
  14. Dec 12, 2014 at 12:00 PM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
  15. Dec 12, 2014 at 12:10 PM
    Uranium235
    Uranium235 Well-Known Member
    Illinois
    2015 TRD Sport
    Synthetic blinker fluid, upgraded floor mats, custom passenger.
    I had the Cycleops and it was a great trainer. Beware...trainers get very boring very quickly. It is HARD to keep pedalling away and going nowhere. I'd also recommend against rollers...not enough resistance for most people, and trying to balance on them isn't worth the hassle. Don't bother with the dedicated yellow "trainer" tires either. Just get a POS cheapo one and you'll be fine.
    I am a competitive triathlete and don't bike outside if it's less than about 40F out. I bought a Computrainer 4 years ago and haven't looked back. It costs more than an entry level bike though.
  16. Dec 12, 2014 at 12:13 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    Stock for now
    Oh so long ago....
    I ended up finding one from a friend. It worked ok and do not remember the brand. I sold it at my yard sale.
    Now I'm getting into fat tire riding in the winter, I rented one and am hooked. It doesn't get boring and gets me outside on the trails :)
  17. Dec 12, 2014 at 12:16 PM
    Pugga
    Massachusetts
    Just google'd Fat Bikes, those look awesome! How much snow can you reasonably ride in though? Seems like it'd be ok on hard pack but can't see it being any good in powder.
  18. Dec 12, 2014 at 12:33 PM
    DaVikes
    DaVikes Well-Known Member
    Ross
    Denver
    Colorado Sports Car
    Arb front bumper, warn winch, All Pro rear bumper, OME up front, OME and All Pro Standard in Back, ARB locker, 34 x 10.5 KO2's, 17" Level 8 Trackers, and fancy single piece driveshaft.
  19. Dec 14, 2014 at 5:44 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    Stock for now
    I'm not sure how deep but I'm a noob. I was intrigued when I saw them riding on the trail way up in the mountains last year while snowmobiling. Many trails here are multi use so will know more & start a new thread with a report. I've seen some in steep & deep but need to work up to that lol
  20. Dec 14, 2014 at 6:01 PM
    Texas50
    Texas50 Well-Known Member
    Brazoria County-Texas
    11 TRD Sport.
    OME 885's,Light Racing UCA's,Bilstein 5100's all the way around, Deaver AAL. Cooper 265/70/17
