Anyone’s transmission still wonky? 20k miles in
Discussion in '4th Gen. Tacomas (2024+)' started by pnwoctane, Jun 19, 2025.
  1. Jun 19, 2025 at 8:22 PM
    balong48
    balong48 Well-Known Member
    2011 Silver 4Runner Limited
    I disagree, slightly. The A750F was best paired with the V8 in the 4th gen. 5th gen is still smooth with it, but pedal to the floor, the V8+A750F is way smoother.
    My wife’s RAV4 with UA80F is very similar. I’ve learned to anticipate a clunk when coming to a complete stop. It jolts you forward. If I remember reading right, for the UA80 at least, 1st and 2nd are ridiculously close so much so that 2nd is almost another 1st. I wonder if that’s the same with the AL80.
  2. Jun 19, 2025 at 11:00 PM
    TurboDA6
    TurboDA6 Well-Known Member
    It's weird, between Nissan and Toyota, it seems the old 5AT was the best. I had a 5AT Titan for 14 years, that transmission never once behaved improperly.
    Toyota stuck with the 5AT on the 4R for some super secret reason.
    Industry wide, anything with 6 speeds or more seems to be problematic.
    I currently have a 9AT Titan, I swear to God some day I'm going to figure out how to swap the 5AT into it.
    At work, our Ford trucks eat 10AT transmissions like they're snacks. We don't get more than 20k out of them. A peculiar transmission, they don't shift sequentially through each gear, they skip shift. It's too busy to go through 10 (or 9) gears, so most manufacturers program their mega speed transmissions to only shift 4-5 times before getting top gear.
    The complaints about the Tacoma 8AT are similar to how I feel about the 9AT in my Titan. Well, at least they don't break like the Fords and GMs, right?
  3. Jun 20, 2025 at 3:12 AM
    balong48
    If I had to guess, it’s cause it almost got killed two or three times during its 5th gen run. It was supposed to be killed shortly after the refresh but instead sales took off. I then believe it was going to get killed around the 2018 MY but sales stayed strong. So strong sales + that generation being so old = money printing machine. Toyota definitely got its moneys worth out of R&D for the 5th gen.
    The taco got updated to a 6 speed as a stop gap because it finally had competition again. I’d imagine Toyota would’ve drug the 5 speed out longer had it remained the only midsize truck aside from the Frontier.
    TurboDA6[QUOTED] and batacoma like this.
  4. Jun 20, 2025 at 6:34 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Where was the 6spd auto produced? If it's made in Japan which I doubt. Toyota would have thrown it in the 4R. My guess is Toyota had the 6spd built in NA for the NA Tacoma. I agree with everything else you said, but shipping parts from Mexico to Japan to be sent back doesn't make sense, and there never was a reason to update the 4R drivetrain as it was easily sold with minimal complaint from customers.
  5. Jun 20, 2025 at 6:39 AM
    Snakepilot
    Snakepilot Well-Known Member
    Tucson, AZ
    2025 Tacoma TRD Pro
    I wonder why Toyota went to the expense of developing an 8AT for the Tacoma/LC250. They put the Tundra 10AT in the GX which is basically an LC250 which basically a Tacoma. I'm sure it fits. Ford has a 10AT with their 2.3 Rangers and Broncos. The 8AT, with two less gears, is probably a little less expensive per unit compared to the 10AT but the savings in development costs and the commonality among platforms would have offset a lot of that.
    holland1 likes this.
  6. Jun 20, 2025 at 6:51 AM
    batacoma
    batacoma Truck Wars
    I don't dislike the Tundra but the roll out of that truck and it's on going problems combined with the abundance of other half ton options out there I don't think I'd ever want one. If I was a Texan I'd be singing a different tune because it's locally made, and that would make a difference. But why wouldn't Toyota use that transmission on all GAF trucks?
  7. Jun 20, 2025 at 7:15 AM
    balong48
    Common denominator is the 10AT is in the Turbo V6 and 8AT is the Turbo 4.
