Anyone Change Rear diff and M/T transmission Oil Yet??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bobrown14, Oct 19, 2016.
  1. Oct 22, 2016 at 6:18 AM
    bradwhitenikki
    bradwhitenikki Well-Known Member
    Brad
    2016 Tacoma Trd Off Road 6sp Auto
    It may not be a bad idea to use factory fluids through the waranty period. This would give T less wiggle room for waranty claims and/or good will support down the road. If you want to be safe, change the fluids more often. I changed my rear diff fluid and engine oil at 2k. I changed my complete transmission assemble at 2200 miles as well. That should cover it for a while.
  2. Nov 3, 2016 at 6:27 AM
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
  3. Nov 3, 2016 at 1:53 PM
    ahkouchi
    ahkouchi Well-Known Member
    Andrew
    Big Island Hawaii
    2016 Magnetic Gray Metallic Tacoma
    Front Elka 2.5 non resi with 650lb spring Rear Serviceable 5160's with AAL 265/75/r16 BFG KO2
    used Amsoil SG 75w-90 in my front and rear diff. you need a nice long ratchet. I used a half inch drive 24 inch long snap on Ratchet. Make sure you use a 6 point 24mm socket as well. the 12 points will strip it. You can get a Tekton one on Amazon for like 36 bucks with free shipping https://www.amazon.com/TEKTON-15013...qid=1478206280&sr=8-5&keywords=Tekton+ratchet.
    Also, i don't remember what the front diff was... But if you check the forums you can find out if it is a 24mm or a 10mm hex.
