Anyone Change Rear diff and M/T transmission Oil Yet??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bobrown14, Oct 19, 2016.
  1. Oct 19, 2016 at 8:09 AM
    bobrown14
    bobrown14 [OP] Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    What gear oil did you go with??
    I'm looking at Amsoil gear and on the Amsoil website is says with the MT my rear diff needs 6.1qts but the manual says 4 qts...??
    I thinking of using the severe-gear 75w-90 in the diffs (front and rear) and thinking about using the same thing in the manual tranny - anyone think I should use the standard 75w90 GL-4 oil for the transmission instead.
    There's the standard manual trans and diff fluid GL-4 from Amsoil and the heavy duty severe-gear which is GL-5 75w90 which is what the manual says to use in the tranny... any reason for NOT just using the Severe-gear stuff in the diffs AND the manual trans??
  2. Oct 19, 2016 at 8:31 AM
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    I used the Redline MT-90 in my transmission. I can't say that it's better or worse than anything else, but a lot of people use it.
    The rear differential definitely doesn't hold 6 quarts.
  3. Oct 19, 2016 at 8:51 AM
    SnowRanger13
    SnowRanger13 Well-Known Member
    Winnipeg, Manitoba, Canada
    2016 Tacoma TRD OR AC 6MT
    Maybe the 6.1qts is front + rear?
    I was thinking about changing to amsoil as well but haven't yet.
  4. Oct 19, 2016 at 8:55 AM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    rear diff takes a hair over 4, front takes a little under 2. I used not quite 6 quarts
    AdventureKid and TroutBum like this.
  5. Oct 19, 2016 at 9:51 AM
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    Not sure where you're looking on Amsoil's site but they are claiming 8 pints for MT rear differential.
    The 6.1 is listed on some configurations for some reason, along side an 8 pint recommendation so that's a bit confusing, but in all cases, they are pints, not quarts.
  6. Oct 19, 2016 at 10:19 AM
    vinkon235
    vinkon235 Well-Known Member
    vince
    steubenville oh
    2016 white tacoma trdor access cab
    opt7 cree series fog lights busman aux relay box viair 450c oba opt7 fluxbeam led headlights
    4 quarts in rear diff. when I changed over to royal purple.
  7. Oct 19, 2016 at 10:54 AM
    bobrown14
    Bob
    Philadelphia
    Gen 3
    Damn-it... that gosh darn reading comprehension thing again.... jeeez! Yer right pints not qts...
    Thanks for clarifying.
    Anyone see a problem with just going straight up 75w90 all around (front/rear diffs & MT)??
    I'm thinking going with the severe-gear goo....?
  8. Oct 19, 2016 at 11:11 AM
    SnowRanger13
  9. Oct 19, 2016 at 11:40 AM
    bobrown14
    Bob
    Philadelphia
    Gen 3
    I saw that ... thanks ..
    Another ?? What tool takes out the fill plug is it a 10mm hex or will a 1/4" drive end work??
  10. Oct 19, 2016 at 12:32 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Nah I just had them replace the entire rear diff. I guess the new one came with fresh fluid. It's howling now too so I'll probably be in to get a new "fluid" change soon.
    shakerhood and GPsevinSixx like this.
  11. Oct 19, 2016 at 12:38 PM
    fdbyrne
    Missouri
    I believe that both the transmission and rear differential are 24mm sockets. I've not done the front, but 10mm hex sounds right compared to other Toyotas trucks that I've done in the past.
  12. Oct 20, 2016 at 10:51 AM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Your service regimen is too fancy.... LOL
  13. Oct 20, 2016 at 11:14 AM
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Are these differentials mechanically limited slip, or electronic via abs only?
  14. Oct 20, 2016 at 11:45 AM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    the right amount though? probably not
    smitty99[QUOTED] likes this.
  15. Oct 20, 2016 at 12:11 PM
    flying_az
    flying_az Well-Known Member
    Scottsdale, AZ
    2014 TRD Off Road, 4X4, MT
    Old Man EMU, Avid sliders, Pelfreybilt skids, winch mount bumper & winch, 265/75-16 BFG KO2s, fiberglass tonneau cover, flexible mud flaps, locking tailgate, debadged, decals removed, breather relocate
  16. Oct 20, 2016 at 12:34 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My 2015 calls for 75W-85 in the diffs, there is not much out there to pick from.
  17. Oct 21, 2016 at 12:47 AM
    snefo
    snefo Well-Known Member
    I used Super Tech 80w90 from Wal Mart. Rear diff took almost all of the gallon jug. I used it for flushing fluid to get the break in metal out. Only cost $13/gal.
    Fuel economy is still great. I may keep using it. Diff is nice and quiet.
    I used Amsoil GL4 in the trans. Seems to shift the same as OEM fluid.
  18. Oct 21, 2016 at 4:13 PM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    Hey guys! I tried to change my rear diff oil and I could open the freaking bolt... I spent around half hour under the truck trying and trying and nothing... that bolt is like welded to the freaking diff....
    I came from job and tryed to do it and nothing... the diff wasn't that hot... I could touch it and leave my hand on it..
    So what I'm hoping is that the entire diff was to hot now after a 1 hour drive and that shit was expanded and that's why I couldn't open it... I'm going to try tomorrow morning to see...
    Any thoughts?? Am I the only one???
    Ps: I'm sure I was unscrewing.. or trying to haha
  19. Oct 21, 2016 at 7:17 PM
    shakerhood
    Southern Ohio
    Try spraying the Bolts with some PB Blaster the night before, and DEFINITELY loosen the Fill Plug prior to the Drain Plug.
  20. Oct 21, 2016 at 8:18 PM
    fdbyrne
    Missouri
    I have an 18" section of galvanized steel pipe that I can slip over a standard socket wrench to lengthen it and add leverage. I couldn't get the either the drain or fill bolts off without it but with it, it took very little effort.
    bucktowntaco and Claudiomartinof like this.
