Anyone consider a Jeep Wrangler?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 80sforlife, Mar 18, 2016.
  1. Aug 10, 2018 at 6:51 AM
    #101
    Muldoon
    Muldoon Well-Known Member
    Robert
    Northeast Ohio
    2009 4x4 ACLB TRD-OR 4.0, Green
    5100s, Wheelers AAL, Leer 100R
    I had a 2 dr early model JK before the Tacoma and loved it. Had it up on 33s, overall about 5" lifted from stock. Had a handful of minor issues along with the famous death wobble that got taken care of then an oil leak problem that may well have been the head gasket.
    But...Back seats were always out, doors almost always off unless it was snowing. Thing was a blast. I loved driving it, even though even with a V6 the 3.8 was dismally underpowered. But anyway kids happen and needs change. I found myself needing to haul and tow things regularly with my business and the farm, the jeep didn't make sense anymore. The 2dr can't effectively haul or tow much of anything.
    I do miss taking the doors off and just the fun of driving it. I hope someday to buy a beater TJ or something to have some fun with, but that day is not soon.
  2. Aug 10, 2018 at 6:53 AM
    #102
    20ravens52
    20ravens52 Well-Known Member
    Maryland
    2017 Toyota Tacoma TRD-Offroad DCLB in MGM
    What's the reason for the change of heart?
  3. Aug 10, 2018 at 7:14 AM
    #103
    Xena1
    Xena1 Well-Known Member
    Ron
    2017 Tacoma Access Cab
    My 2015 had a leaking oil cooler and a bad main buss which made the horn go off and had to drive 20 miles with a blaring horn. Others had defective oil filter housings.
  4. Aug 10, 2018 at 7:20 AM
    #104
    beriman10
    beriman10 Well-Known Member
    Omar
    Orange County
    2019 Jeep Wrangler Unlimited Rubicon
    Fox 2.5 Suspension 2 in Lift
    I came from a a YJ 1990 Wrangler and a 2013 Wrangler and couldn't agree more, two completely different beasts.
    The Tacoma is Excellent offroad if you're into desert driving= High speed sand driving. My Tacoma can go 3x the speed while being twice as smooth. In terms of rock crawling, there is no substitute for short break-over and departure angles and solid axles. Jeep has a winner if you want to take it the extra mile but most never do.
    all three tacomas and 2 wranglers have been reliable for me having driven 60k+ min. on each. The character of a jeep is unmistakable and is something that (if you were a jeep owner prior) you will always miss and want to go back to.
    You cant really go wrong with whatever you choose as long as you acknowledge each vehicles weaknesses
  5. Aug 10, 2018 at 7:35 AM
    #105
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Just getting bored with the Taco. It’s also starting to nickel and dime me and I’m just not having the passion to put time or money into it. It’s just not what I want anymore :notsure:
    My step dad had a JK a few years ago and it rode a lot nicer than the Taco. So the nicer ride on and off-road with even better mpg to boot doesn’t sound like a bad deal.
    When I wrote that post two years ago, “Jeep” was only TJs and older in my mind and I didn’t consider a JK “a real Jeep” but I’ve since gotten over it. And the 3.6l Jeeps seem to be just as reliable as my current Taco.
    Fiesta346 likes this.
  6. Aug 10, 2018 at 7:39 AM
    #106
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Struts and Shocks. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    Wife drives a 2018 JLU Rubicon. I drive the Taco. Best of both.
  7. Aug 10, 2018 at 7:45 AM
    #107
    Glenn671
    Glenn671 Active Member
    Glenn
    2018 DBL Cab TRD Sport
    All stock... for now
    Owned several wranglers and several Tacoma’s. Having a truck is way more practical.
    Hichung likes this.
  8. Aug 10, 2018 at 7:47 AM
    #108
    20ravens52
    Maryland
    The grass will always seem to be greener on the other side..
    I love my taco, as it just seems to be more practical and as you stated before is more likely to be reliable than a Wrangler.
  9. Aug 10, 2018 at 7:48 AM
    #109
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    i get the the whole jeep thing, they are cool..... but when I think jeep i recall the simplicity of my dad's '79 CJ5, not today's Fiat Rubicon....lol.... and please don't start with the flaming about technology advancements, reliability, etc..... I get it.... I just like the general purpose vehicle era of Jeeps......besides, if I didn't need the cargo room of a Taco I'd have a 4runner...
    Linewalker likes this.
  10. Aug 10, 2018 at 7:49 AM
    #110
    Tacoaric
    Tacoaric Well-Known Member
    Dallas, Texas
    King Ranch F250 Powerstroke
    Beater TJ, good luck! Lol. They’re so overpriced right now it’s insane.
  11. Aug 10, 2018 at 7:50 AM
    #111
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    She’ll love it. Congrats.
  12. Aug 10, 2018 at 7:54 AM
    #112
    Glenn671
    Glenn
    Or just wait for this.
  13. Aug 10, 2018 at 7:56 AM
    #113
    Tacoaric
    Dallas, Texas
    Unless you paid 10k for it, I’m not sure you’re being realistic lol
  14. Aug 10, 2018 at 8:03 AM
    #114
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Looks cool, but Jeeps are dead. It was probably the ugliest part on a jeep, but once they stopped using trailer lights for tail lights, the Jeep died.
    Yeah I know Jeeps once used the round trailer lights for tails, maybe it died twice.
  15. Aug 10, 2018 at 8:05 AM
    #115
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Ive never owned a Jeep. What keeps me away is the reputation that they are poor road-trip vehicles. My buddy who owns one describes driving it on the highway as being akin to “trying to push a piece of rope down a hallway”.
    Not really my thing, but undoubtably they are very capable off-road vehicles.
    Hichung likes this.
  16. Aug 10, 2018 at 8:06 AM
    #116
    DustStorm4x4
    U S A
    04 Jeep LJ
    That’s fine but I don’t see many wrangler owners day dreaming about a Tacoma. At this point, everything I toss in my tacos bed can be tossed in the back of an SUV. I’m also not towing much anymore either. I honestly believe a Jeep with more interior space would be more practical for me.
    And what’s wrong for wanting to sell something you’re no longer passionate about? At some point, you have to just throw in the towel and drive what you enjoy. When I wanted a compact truck, I chose the Tacoma and I’ve been riding in these things since 15. Now I want an off-road oriented SUV so that brings me to a 4Runner or Jeep. I’d consider a 4Runner but I want those locked solid axles haha.
  17. Aug 10, 2018 at 8:09 AM
    #117
    Glenn671
    Glenn
    Definitely go for the Jeep. Way more parts too for your off road needs. I seriously thought about a 2018 Wrangler unlimited, but they start at $38K. Way over what I wanted to spend.
    DustStorm4x4[QUOTED] likes this.
  18. Aug 10, 2018 at 8:14 AM
    #118
    DustStorm4x4
    U S A
    04 Jeep LJ
    Yes I was planning on saving up for a JLUR but I think I’m okay with saving a few bucks and going with a newer JKR.
  19. Aug 10, 2018 at 8:15 AM
    #119
    Tacoaric
    Dallas, Texas
    I compare it to driving a loaf of bread into a hurricane when they’re lifted and stuff
  20. Aug 10, 2018 at 8:26 AM
    #120
    Glenn671
    Glenn
    Getting harder to find the 2018’s. Don’t know how I like the 2019 body. If you’re lucky enough and can find an ‘18 next month or October, you should get a good deal.
