Anyone bought this Tire
Discussion in 'Wheels & Tires' started by CrippledOldMan, Aug 11, 2023.
  1. Aug 11, 2023 at 5:49 AM
    CrippledOldMan
    CrippledOldMan [OP] Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    Okay TW, I've been searching for an affordable tire that won't break the bank. Being disabled and retired, I don't drive as much as I used too. I never wear out a set of tires any more, so I'm looking to save a little money. Does any TW member have any experience with this tire. I only posted the Amazon link for information purposes.
    https://www.amazon.com/Travelstar-EcoPath-Terrain-Radial-Tire-265/dp/B07GXFMCB1?keywords=265%2F70%2F16+Tire&qid=1689431848&sr=8-24&th=1
  2. Aug 11, 2023 at 8:07 PM
    Admiral Snackbar
    Admiral Snackbar Well-Known Member
    I have no first hand experience. I know the parent company is called Unicorn Tire. They're tested with others here and they're not the worst.
    https://youtu.be/2hwYCc6YvYM
  3. Aug 11, 2023 at 10:40 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    Same exact video that I watched, that got me interested in these tires. Compared to other tires tested in the video, they did very well.
  4. Aug 12, 2023 at 12:56 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Sidewall says E range so hard ride to start with.
    Walmart even sells them so look at the ratings on their site as many happy and many not.
    Unicorn is an importer only. Looks like lots of balance and out of round comments. Tacomas hate tires like that and if off the truck front end will shake!
    Final word is you get what you pay for. Tires sure are not cheap anymore so feel your pain.
    Discount Tire likes this.
  5. Aug 12, 2023 at 3:22 AM
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    I'd go with a set of Kumho Crugen HT51. Tread is almost an exact copy of Michelin's Defender/LTX but comes in at $160 a tire in 265/70-16 or $156 for the P245/75-16. I put a set on a family member's 01 a few years ago and have zero complaints.
    Haven't had any problems with Kumhos out of the 4 sets I've tried on different vehicles.
  6. Aug 12, 2023 at 4:28 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Stay away from Chinesium tires would be my advice.
