Anyone Considered Solar?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by transplant, Nov 13, 2014.
  1. Nov 24, 2014 at 10:26 AM
    #201
    transplant
    transplant [OP] resident know-nothing
    theo
    Crestline, Ca
    89 sr5, 99 OR, 11sport, 14 offroad
    well, that certainly makes more sense. its a load test.
  2. Nov 24, 2014 at 10:45 AM
    #202
    transplant
    theo
    Crestline, Ca
    im seeing that. i could have sworn ive seen a 200ah one of those, but good googa mooga are those expensive!
    damn, this little solar bit just grew into a monster! all i wanted was cold beer and bread that wasnt soggy in my fridge :confused: haha
    thanks JLee, looking forward to seeing more of how you put it all together.
  3. Nov 24, 2014 at 11:16 AM
    #203
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Honestly Ive ran my 50q ARB for four days without starting the truck and it started fine at the end of the trip. If your just going for weekend trips and just want to run a fridge just get a second battery. You should be good for four or five days between starts these fridges don't use much at all. If you want to run more stuff then I'd get a panel so you don't damage your battery over discharging it.
  4. Nov 24, 2014 at 11:23 AM
    #204
    transplant
    theo
    Crestline, Ca
    ok, this is just so i can wrap my head around all this....
    fridge- ARB 50Qt, slider, and tie downs = 1283.73 -ish
    solar- Gp 200W w 30A controller = $1011.99
    battery- VMax 125Ah, dual battery tray, charging relay, fuse block, bed outlet, cabling = 602.14
    roof rack = 555.00 +ship
    all for cold beer and food thats not waterlogged after a day.
    JLee, is that what you shelled out for your 200W solar set up?
  5. Nov 24, 2014 at 11:24 AM
    #205
    transplant
    theo
    Crestline, Ca
    good call. not until i get an onboard compressor and that 1500-2000W inverter will i really need solar or anything heavier i suppose.
    i have seen the light!
  6. Nov 24, 2014 at 11:42 AM
    #206
    JLee
    Jerry
    Grass valley CA
  7. Nov 24, 2014 at 12:26 PM
    #207
    transplant
    theo
    Crestline, Ca
  8. Nov 24, 2014 at 12:41 PM
    #208
    JLee
    Jerry
    Grass valley CA
    It came highly recommended on solar forums I wanted a MPPT controller as they are more efficient then the PWM type you have linked there.
    I would go with a MPPT (Maximum power point tracking) controller if i were you you get more out of your panels that way.
    Specs on mine
    Voltage range for batteries: 12 to 48 volts DC
    Voltage range for solar/wind/hydro: Up to 150 volts DC input
    Up to 30 amps output
    Can be connected in parallel for a total of two Kid controllers.
    Built in lighting controller: dusk-dawn, hourly, day and night settings
    Reverse polarity protection
    Sealed for harsh environments
    No cooling fan
    Dimensions: 9.5"L x 6.6"W x 3.4"D
    Weight: 6 lbs.
    Made in the U.S.A.
    2 year warranty
  9. Nov 24, 2014 at 12:46 PM
    #209
    transplant
    theo
    Crestline, Ca
    ive got a LOT of learning to do still! thanks!
    i believe im going to go with a dual battery set up for now.. and once i have onboard air/winch/more lights or electrical demand... ill upgrade into solar. thanks everyone for all your contributions (or many bags of popcorn :rolleyes:)
    for anyone else with questions... or just visual like i am, i found a great simple schematic for how itll all hook in... (battery monitor optional)
    http://www.sierraexpeditions.com/productimg/IBS/Schematic.jpg
    trailbound likes this.
  10. Nov 24, 2014 at 8:08 PM
    #210
    transplant
    theo
    Crestline, Ca
    same goes for the winch too...
    my dad had much the same response. not going solar?? what the hell is wrong with you boy!
    too many wants, not enough $$. what to do. what to do.
    ill pick up an inverter and solar with my tax refund. dual battery self xmas :D
  11. Nov 24, 2014 at 10:50 PM
    #211
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    You can probably just use a 30W solar panel to keep the jump pack charged.
  12. Nov 25, 2014 at 8:34 AM
    #212
    BamaToy1997
    Bill
    Navarre, FL
    How much current does the AC transformer draw while charging? If you used a solar panel with an inverter, then you could use the automatic part of the AC charging system to keep the jump box constantly up and charged. Just a thought.
  13. May 19, 2015 at 9:27 AM
    #213
    bridaw
    bridaw The light was yellow, Sir.
