Anyone do a re-gear?
Discussion in 'Canada' started by Kirk5370, Mar 2, 2017.
  1. Mar 2, 2017 at 2:37 PM
    Kirk5370
    Kirk5370 [OP] Well-Known Member
    Toronto, Ontario
    2017 DCLB TRD Sport +
    Clazzio, Weatherbeaters, Softopper
    Looking for a shop around Toronto.
  2. Mar 2, 2017 at 2:42 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  3. Mar 2, 2017 at 2:45 PM
    mustangwilly
    mustangwilly Well-Known Member
    2017 DCSB OR Quicksand MT
    Out of curiosity, are you re-gearing because you're going to a larger tire size or are you just unhappy with the stock gearing?
  4. Mar 2, 2017 at 2:46 PM
    Kirk5370
    Toronto, Ontario
    Both. I won't be going much larger than my stock tire size, but the gear hunting with the stock set up is enough to bother me I can only imagine what it will be like when I add more rubber.
  5. Mar 2, 2017 at 2:55 PM
    mustangwilly
    I figured that was the reason. The stock gearing is pathetic. Hopefully you can get it done and start enjoying your truck. My solution was to trade it in on a manual.
    Tridet167 and taczilla like this.
  6. Mar 2, 2017 at 2:56 PM
    Kirk5370
    Toronto, Ontario
    I occasionally need the wife to drive me home when I've been hitting the bottle:cheers:, or I would have gone the manual.
    mustangwilly[QUOTED] likes this.
  7. Mar 2, 2017 at 2:56 PM
    Kirk5370
    Toronto, Ontario
    Also - no long bed.
  8. Mar 2, 2017 at 2:57 PM
    mustangwilly
    Yep, I lost my long bed in the deal. I'm going to miss it for sure.
  9. Mar 2, 2017 at 3:42 PM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    I don't think it will help at all. The tranny will still do the same shit, unless you remap that as well.
    But if you want to spend money:
    http://www.ctmotorsports.ca/store/
    T4RFTMFW[QUOTED] likes this.
  10. Mar 2, 2017 at 3:55 PM
    Pushincaskets
    Pushincaskets Well-Known Member
    High Point, NC
    07 PreRunner DCSB
    4" Maxtrac Spindles, Dakars and extra leaf, SOS Concepts bed rack, Lund tonneau cover, RTT,
    Pretty sure this might be correct, as far as I have heard the issue lies in the fact that they want to achieve better gas mileage, companies are adding more and more gears to Auto trans and using mapping changes, this is the result. Changing the gearing may help it from hunting under some condition or speed, but then it will just hunt in another. I.e. City vs. highway driving or vice verse
  11. Mar 2, 2017 at 4:12 PM
    taczilla
    Marc
    2016 RAM Rebel
    ... basically at now different speeds according to the pre-mapped RPM shift points, which won't change.
    Trade for, or buy, an MT... or use that fancy ECT button that you have.
    mustangwilly likes this.
  12. Mar 3, 2017 at 9:31 AM
    Kirk5370
    Toronto, Ontario
    I guess I'll push the button. Look into the tranny mapping, there is a lot more than just RPM range in the transmission programming. There are a lot of sensors feeding data to that ECU
  13. Mar 3, 2017 at 9:55 AM
    taczilla
    Marc
    2016 RAM Rebel
    I know that the tranny issue is pushing a lot of owner's buttons as well. :rofl:
  14. Mar 3, 2017 at 11:19 AM
    BR Pipke
    BR Pipke Well-Known Member
    Drayton Valley Canada
    11 TRD short box 6speed std with 3" lift bilstein 5100 struts pro comp UCA AFE air cleaner and throttle spacer ultra rims 265-70/18 dual exhaust
    I just done a re-gear in my taco went to 4:56. Very happy with the change. Running 285-70-17 makes the rpm higher but more proper on take off. Did the speedometer recalibration. Got my regear from the JT Differential they were great to deal with. It only took a week to get them. East Coast gear supply has gears assembly with any ratio you want and if you want locking diffs, they'll will install them also, they do the same as JT. Check them out, give them a call
