Anyone do alignments at home?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ccal, Dec 1, 2017.
  1. Dec 1, 2017 at 2:01 PM
    ccal
    ccal [OP] Well-Known Member
    carmen
    kirtland ohio
    2014 tacoma trd
    2.25 leveling kit
    my front tires look to be sitting like this \--/ .I recently had an alignment done and brought it back up to them twice. the first time they didn't do anything but charge me 85 dollars the second time they changed settings to make it within specs but now when I look at the front of my truck on level ground it sits like this \--/. has anyone checked camber with a digital angle finder? I bought one today and just not sure what number it should be reading to be within specs or a good number to leave it at. my truck has adjustable upper control arms and a 2.5 in lift up front. any help would be great so I can check this and bring it back up to the alignment shop again .
  2. Dec 1, 2017 at 2:05 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    on my 1982 hilux but not any more....................0 degree toe, 0 degree camber and somewhere between 2.4 and 3 for castor is what to shoot for. If they cannot get it right then you may have the upper ball joint incorrectly positioned if the UCAs are LR(SPC). They have a specific orientation that gives more or less castor. The depiction you are showing seems to be incorrect camber. If these are LR UCAs then you have camber adjustment slot in UCA as well as the oem adjusters downstairs on LCA to adjust camber. Center the oems and center the UCA slot with ball joint oriented to give 1 degree of castor then fine tune it with machine. Camber off will wear tire edges and castor off will be all twitchy feeling on uneven surfaces but will not wear tires. Toe off will obviously wear tires. A tiny bit of negative toe is OK - whatever spec is.
  3. Dec 1, 2017 at 3:22 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Most shops do a free alignment check. Get a printout and report back
  4. Dec 1, 2017 at 3:25 PM
    tweakit88
    tweakit88 COPELANDING_ADVENTURES
    Leroy IL
    3rd gen inferno TRD OR.
    Only the best.
  5. Dec 1, 2017 at 3:29 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  6. Dec 1, 2017 at 3:30 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    IIRC @jberry813 made a really detailed alignment DIY write-up
    BassAckwards and Unchained 5150 like this.
  7. Dec 1, 2017 at 3:30 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  8. Dec 1, 2017 at 3:33 PM
    R490
    R490 Well-Known Member
    Upgrayedd
    VA/PA
    I personally wouldn't. The alignment rack is a very average invention.
    Bebop likes this.
  9. Dec 1, 2017 at 3:34 PM
    Bebop
    Nick
    I couldn't imagine tweaking camber and caster in my driveway. Glad I have an alignment rack at work.
  10. Dec 1, 2017 at 3:46 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Go somewhere that has a Hunter quick check; takes less than 5 minutes.
    Most dealership's have them and it's free.
    Bebop likes this.
  11. Dec 1, 2017 at 3:53 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    I did mine at home for a few years. Provided you take the time, willing to buy the tools, and have an understanding of what needs to be done, you can do it relatively easily and get it pretty good.. What stopped me was working on semis on Hunter branded alignment equipment. The precision of those machines is insane. I was able to do my truck on the semi rack once I went to 285/75/16's, 31" was too small.
    Now I have changed careers, out of automotive so no more rack access and decided the hassle is not worth it to me. So I pay the local alignment shop who specialize in less common setups 50 doll hairs to do the job better and faster then what I could do in the driveway.
    JoefromPTC likes this.
  12. Dec 1, 2017 at 5:25 PM
    ccal
    carmen
    kirtland ohio
    2014 tacoma trd
    2.25 leveling kit
    these are my numbers after the second alignment. Caster left 2.3, right 2.1 Camber left 0.6, right 0.0 , Toe left .05, right .05 .I do have the spc upper control arms
  13. Dec 1, 2017 at 7:04 PM
    TacoAlaMode
    TacoAlaMode Mr. Midlife Crisis
    Brian
    Huntsville AL
    10 DC LB MG 4X4 TRD Sport
    Icon Ext Coilover, Alcan Rear springs, Demello 3-Hoop Bumper and RockCrusher Sliders, Full tint 360', WeatherTech Floor liners and rainguards, Debadged, In Cabin 110 with 400w anytime, Diff breather mod
    Those numbers should be fine. My home alignment is primarily for toe after knocking my truck out of line and need/wanting to get the wheel straight enough to not kick off the VSC. I use a string to make sure my front tires are straight with the rear. If Camber needs adjusted, measure from the wheel, not the tire. You need to make sure you let the suspension and tires settle after any changes and then recheck. I normal pull out of my garage and make sure to give her some turns. Then pull back in and recheck.