    Brian
    SoCal, East San Diego County
    10 DC 6-speed TRD OR 4x4 tow debadged
    tailgate hose clamp/washer mod ,disable seatbelt warning ,dealer tinted windows ,running boards ,DiamondBack SE bed cover ,OEM rubber bed mat ,TRD Japan shift knob ,bed rail corner reinforcement with angle brackets+square nuts ,Armor Tech Offroad mount for 60" highlift jack ,Scangauge II ,OEM roof rack ,BajaRack basket ,WeatherTech dark tint window deflectors ,removed mud flaps ,debadged ,stubby antenna ,D-rings - 4 in bed floor + 8 on the side rails ,cut four D-ring slots in bedmat ,secured ActionPacker 48 gal cargo box to bed ,center console lock ,relocated 7 pin harness ,Redline Tuning QuickLIFT Elite hood supports ,Pop & Lock PL5300 tailgate lock ,RAM A-pillar mounts for GPS and Drift HD170 camera ,RAM mounts on bajarack for Drift HD170 exterior shots ,relocated rear differential breather ,headrest iPad mount ,ImMrYo rear view mirror lift ,Panavise Indash mount ,265/75/16 BFG All-Terrain T/A KO on TKO black rims ,installed front and rear WeatherTechTacoma DigitalFit FloorLiners ,replaced interior/external lights with Jumpers LEDs +switchback mod +under hood light ,installed rcbs204 Illuminated 4x4 Switch ,installed left and right Relentless Off-road Fabrication hood hinge light mounts ,installed KB Voodoo's Powder Coated Tailgate Cap System ,installed front and rear Wet Okole seat covers ,made and installed mount for Trail Toys NSA Switch Panel ,did ND4's Fog Light Anytime Mod
    *bump*
    I know, old thread with a bit of a piissing match (from one member) but I was really interested in this thread. Same needs as most. PLENTY of sun in the desert where I explore and camp. Some day I would like a fridge instead of my 7 day cooler. Only need to keep a few things running and the idea of hauling and running a generator is obscene. No freaking way I want that noise and hauling fuel plus it would take up too much space. I've also read quite a bit about compact Lithium-Ion jump start packs vs traditional lead-acid packs and wanted to hear from the folks with experience before I spend $$.
  14. May 23, 2015 at 5:58 PM
    #214
    transplant
    theo
    Crestline, Ca
    i still havent gotten around to it yet. sorry!
  15. May 26, 2015 at 12:12 AM
    #215
    Nate87
    Nate87 Well-Known Member
    Nate
    CONUS
    2013 AC TRD OR
    Jerry,
    Curious to see how your setup turned out. Do you have any updates or photos of the setup? I'd like to see more on that charge controller and where you have it mounted.
    I'll be finishing up my setup but still looking at controllers. I want a MPPT but size is a factor for me.
  16. May 26, 2015 at 1:18 AM
    #216
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    With the amount of money you guys plan on spending on solar you can buy a single LIPO battery 50 or 100ah that will take care of all your needs and then some. Guys i know have compared running a single LIPO(50ah) under massive amp loads and compared to the output of 3 Group 31 batteries. Yes their expensive but damn are they light and really makes up for it.
  17. May 26, 2015 at 12:32 PM
    #217
    JLee
    Jerry
    Grass valley CA
    Its working great were at float on the battery by 9:00 am every morning. Running lights, 82q ARB fridge and charging phones and whatnot in the evening.
    Nate87[QUOTED] likes this.
  18. May 26, 2015 at 12:36 PM
    #218
    mlbdriver
    mlbdriver Well-Known Member
    Ben
    Santa Rosa
    2020 TRD Off-Road
    Go Fast Camper ARB Dual Air-Compressor Pro-Comp 7089 17x8 BFG AT KO2 265x70x17
    Do you have more pictures?
  19. May 26, 2015 at 1:05 PM
    #219
    JLee
    Jerry
    Grass valley CA
    No but i can take some when i get back to the trailer.
  20. May 26, 2015 at 7:13 PM
    #220
    Nate87
    Nate
    CONUS
    2013 AC TRD OR
    If you get the chance, can you take a few measurements of the charger controller? There seems to be a few different dimensions of it online. I've been looking at the Renogy Tracer 20 Amp but I'm not sure it'll fit my needs since I need something more flat with less depth and the one you have might do the trick. I'm looking to put it on one of these boards behind my rear interior panel of my Access Cab. That blank space to the right might be a good spot if it'll fit. Thanks.
