Anyone buy a TRD OR with no intention of off-roading?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cowdog, Sep 30, 2021.
  1. Dec 13, 2021 at 7:04 PM
    #141
    eosrory
    eosrory Well-Known Member
    2019 Tacoma TRD OFFROAD Quicksand
    Rear locker is cool though. You don't have to use it. While you must have it.
  2. Dec 14, 2021 at 4:14 AM
    #142
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    Yes, a 2wd does not have to push the extra weight up front (that's weight not over the drive wheels) nor overcome the rotating friction of 4wd components especially true in older trucks.
  3. Dec 14, 2021 at 10:32 AM
    #143
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    Still not convinced. Driving in snow has so many variables; snow has such a wide spectrum of depth, temperature, density, surface underneath. Then there is the tires and the point of wear they are at, the driver, the day, the speed, road dynamics...
    In theory, the ~100lbs of diff and axles would be more weight to move, but it also increases front end friction. Kinda like the improvements seen with skinny tires able to cut down to gain traction vs the wide for floating on deep sand. The skinny has more relative friction. My understanding is friction increased more so with pressure, not surface area. But I digress. Some physics bros could explain better.
    Unless you had run back to back tests, same road, both following a slightly different line as to not compromise the condition for the next test, I am thinking this is just some old wisdom from someone's grandpa. But whatever works for you... Just my two penny's.
  4. Dec 14, 2021 at 10:41 AM
    #144
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    yea no.
    Chucky888_2021_TRD_OR likes this.
  5. Dec 14, 2021 at 11:24 AM
    #145
    Rvh09
    Rvh09 Active Member
    Rob
    2021 Cement Tacoma TRD OR
    Yeah I'm guilty! Not to say I never will, but don't have plans to at this point
  6. Dec 14, 2021 at 11:26 AM
    #146
    Mmaira2018
    Mmaira2018 Well-Known Member
    Of course. How many Raptors do you think ever have seen Baja? 1% maybe?
  7. Dec 14, 2021 at 11:33 AM
    #147
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I guess the key is too heavy for some to use from what i can figure.
  8. Dec 14, 2021 at 11:37 AM
    #148
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Or a smartkey is too difficult for some to use from what I can figure.
  9. Dec 14, 2021 at 12:12 PM
    #149
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    I didn’t go truck hunting with any thought of off-roading. My dealer had an Off Road in stock that met my criteria.
    tow rating
    AT
    4x4,
    Double cab
    fit into my parkade space (short box)
    Price in a range I could manage
    Didn’t have a clue what the various models and trim levels were all about then, just so long as it did what I wanted.
    I think we were up-sold but no regrets. All the bells and whistles work and I check them out every once in a while. Plus I like the look of the fender flares.
    dleithaus likes this.
  10. Dec 14, 2021 at 1:21 PM
    #150
    dleithaus
    dleithaus Well-Known Member
    Washington State
    2024 TRD OR iForce Max
    Exactly.
    Fitting into a garage was a top priority for me.
    My garage will fit most cars but trucks are another matter.
    For instance, a 2021 F-150 access cab (they call it super cab?) would leave about 1/2 inch to the rear wall of my garage with the garage door closed.
    I am not even sure if I could squeeze that particular vehicle in there with the hanging ball against the windshield without continual adjustment!
    My 2021 AC LB leaves about 8 inches of room to get to the beer refrigerator!
    wiljayhi[QUOTED] likes this.
  11. Dec 14, 2021 at 4:26 PM
    #151
    The Money Pit
    The Money Pit Member
    DFW, TX
    2019 DCSB OR
    3” OME Lift, 33” DuraTracs, Taco Bar, ARB Summit Bumper
    It fits in my garage, barely. Like open the garage door to go from one side of the Taco to the other.
    I'd like to off road, one day. My mods will support it. Until then, I mad flex at the grocery store parking lot. Those speed bumps ain't got shit on this Taco!
    dleithaus and Claudiomartinof like this.
  12. Dec 15, 2021 at 6:07 AM
    #152
    Vmax540
    Chuck
    Clarion PA.
    Wow... pretty much has to be all other factor's being equal (like I said) except 2wd vs. 4wd
  13. Dec 15, 2021 at 6:14 AM
    #153
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    I would NOT buy an Off Road with no intention of off roading.
    I bought a Pro with no intention of off roading. :laugh:
  14. Dec 15, 2021 at 6:30 AM
    #154
    findingthingsout
    midwest
    The front clam shell and axles sure looked in line with the front tires when I swapped it out for new gears...
    Anyways, we can agree to disagree.
  15. Dec 15, 2021 at 7:05 AM
    #155
    Cazman13
    Cazman13 Well-Known Member
    Northern Minnesota
    2022 Tacoma TRD OR Premium Blue Crush
    Yeah I am guilty! Worst mine will see is a dirt road I am sure. But that could change. But initially I bought it cause it had the options I wanted and I didn't care for the hood scoop that added 80 hp on the sport. :)