    Probably came down to efficiency and power output at the different drive ratios - may not have been necessary to do the 10AT in all cases.
    batacoma[QUOTED] likes this.
  8. Jun 20, 2025 at 7:21 AM
    DJR81
    DJR81 Well-Known Member
    2013 5 lug 4 speed auto
    The 5AT in the 2nd gen frontier is a great transmission (engine also great), I've owned 2 of them
    TurboDA6[QUOTED] likes this.
  9. Jun 20, 2025 at 7:30 AM
    Tacoma Dan
    Tacoma Dan Active Member
    Daniel
    Wichita
    2024 Tacoma TRD Sport Celestial Silver Metallic
    im in the exact same boat, took it to the dealer once and they said its normal. I still hate getting in this truck sometimes. ive been considering selling it and getting something else. idk, i feel exactly how you do, i feel like 95% of this truck is awesome, i love the tech. but the trans hurts me every morning :(
  10. Jun 20, 2025 at 7:30 AM
    dneal
    dneal Well-Known Member
    MidMO
    24 TRD OR 6M
    And the Tacoma's 8AT is basically a UA80 reconfigured from FWD to RWD.
  11. Jun 20, 2025 at 9:30 AM
    DJR81
  12. Jun 20, 2025 at 12:13 PM
    batacoma
    batacoma Truck Wars
    Nothing with a 10spd probably needs, it does seem like overkill in a midsize.
  13. Jun 20, 2025 at 1:22 PM
    yotadust
    yotadust Well-Known Member
    all Tacomas transmissions are clunky cycling thru the low gears and thru low rpms. If you aren't going from a stop to 80mph or 80mph to a stop, its going to clunky a lot. My 23 transmission feels like its slamming into a boulder around 3rd gear quite often. It's a similar feeling to how it feels when you lock it in 4 lo. I've had 4 Tacomas and the auto trans have all been that way in one way or another...
    My wife's Highlander on the other hand is smooth as silk all the time no matter how you drive it.
    WilliamJames likes this.
  14. Jun 20, 2025 at 2:46 PM
    Snakepilot
    Tucson, AZ
    2025 Tacoma TRD Pro
    Does that include your 4g?
  15. Jun 20, 2025 at 2:51 PM
    #35
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    As a third gen owner now hearing complaints about the transmission on the 4th gen…
    Lawfarin, WilliamJames and TurboDA6 like this.
  16. Jun 21, 2025 at 7:28 PM
    #36
    smeredith
    smeredith Member
    SkyTaco
    (F)arvada,Colorado
    2024 TRD OR Tacoma , Celestial Silver
    Interesting topic, I think all cars vary a bit. Here's my input
    My 4th Gen Tacoma is not clunky shifting thru any of the gears when it's Hot or cold. Drive in eco most of the time.
    My 2016 5th Gen 4runner transmission was not smooth, however my 2008 Tacoma shifted very smooth.
    Skyler
  17. Jun 22, 2025 at 3:53 AM
    #37
    Goin2drt
    Goin2drt Well-Known Member
    I'd take it to the dealer. I am at 20K, been through one of our coldest winters and the trans has been buttery smooth. My wife's 24 Camry is rougher than the 24 Tacoma.
  18. Jun 22, 2025 at 6:44 AM
    #38
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Yup mines the same way
  19. Jun 22, 2025 at 11:15 AM
    #39
    Edhd0ne
    Edhd0ne Member
    Eds
    Mine was smooth up until 8k. It started doing what everyone here is describing at very random times. I took it in and went on a ride a long with the mechanic but we couldn't replicate it. He checked for codes, and checked the trans fluid. Nothing came up. He told me to bring it back if it gets worse. Bummer.
    Gfenza89 likes this.
  20. Jun 22, 2025 at 11:16 AM
    #40
    Gfenza89
    It’s sad Toyota hasn’t addressed this yet
