Anyone cut through cowl? Pool in passenger floorboard
Discussion in '1st Gen. Tacomas (1995-2004)' started by trd/chaser, Sep 22, 2021.
  1. Sep 22, 2021 at 4:26 PM
    trd/chaser
    trd/chaser [OP] Member
    greg
    03 sr5 trd offroad package
    anyone cut through cowl above fresh air intake? I have caulked every crack and hole around area of pass. side cowl 03 taco
  2. Sep 22, 2021 at 5:01 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Don't cut through the cowl
    tcBob and HisDad like this.
  3. Sep 22, 2021 at 5:20 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Why would you it makes no sense.
    you have ruled out AC condensation??
  4. Sep 22, 2021 at 7:48 PM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
    I spent a long time trying to fix a leak that I thought was coming from that cowl seam, but ended up being from the windshield seal.
    Next time you have rain coming, stuff a bunch of paper towels around the A pillar, door panels, and around the firewall on the passenger side. Then check which ones are wet and you might find that the leak isn't coming from the cowl seam.
  5. Sep 22, 2021 at 9:15 PM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    Thanks for posting that pdf. My truck doesn't leak but I didn't know about that.
    I usually suspect a leaking windshield or clogged ac drain. Or a sunroof drain if equipped, not sure if 1st gen/best gen had an oem sunroof.
  6. Sep 23, 2021 at 3:22 PM
    trd/chaser
    greg
    I have checked cowl seam & pulled pass. fender sealed all around top of fender at cowl I am at wits end with this f-ing thing water seams to be coming from same damn place a few of my old 90s cherokees leaked.at fresh air seal around plastic stub rising from bottom of cowl canal.I have watched it many times drain down fenderweld kickpanel connection.carpet molded& going to remove.if you have any other ideas love to here them thank you.
  7. Sep 23, 2021 at 3:30 PM
    trd/chaser
    greg
    I ordered a borescope to run it down cowl first
  8. Sep 24, 2021 at 3:42 AM
    assuptgm
    assuptgm Well-Known Member
    2002 white tacoma
    Mine was leaking on the driver’s side in multiple places. The a pillar was wet, the windshield and inside in a seam down under the wipers. I used a spray that I could only find at Lawson Products. It’s called leak check and you can get these really long spray tubes that can reach places you can’t see. She’s all sealed up now. I chased that leak for two years. Good luck!
    HansWorldTravels likes this.
  9. Sep 24, 2021 at 4:54 AM
    Bivouac
    Have you looked where the antenna coax goes into the cab ?
    Water gets on the Coax surface tension holds it to the coax it gets into the cab.
    Does this only happen when parked or only when driving ??
  10. Sep 24, 2021 at 5:18 PM
    trd/chaser
    greg
